Question about Philips HTS3541/F7 - 5.1-Channel Blu-ray Home Theater System with
Home Theater System is stuck in "starting" mode
I had a power outage the other day and ever since, my home theater system is stuck in "starting" mode and won't allow me to change or even start any of the audio options like Aux 1. The system is on a power strip that is a surge protector and nothing else that was plugged into the strip is damaged. But the HTS/blue ray player will turn on only to the "starting" mode and nothing else. Customer service sent me to a repair shop, but I'm not sure it's worth fixing -it only cost about $250 to begin with. Any help is much appreciated. Oh and I already tried unplugging it to reset it. Thanks!! Carolyn
  • Santino Torres Oct 20, 2015
    My player is stuck in starting mode too... Can't fix. Help anyone?
Thanks Seattle TimE!!!! I thought it was shot. Did the repair you suggested and wors great!
Posted on Jan 29, 2015
  • 46 Answers
I don't see the starting mode described in the user's manual, so I don't know if the buttons on the remote work or not, but you if they do you can try to reset to restore the default settings. Press the Home button, Select Set up and then press oK. Select Advance - Restore Default Settings and then press OK. Select OK and the press OK to confirm.
Also you might want to check if you can if the software is up to date. Compare the version of your current software with the latest version on the Phillips website.
Posted on Jan 07, 2014
4 Suggested Answers
SeattleTimE
  • 3 Answers
SOURCE: not powering on
I solved this problem on my HTS3410D.
Inside there are two circuit boards, the power supply board and the audio/video board.
  • First, unplug your unit and let it sit for a few hours.
  • Now open the unit up, and unplug all of the connectors going to or from the power supply board. You can easily tell which board is the power supply board because it's the one the power cord plugs into.
  • Unscrew the four mounting screws that hold the board to the case.
  • Using a pair of needle-nose pliers, squeeze the two white plastic clips that hold the board to the case (one at a time), while gently lifting the board away from the case.
  • Now that you have the board out, feel the tops of all the capacitors (they look like this). Healthy capacitors should have a totally flat top. (There is probably one that is covered in some sort of heat shrink, so you can't feel the top.)
  • One capacitor most likely has a slightly bulging top. That is the culprit.
  • Using a soldering iron, carefully remove the busted capacitor, making sure to note which side the stripe is on.
  • Buy a replacement capacitor at Radio Shack or www.digikey.com that has the same capacitance (e.g. - 1000uF) an equal or greater voltage, and an equal or greater maximum temperature.
  • Insert and re-solder the replacement capacitor in the same orientation as the one you took out, then trim the excess leads.
  • Reassemble your system, and you're done.
The capacitor that died on mine was 1,000uF, 16V, 105°C. It was located fairly close to where the power cord comes in to the board. I replaced it with a 1,000uF 50V capacitor, and the system powered right up like a champ. The entire process took me about an hour.
I hope this helps some other people have similar results.
Posted on Mar 20, 2008
SOURCE: Unlock HTS 3555
works very well for my PHILIPS home theater HTS3545 as well - semi
Posted on Aug 04, 2008
  • 88 Answers
SOURCE: Reset my soundbar
Amp is probable going into protection mode. Disconnected all speaker and av wires (only power) and check if it switches on. Try to plugged it in also at another wallsocket. Presume PSU damaged by surge
Posted on Aug 12, 2009
Testimonial: "IT WORKED! I TRIED EVERYTHING! This was on my mind all night. THanks for the help. helping real people solve real problems!!!!!!!!!!!!!!!!"
My rca home theater reciever rt2760 seems to be
Have you tried unplugging and plugging it back in? If that doesn't work, then you might have some bad capacitors in the power supply that aren't allowing it to switch to "on."
Sep 24, 2014 | Audio Players & Recorders
Turn demo mode off on Sony Bravia home theater
On your remote;
Scroll left to settings
System settings
Auto-start up - go through setup and select "Home" (not store)
Sorted
Dec 06, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Reset my soundbar
Aug 12, 2009 | Philips SoundBar DVD Home Theater with...
Sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 23, 2009 | Sony DAV-DX250 System
No home theater sound
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Bad speaker wiring.
Internal fault.
Regards.
Mar 07, 2009 | Denon AVR-4800 Receiver
Gateway desktop 500xl stuck in power saver mode
click start, run and type in msconfig
the menu that appears allows you to start in NORMAL MODE
Jan 04, 2009 | Gateway 500XL PC Desktop
Home Theater Audio System System
Bad speaker wiring.
Internal fault.
Regards.
Dec 22, 2008 | Samsung HT-TX72 Theater System
Home theater system hx-tx72
Bad speaker wiring.
Internal fault.
Regards.
May 30, 2008 | Samsung HT-TXQ120 Home Theater System...
Unit won't allow me to change modes
If you're NOT still under warrantee you should at least open the reciever and look for a blown fuse near where the power cable enters the set. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the receiver to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your reciever serviced.
Jan 17, 2006 | RCA RT2380 Home Theater System System
Philips HTS3541/F7 - 5.1-Channel Blu-ray Home Theater System with Logo
3,119 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
