Question about Brother IntelliFAX 1270E Plain Paper Fax
When I press copy button it will not copy
Copy button will not allow machine to make copies
    Champion:
  • Brother Expert
  • 265 Answers
The key sheet in the control panel is faulty, replace it
Posted on Dec 28, 2013
JayBlair
  • 328 Answers
SOURCE: Copied pages are all black
Is is a lower end product for light duty use. You can try a new genuine OEM drum and or toner, but buying them both would cost as much as a new 2800. Can you print a internal report OK?If so, then your scanner is defective. A common problem with 2800,s
Posted on Aug 07, 2007
Logjam
  • 159 Answers
SOURCE: Copies with the Brother Fax-T104
I presume that it is possible to send a fax normally? To make a copy, the machine is basically sending a fax to itself. Therefore if it is possible to send a normal fax and setting the paper to make a copy in the same way as faxing doesn't allow the copy button to work, then the fault is in the machine. Believe me this machine isn't worth spending money on.
Posted on Dec 24, 2007
leroyal
  • 2120 Answers
SOURCE: when i make a copy on my brother 4750e i get the plain black copy
Your scanner block has a loose connection or it is bad.
Posted on Nov 26, 2008
  • 159 Answers
SOURCE: brotherintellifax4100...will not copy, send or receive fax
This might work: Press Menu, Mode, 0 to enter the Maintenance Mode. Then touch 91 to clear most of the machine's memory. (But not your phone numbers & stuff.)
More likely, that won't work, because your keyboard is messed up. These machines won't allow you to press a key when another is still down. Is one key sitting lower than the others? Or maybe water has been spilled in the keyboard? The keyboard itself might be bad. I've had to replace one only once, but it happens.
Posted on Jun 11, 2009
  • 108 Answers
SOURCE: the fax wont work and the copy wont work
I would first check to see if there is anything that is stuck in the top feeder (ADF) area. If that is all clear I would unplug the machine and leave off for about 10 minutes and then plug back in. If that does not work. there could be a problem with one of the electrical components in the machine.
Posted on Sep 01, 2009
IR2870 HANGUP
contact the manufacturer thru their website . I see no make listed
Feb 17, 2013 | Office Equipment & Supplies
Pin code reached the copy limit. How to re-set the copy limit for pin code?
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. Before resetting the machine you will want to print a usage report. Those instructions are at the bottom of these instructions.
  1. Press the [Log In / Out] button on the Control Panel. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the [Select] button below the Display Screen to select 'System Settings.'
  3. Use the numeric keypad on the Control Panel to enter the Administrator Login ID, then press the [Select] button to confirm.
    NOTE: The default System Administrator Login ID is set to 11111. The System Administrator mode allows you to customize many settings on the machine to suit your particular requirements. The machine enters the Machine Administrator mode only when a correct System Administrator login ID is entered.
  4. Press the [Select] button until 'Auditron Admin' is highlighted, and then press the [Enter] button on the Control Panel to confirm selection. The Auditron Administration screen will be displayed.
  5. Press the middle [Select] button until 'Reset Acc Limit' is highlighted, and then press the [Enter] button. The 'Reset Accounts' screen will be displayed.
  6. Press the left [Select] button to reset all accounts.
  7. Press the middle [Select] button to cancel the request.
  8. Press the left or middle [Select] button to perform the action. The Auditron Administration screen will be displayed.
  9. Press the [Exit] button to return to the default screen.
Solution : How To Print Reports and Lists (Auditron / Copy Meter Report) The Print Report / List feature allows you to print various reports and lists for each non-print job.
  1. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed on the Display Screen. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the middle [Select] button below the Display Screen to display the Report / List information.
  3. Press the [Enter] button on the Control Panel. The Print Report / List (Non-print Jobs) screen will be displayed with the options referenced in the table below.
Copy Meter
Lists the account data such the account name, the limit set for the account and the total number of copies for each account.
  1. Press the [Select] button to scroll to highlight the required report under the appropriate column, then press [Enter].
  2. Press the [Start] button on the Control Panel. The Report / List will print.
May 16, 2011 | Xerox WorkCentre M118 Black and White...
Canon_fax_b820_error_342
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If your problem not solved replace the SCNT PCB
May 01, 2011 | Canon FAX-B820 Plain Paper Bubblejet
Mi da errore ##331 .... dopo aver cambiato le cartucce . prima mi dava errore ##342 ... e non mi prende la carta . ho il fax canon b 140 AIUTATEMI Grazie mille
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If problem not solved replace SCNT PCB.
May 01, 2011 | Canon FAX-B840 Plain Paper Bubblejet
Copies
Insert the original (as if sending a fax) and press the Copy or Start button. Usually clearly marked on fax machines. If not marked then look for a button called "Menu". Scroll using this button until the copy option appears.
Different manufacturers use different methods.
Nov 13, 2009 | Office Equipment & Supplies
I just purchased a FAX-JX300,set it up,pressed Spanish by mistake,now can not clear it to put it into english.I am sure there is a simple solution but I'm definatly tech. challenged.Thanks,John.
Press [Menu], [Start/Copy] x 2, press Scroll Down button 5 times, press [Start/Copy], press Scroll Down button 2 times, press [Start/Copy], press Scroll Up button 5 times, then press [Start/Copy]..... you done it !
Apr 18, 2008 | Office Equipment & Supplies
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Dec 21, 2007 | Brother FAX T104 Plain Paper Thermal...
Brother IntelliFAX 1270E Plain Paper Fax Logo
60 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
