Question about Lanier Office Equipment & Supplies
Lanier LD335c shows SC990 when connected to network
LD335c. I moved it from one office to another. Different network. Now I get a SC990 whenever I connect the network. Works fine without the network cable connected but as soon as I plug it in a 990 pops up. It's obviously a setting but I'm lost. Any Ideas?
  • quennie732 Feb 04, 2014
    The Gateway would not be the same...
  • Lanier Expert
  • 393 Answers
Check IP address sub net, ect?
Posted on Jan 11, 2014
Testimonial: "Yes, I checked all of those. They are exactly the same as all of the other machines in the office that are connected to the network. Very strange!! I used this machine on the other network before moving it and it worked fine."
4 Suggested Answers
  • 8 Answers
SOURCE: Dell 3000cn Network Connection not working
First of, the ethernet must be 'on'. If dhcp available, set it to auto (or dhcp.. anyways..) and let it reboot, just in case :)
if not, try setting the IP-setting yourself. They should be somewhat similar to the settings on your local computer(s).
To add the printer to your computer, select 'Local' printer and specify 'tcp/ip' as which port its connected to. In the new window the ip to the printer should be entered. :) (at least for XP this is..)
Hope this gave you the correct solution..
Posted on Mar 18, 2008
SOURCE: Cannot setup/connect to Kyocera CS-2050
go to kyocera mita america online. they have all the drivers. you need the KX driver
Posted on Feb 05, 2009
SOURCE: Network Connection (LAN) for HP 650C
I have a HP 650C, I just bought a Parallel to USB adapter on Ebay. It can plug straight into a computer and then be shared. I also have network card on a HP 750C+ and have it connected straight to my router through an Ethernet connection and it works fine.
Posted on May 18, 2009
LANIER LD135 CODIGO DE ERROR SC990
Depends on the associate engine code. Most of the time it means that maintenance is overdue. Otherwise, it is an electronic issue.
Jun 10, 2014 | Lanier Office Equipment & Supplies
Lanier 335c toner won't load
If the toner hopper assembly is not broken the mylars inside of it have fallen off over time. The toner supply unit needs to be replaced.
Apr 25, 2014 | Lanier Ld328c Ld335c Type R1 Toner Black...
Not want to read the new toner
Very, very common issue on these normally related to a problem in the toner hopper assembly itself.
Feb 08, 2014 | Lanier Ld328c Ld335c Ld345c Black...
LD335c Networking causing SC990
You need to check the network address of the newly connected network. you said it was connected to a network A (e.g. 192.168.1.0 subnet mask 255.255.255.0 or /24) and now you are connected to network B (e.g. 192.168.2.0 subnet mask 255.255.255.0 or /24). Your device had an ip address assigned in the old network, could be 192.168.1.99 this ip can not communicate with the new network 192.168.2.0, you need fir to find out what is the new network address and subnet you need to ask your network admin. and then modify the setting of your router to be part of the new network.
Dec 27, 2013 | Computers & Internet
Lanier 5618 Network
Lanier 5618 is not a Network Copier. However, it may be installed on one PC and shared from there. Drivers are available from LANIER Official Support
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 22, 2011 | Lanier 1205 Copier
How do I get my Ace laptop to connect to my wifi? It shows that it's connected to the internet and it work in my office, but when I step out of the room it won't stay connected.
When you are within a region of discoverable network, you would be able to connect to that network's internet access. But if that network is weak, there is a possibility that when you move out of range of the network, there would be a fluctuation or disconnection. So, if you must use the wireless in the office, check that the signal strenght is high. If it is not, aviod moving about.
You may not be able to access your office network when you are out of the office.
Hope that helped?
Jul 11, 2011 | Acer Computers & Internet
Network error CE-02
You didn't tell me enough about the problem. Are you trying to scan from a PC or to a PC? The problem is that the network address changed when you moved the printer. You can fix this by correcting the network address
Nov 23, 2009 | Sharp AR-M162 All-In-One Laser Printer
2 NICs connecting to 2 different networks
you need to speak to your network administrator, for printers you get network enabled printers ( your network admin will assign an IP address and sharenames for your printers,
your network admin can create shared volumes on the network and can sort out internet routing that complies with the corporate domain.
sorry no easy way to do this
Oct 04, 2008 | Compaq Presario 5000 PC Desktop
Cannot connect to SonicWall VPN
My guess is that dhcp is using the same private network scheme. Try changing your home network scheme to something different than your office.
For example:
Office = 192.168.1.x
home = 192.168.2.x
Aug 26, 2008 | Westell Wirespeed VersaLink...
Unable to print more than 3 copies of anything
What error if any do you get? Sounds like your printer needs a firmware update.
Carl ( Lanier tech )
Oct 24, 2006 | Lanier 5222/27 Laser Printer
118 people viewed this question
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
