LD335c Networking causing SC990
LD335c. I moved it from one office to another. Different network. Now I get a SC990 whenever I connect the network. Works fine without the network cable connected but as soon as I plug it in a 990 pops up. It's obviously a setting but I'm lost. Any Ideas?
  • 4 Answers
You need to check the network address of the newly connected network. you said it was connected to a network A (e.g. 192.168.1.0 subnet mask 255.255.255.0 or /24) and now you are connected to network B (e.g. 192.168.2.0 subnet mask 255.255.255.0 or /24). Your device had an ip address assigned in the old network, could be 192.168.1.99 this ip can not communicate with the new network 192.168.2.0, you need fir to find out what is the new network address and subnet you need to ask your network admin. and then modify the setting of your router to be part of the new network.
Posted on Dec 28, 2013
4 Suggested Answers
  • 196 Answers
SOURCE: Connection Issues Occur When I Try to Connect Through a Broadband Network Adapter
To resolve this issue, remove the network bridge. To do so, follow these steps: 1. Click Start, and then click My Network Places. 2. In the left pane, click View Network Connections. 3. Look for any connection that is bridged. 4. Right-click the bridged connection, and then click Remove From Bridge. 5. Repeat step 4 for each connection that is connected with a bridge. 6. When the bridge is removed from each network adapter, right-click Network Bridge, and then click Delete. 7. Click OK. When the all the bridged connections and the network bridge are removed, the broadband hardware is automatically detected.
Posted on Feb 16, 2006
SOURCE: wireless router dropping then disappeared
I don't know a solution but the router will appear in the list along with neighboring routers but it will disappear and the others will still be there so it's not an adapter problem something in the router stops sending a signal
Posted on May 22, 2007
Teis
  • 340 Answers
SOURCE: di-524 dlink; wireless laptop connects but no internet or network
Your wireless card is dead, replace.
Posted on Nov 23, 2008
Linksys SD216 isn't working when different laptops are connected
Sounds like either a bad cord or a bad port. have you tried to replace ethernet cable or plugging it into another port.
Feb 24, 2014 | Linksys SD216 16-PORT 10/100 DESKTOP...
Tip
Set up and Use Internet Connection Sharing
To enable Internet Connection Sharing on a network connection
You must be logged on to your computer with an owner account in order to complete this procedure.
Open Network Connections. (Click Start, click Control Panel, and then double–click Network Connections.)
Click the dial–up, local area network, PPPoE, or VPN connection you want to share, and then, under Network Tasks, click Change settings of this connection.
On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box.
If you want this connection to dial automatically when another computer on your home or small office network attempts to access external resources, select the Establish a dial–up connection whenever a computer on my network attempts to access the Internet check box.
If you want other network users to enable or disable the shared Internet connection, select the Allow other network users to control or disable the shared Internet connection check box.
Under Internet Connection Sharing, in Home networking connection, select any adapter that connects the computer sharing its Internet connection to the other computers on your network. The Home networking connection is only present when two or more network adapters are installed on the computer.
To configure Internet options on your client computers for Internet Connection Sharing
Open Internet Explorer. Click Start, point to All Programs, and then click Internet Explorer.)
On the Tools menu, click Internet Options.
On the Connections tab, click Never dial a connection, and then click LAN Settings.
In Automatic configuration, clear the Automatically detect settings and Use automatic configuration script check boxes.
In Proxy Server, clear the Use a proxy server check box.
Bhautesh.
on Feb 24, 2010 | Computers & Internet
I having a problem with frequency. My phone and my neighbor phone seems to be on the same frequency. Is there any way to change this. When her phone rings our do also. We have called the cable n At&t,...
Telephone devices connected as alternative ansering allows for one person or the other to respond especially devices at the same residence. E. g. devices may share the same line like several telephones situated in the bed room interconnected to living room telephones allowing for the same person or owner to answer from any location of the structure. A situation that the telephone connection is thought to be malfunctioning requires consultation with the networking company. Usually, an experts technician would provide separate telephone lines to each devices least interfering with responses. alternatively, wireless telephone networking with modem installations provides residential, office locations networking where several devices share signals least interfering with neigbor response resources. Contact a network structure about wireless networking, broadband networking connectivity at residences, offices, schools or elsewhere.
Jul 20, 2011 | Lands Phones
Networking with two different ISP's
Hi there
Even if you 2 different ISP that doesn't matter. If you need to connect all the computers together i'd suggest you to buy ROUTER and connect wireless.....
For further clarification please revert
Jan 23, 2010 | Network Computing Devices (NSH800S/A)...
I have a cisco router linksys. I connect internet cable to it in ethernet port. Neither by wire not by wireless I can connect my laptop. The connection comes as only local
If you can plug the cable that you have ran into your router into your computer directly and it works, then you can plug the router back in. Then connect the computer to the router via cable and unplug the router for about 15 seconds and plug it back in. If you connect the computer by cable directly and it doesn't work, then try unplugging your router for about 15 seconds and then plugging it in. I have found many networking items that need to be reset whenever a network cable is plugged in when the device is powered on.
Jun 08, 2009 | Cisco Catalyst 2908 (WS-C2908-XL)...
How can i connect to the internet using my switch??
Basically Internet connection required a networking connection for multiple number of PCs.There are 5 types of network connection and most simple and common network connection is Local Area Connection.You can use Windows Xp or Vista for your OS, when connection was made set up your lan from your internet server from cd provided by DSLinternet server.You should Have one PC server for your multiple PC as the administrator.If your inernet was configured from your PC server(as administrator) Share your internet using your LAN in each PC using Windows xp follow set up networking clicking additional task and click Home and office networking then follow wisard set up.You Have now internet connection in your multiple PC.
Feb 24, 2009 | Computers & Internet
Can't connect to 3Com Office connect wireless from Apple Mac Pro
PPPoE connection is set up
1. Control Panel, double-click Network Connections. 2. Click the PPPoE connection under the Broadband group that you want to share, and then click Change settings of this connection under Network Tasks. 3. On the Advanced tab, click to select the Allow other network users to connect through this computer's Internet connection check box. 4. PPPoE connections behave in a similar way as do dial-up networking (DUN) connections, and you may want the connection to be automatically dialed when another computer on your network attempts to connect to the Internet. To do this, click to select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box. 5. If you want to allow other network users to enable or disable the shared Internet connection, click to select the Allow other network users to control or disable the shared Internet connection check box. 6. Under Internet Connection Sharing, in Home networking connection, click the LAN (Local Area Network) connection that connects the computer that is sharing its PPPoE Internet connection to the other computers on your network.
Feb 07, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Communication problems over IP phone
I have found many possible causes. Firmware Levels Outdated firmware in routers, VOIP phones, Firewalls, etc. can cause one-way audio. Ensure you have the latest updates for all the devices in the call path. Configuration Particularly if NAT is involved in the call path, configuration of the various devices may be a problem. Check to see if all devices are configured appropiately for your envioronment. Has anything changed, carriers harware, quos settings on router ? packet loss to these locations should be tested @ time it happens most, don't use it as gospel retur, ttl and re-xmits' do same.. Bob Finding the Cause The basic troubleshooting technique is to use a tool like Ethereal to capture SIP and RTP packets at each point in the call path where packets could be lost. Interperting the resulting captured packets requires some familarity with how networking and VOIP work. For example if the call path is: VOIP phone/device ---- firewall ---- sip proxy ---- firewall ---- asterisk Troubleshooting Steps Start capturing at point Make a VOIP call that will have one-way audio Analyze capture If problem found, fix and retest Otherwise move capture point to the next point (a, b, c, d, etc) and start over If the problem is intermittent, then a long term simultanous capture at multiple points can be used to attempt to capture a comple call with the problem. Most capture tools will let you capture only traffic from selected devices, so the volume of captured information can be kept to a reasonable size. If a back-to-back SIP user agent (for example a Session Border Controller ) is part of of the call path, then it may be necessary to capture all VOIP traffic at some points to ensure catching the wanted call since the IP addresses can change when traversing this device. Resources How To Debug and Troubleshoot VOIP
Nov 14, 2006 | Nortel I2002 IP Phone w/Text Keycaps, No...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
