Question about HOUSE OF MARLEY Audio Players & Recorders
Inner plug pulled out of plugin
The inner plug has pulled out of the main plug on the headset it stays inside my iPad and has to be pulled out with a pliers and be put back into plug in.
  • Bonnie Jung
    Bonnie Jung Dec 30, 2013
    On my Marley headphones I really want to know if I glue the sleave that has come lose from the plug in that goes into my IPad headset hole. The pin like metal pin stays in my iPad when I try to plull off the plug for the headset
  • Bonnie Jung
    I want to know if it will ruin the contact if I glue it ???
  • 50 Answers
SOURCE: grohe pull out kitchen faucet the inner tube ripped
go to the store you bought it and see if they carry parts. if not , try the internet under grohe.com.
Posted on Jun 11, 2009
  • 14 Answers
SOURCE: Duet GHW9150P inner SS drum is actually loose but
go buy new washer the drum bearings have gone and it really is not worth repairing . it can be repaired but always found that it never lasts long once done.
Posted on Jul 07, 2009
  • 1986 Answers
SOURCE: 1999 Volkswagen Passat inside inner door panel
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
Posted on Aug 14, 2009
sparktgo
  • 68 Answers
SOURCE: inner burner -- front right burner - does not heat up
You will have to check your stat.this is the switch which controls the power to both parts of the ring.It may be faulty.This is a thermostatic switch.It can be checked with a mains test lamp.If this is ok then check the spade terminals are still intact at the ring itself.
Posted on Oct 12, 2009
SOURCE: Changing Spark Plugs on 1999 Honda Shadow 750
Yes, it is an 18mm plug but you will need to use the Honda Plug Tool which is part of the stock tool kit just below the seat. Use that and you will get all of the plugs out very easily.
Posted on Jan 17, 2011
Hi I'm ddesperately trying to find instructions for a tent we just bought which is a Cantera 9. Would you be able to provide this for me please?
I have never seen your tent but found these instructions online. Hope they help:
Erection / Pitching
This tent pitches inner first and uses the popular ring and pin method to locate the poles on both the inner and outer and takes two to erect. The poles are all colour coded making it very easy to identify which poles go in which sleeves. The inner uses six poles to hold up, three for the main living area and one each for the bedroom pods. Once all poles are threaded, its advisable that one person gets inside the inner tent and supports the main poles as they are located. Tip here and for most tents of this design, make sure the first pole you locate on the main living area is the pole on the bottom of the crossover at the top of the tent, this then takes the weight of the poles above making it easier to secure. Locate the main poles and then the bedroom pod poles using the ring and pin system. The inner tent will then require pegging down and this takes around twenty pegs to secure. Finally once the inner is secure the outer flysheet is pulled over the inner, tied on the main poles and then finally pegged. The final thing to do is to locate the two porch poles and secure with the ring and pins and then peg out the guy ropes.
http://www.365campingcaravanning.com/reviews_familytents_1.htm
Also perhaps this video will give you an idea of what it is supposed to look like when it\'s up. https://www.youtube.com/watch?v=7SyVVIXV7l0
Good Luck!
Jul 24, 2014 | Sport & Outdoor - Others
Hi i own Honda fire blade cbr 900 rrt 1996. And have fitted a complete new ebc clutch and inner clutch basket now theirs a loud knocking coming from tthe clutch at tickover that goes when i pull the...
something is not fitted right inside or the new plates don't match the original outer or inner basket. This would cause the plates to "backlash" inside the clutch, especially at idling.
if that's not the case, you might have not tighten hard enough the main shaft nut and it came loose. You need a special tool to hold properly the inner drum.
Jun 25, 2014 | Motorcycles
Cork will not come out of opener
This is from Jen8926 in another forum and it worked for me (push up the inner sleeve an inch or more inside the main tube): Use a screwdriver (or whatever) to push the inner ring at the opening as far inside the appliance as you can. It is a black piece with a spring action that has plastic molded ridges inside. The ridges on the inner edge of this will grasp the cork. Then, while you are holding the inner section in place as far inside as possible, push the button to operate the opener and the cork should come out as it normally should. I had half a cork stuck up there, and this just worked perfectly.
Mar 02, 2013 | Waring Pro WO50 Cordless Wine Opener
When i pull the brake it doesent stay
When you pull the brake lever up it does not lock but pops back down? If so undo the two screws that hold the lever assembly together. You'll see an inner button with a spring and the lever. The inner button has ratchet teeth that need to lock into matching teeth on the inside of the black lever holder. If these are worn you can reshape them with a small file or a rotary tool like a Demell. The lever assembly should be kept well lubricated with silicon spray to avoid ware on the teeth. It is the teeth shape that does the locking and not lubricating them wares them down.
Aug 14, 2011 | Bugaboo Cameleon Jogger
I just obtained a 1989 Cadillac Deville...The drivers door wont open....Locks go up and down...trying to open it form the outside...there is no tension in the handle or from the handle inside either......I...
if you remove the cover that is behind the inside door handle and look you may see the arm that connects to the handle.if its connected then you will have to remove the inner door panel,if its come off the handle and you get a hold of it you can pull on it and the door should open.you have to be patient to remove the door panel with the door closed.you will need to remove some screws to loosen the panel from the steel door inner panel.(arm rest,cover behind the handle).pop up the power door/window switch control and remove the plug attached.pull out the inner door panel to unhook the clips around the outside edge of the panel,you will have to move the seat to get better access to some,then remove the panel and reach into the inner door and move the unlock arm to open the door.you move have clips that are broken that allowed the arms to come off that need replacing to fix the problem.
Jul 16, 2011 | 1989 Cadillac Sedan DeVille
Replace bottom seal hoover dishwasher
There's only 2 screws under the top where it screws to work top and 2 on the inside where there are 2 White plugs on either side. If the bottom door seal is leaking you don't have to pull it out just remove inner door and replace , bottom seal comes with the inner door not separate.
hope this will be helpfull to you.
Goodluck..................
Feb 02, 2011 | Hoover 24 in. HD73M Free-standing...
Replace door seal
its not to easy to do but,,,
look at the bottom of the washer were the door closes the seal is held on with a spring wire,,unhook this wire and fold the seal inside the washer,,look for the inner drum there is another spring wire holding the inner part of the seal to the inner drum undo this as well,, pull old seal out through the door hole,,,now fold new seal so that the inner wire can be fitted round the new seal first to the inner drum,,then pull the new seal through the door hole and fit the outer wire to seal,,,
and then job a good un?,,, not easy a,,well i did tell you this!
Jul 12, 2010 | Frigidaire ATF6000ES Front Load Washer
How do I remove the door panel and replace the inside door handle
PLEASE DON'T FORGET TO RATE!!
Door Panel
  1. Remove the door handles and the locking knob from the inside of the doors.
If equipped with screw retained door pull handles, remove the screws through the handle into the door inner panel.
  1. If equipped with remote control mirrors, remove the remote mirror escutcheon, then disengage the end of the mirror control cable from the escutcheon.
Door lock remote control handle
Removing the clip from inside the door handle
3. If equipped with a switch cover plate in the door armrest, remove the cover plate screws, then disconnect the switches and the cigar lighter (if equipped) from the electrical harness.
4. If equipped with an integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. If equipped with an armrest applied after the door trim installation, remove the armrest-to-inner panel screws.
View of the armrest switch cover plate and remove mirror cable attachment
  1. If equipped with two-piece trim panels, disengage the retainer clips from the front and the rear of the upper trim panel, using tool No. BT-7323A, then lift the upper door trim and slide it slightly rearward to disengage it from the door inner panel at the beltline.
If equipped with electric switches in the door trim panel, disengage the electrical connectors from the switch assembly.
  1. Along the upper edge of the lower trim panel, remove the mounting screws. At the lower edge of the panel, insert tool No. BT-7323A between the inner panel and the trim panel, then disengage the retaining clips from around the outer perimeter. To remove the lower panel, push the panel down and outward to disengage it from the door.
If equipped with courtesy lights, disconnect the wiring harness.
  1. If equipped with an insulator pad glued to the door inner panel, remove the pad (with a putty knife) by separating it from the inner panel.
To install:
If replacing the inner pad to the door inner panel, use 3M General Trim Adhesive No. 8080, glue it to the panel.
  1. If removed, glue a new inner pad to the door inner panel.
If equipped with courtesy lights, connect the wiring harness.
Exploded view of the window regulator handle
Exploded view of the door trim panel
  1. Engage the retaining clips around the edge of the lower trim panel, then install mounting screws.
If equipped with electric switches in the door trim panel, engage the electrical connectors to the switch assembly.
  1. If equipped with two-piece trim panels, engage the retainer clips to the front and the rear of the upper trim panel.
  2. If equipped with an integral armrest, install the retaining screws.
  3. If equipped with a switch cover plate in the door armrest, engage the switches and cigar lighter (if equipped) harness connectors, then install the cover plate and secure using the plate screws.
  4. If equipped with remote control mirrors, engage the control cable, then install the remote mirror escutcheon.
If equipped, install the pull handle screws through the handle into the door inner panel.
  1. Install the door handles and the locking knob to the inside of the doors.
Exploded view of the 2-piece door trim
  1. If equipped with a switch cover plate in the door armrest, remove the cover plate screws, then disconnect the switch
  1. If equipped with an integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. If equipped with an armrest applied after the door trim installation, remove the armrest-to-inner panel screws.
  2. If equipped with two-piece trim panels, disengage the retainer clips from the front and the rear of the upper trim panel, using tool No. BT-7323A, then lift the upper door trim and slide it slightly rearward to disengage it from the door inner panel at the beltline.
To install:
  3. If equipped with a switch cover plate in the door armrest, engage the switch harness connector, then install the cover plate and secure using the plate screws.
Nov 16, 2009 | 1987 Chevrolet Monte Carlo
Front Axel
you have to undo inner cv boot and remove clip inside cv then pull out outer cv with shaft and inner bearing of inner cv,leaving inner cv outer section in diff.If you want to get out inner cv end, diff assembly must come out of vehicle then unbolt plate retainer on diff tube.
Jul 06, 2008 | 1999 Isuzu VehiCROSS
65 people viewed this question
Top HOUSE OF MARLEY Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a HOUSE OF MARLEY Audio Player and Recorder Expert? Answer questions, earn points and help others
