Question about Lenovo IdeaPad Z570 Notebook
Battery fine on lenovo g575, power adapter fine, but computer will not recognise power lead at all when plugged in, so therefore battery just drains.
    Top Expert:
  • Lenovo Master
  • 23,154 Answers
Check there is power coming from the adapter and the socket is not damaged.
Posted on Dec 28, 2013
3 Suggested Answers
elix0411
  • 3530 Answers
SOURCE: Power Failure of Lenovo 3000Y400; AC
Welcome to Fixya!
You can run the computer by just using the power adapter. Take out the battery and turn on the computer just using the power adapter. If the computer wont turn on then possible problem would be the power adapter itself or the socket where you connected the power adapter to your computer.
You need to send the computer to Lenovo depot repair center for repair.You may try to use other lenovo adapters just to check if the adapter is the problem.
Thank you for using Fixya!
Posted on Dec 03, 2010
n5kb
  • 349 Answers
SOURCE: Lenovo 3000 Y410 Laptop Computer
Take it to a shop. This problem is a bad connection inside
Posted on Apr 20, 2011
My lenovo g575 won't power on at all tries then shutdown a few seconds after I hit power button
Try this, and let me know if it works.
  1. First unplug the AC adapter.
  2. Next remove the battery.
  3. Then press the power button 11 times, and hold it for 30 seconds on the 11th time
  4. Reinstall the battery.
  5. Finally plug the AC back in.
  6. Turn on the Laptop
Feb 17, 2015 | Lenovo Computers & Internet
How to connect wifi in lenovo g575
In order to connect to a wireless network and the Internet on an IBM Lenovo machine, you must first enable wireless networking via your computer's operating system. Allow about five minutes to enable your IBM Lenovo computer's wireless capabilities.
Click the Windows logo in the bottom left of your screen. Select "Control Panel" from the menu. Click the "Network and Internet" icon in the Control Panel. Click "Network and Sharing Center." Right click "Wireless Network Connection" icon. Select "Enable." Enable Wireless via Switch Check your IBM Lenovo laptop for a wireless networking switch. It is usually on the front of the computer above the keyboard. Slide the wireless switch to the "On" position. Look for a wireless light on the front of the laptop. In some cases a light will come on to indicate that wireless networking is active. Other switches, when active, reveal a green strip of plastic.
Troubleshoot network connection problems http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-network-connection-problems Lenovo support http://www-307.ibm.com/pc/support/site.wss/migr-50402.html
Apr 02, 2013 | Lenovo G575-438343u Amd E-350 1.60ghz...
My laptop is not charging. i plug the power in but still doenst charge. im not sure if its on the power cords or on the laptop please help asap i need my laptop for school :(
Does the laptop work on AC ? Is the battery or cord/charged a replacement? First, try another cord/charger of the EXACT same specs as original. Second, Is the battery good? How old? Over 4 years? Have it tested. Beware of inexpensive aftermarket batteries and cord/chargers. I assume the laptop works on AC? If you unplug the AC , with battery in, the laptop shuts down immediately?
Nov 26, 2012 | Lenovo IdeaPad Y450 Notebook
N500 will not charge
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 12, 2012 | Lenovo 3000 N500 Notebook
I ve problem when i try to shut down my lenovo G550 2958 laptop.Pls help...
Hi knabeela86,
What is the problem that you are encountering when shutting down the computer?
Try also to perform power drain it might help.
How to perform power drain:
1. Turn off the computer completely.
2. Take out the battery from the system and remove the AC adapter.
3. Press and hold down the power button for 10 - 15 seconds.
4. Put back in the battery and AC adapter then try to power on the computer.
Hope it helps,
Thank you for using FixYa.
Dec 17, 2010 | Lenovo G550 (2958ACU) PC Notebook
Unfreeze a cursor on Lenovo laptop
hi! just a tip in most cases this works. try to do power drain, try to turn off the computer make sure that it is completely turned off, remove the battery and the ac adapter and anything that is plugged on to your computer. press and hold the power button for 15 seconds. try to put the battery back and the ac adapter as well, try to power it on. if still doesnt work try to uninstall and re install the touchpad driver for your lenovo laptop. hope this would help! goodluck!
May 26, 2010 | Toshiba Satellite A135-S4527 Notebook
Mine is lenovo g430.i use windows 7.the system doesnt switch on.the indicaters and the fan comes on and stays.but nothindg is displayed on screen.
Try to perform power drain first as initial troubleshooting.
Procedures:
Unplugged the power adapter
Press and hold the power button for 30 secs
Put the battery back in
Plugged in the power adapter
Turn on the computer
If same issue will happened call our technical support department to have your laptop checked and scheduled for repair. This issue would be an LCD problem.
By the way. Is your unit still under warranty?
May 21, 2010 | Lenovo 3000 N200 Notebook
Battery Wont Charge on my Acer Aspire One Notebook Orange light flashes when power on button is pressed I have checked that the charger is working fine but notebook won't come on as battery is so flat. I...
Try this:
Drain the static on the computer by removing the battery and the power adapter. then press the power button for 1 minute and release. Then plugged the battery back in and turned on the computer, if the computer won't come on plugged the Adapter back to the computer and try turning it on.
If problem persist it is possible that the battery already busted and you need a replacement.
Hope it would help.
May 10, 2010 | Acer Aspire One PC Notebook
Lenovo Y530 T 3200 3GHZ 4G Laptop not charging battery when plugged into outlet;also does not work on battery alone even though it is charged to 85%
Try to perfrom power drain. You must first turn off the computer. Take out the battery and unplug the power adapter. Press and hold the power button for 30 secs. Put the batter back in, plug in the power adapter and power ip the computer then observe.
Let me know if same issue will happen.
May 11, 2010 | Lenovo IdeaPad Y530-3231U Laptop Computer...
How to fix the prolem of audio in Lenovo
hi! just a tip try to do a power drain turn off the computer make sure that it is totally turned off, try ro remove the battery and the ac adapter and anything that is plugged on to your computer. press and hold the power button for 15 seconds. try to put the battery and the ac adapter back try to power it on check if it would work. if it still doesnt try to uninstall and re install the audio driver. hope this help! goodluck!
May 04, 2010 | IBM LENOVO VIDEO ADAPTER-G450 32MB 22P6640...
Lenovo IdeaPad Z570 Notebook Logo
51 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
