Question about Kenmore 62062 Electric Dryer
Door switch how do i check and if need replace the door switch
  • 5,911 Answers
I have posted comments under one of your other postings.  Please make replies to your original posting by adding comments instead of making separate postings.  This makes it easier to assist you.
Posted on Oct 18, 2007
2004 nissan sentra power windows not working. Replaced door master switch. Replaced power window relay. Replaced 30 amp fuse under the hood.
Look for broken wires in the driver's door opening. If you don't find any, you will need a test light or voltmeter to check for power at the driver's door master switch. For any electrical testing problem, you really need a voltmeter. You can check for power to the master switch on one single wire, with key ON. You can also use the multi-meter to check the ground for the power windows right at the master switch.
Jan 26, 2018 | Nissan Cars & Trucks
De error code lg washer?
This is a simple error it means the door switch( Door Error ) is not making showing an open door check nothing stopping door from closing if still a problem might need to diagnose door switch
Apr 17, 2016 | LG Washing Machines
I get DE and it won't work, thought it might be switch in door but now wondering if it is the load sensor
this is the explaining right from sears for code DE
Door is open error Check/Repair Unplug the washer. Check the door for an obstruction. If the door is damaged, replace any defective parts. If the door is closing properly, check the door lock/switch assembly wiring. If the wiring connections are okay, then you will usually need to replace the door lock/switch assembly.
Shop Parts Door lock/switch assembly, Washer door components
Feb 02, 2016 | Kenmore Washing Machines
Whirlpool TXFE366LVQ. When I turn selfclean after few minutes it shuts itself off and displays code F5E2
An F5 error code indicates that you need to check the oven door or the latching switch. The switch is used when cleaning the oven, for safe closure. If you find that the door or the latch switch do not function, you may need to replace them
F5-E2 means latch during clean error; the door and latch switch need checking and possible replacement.
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Hope helps.
Jul 14, 2011 | Ovens
My washer door will not open. When I press the Open Door/ Cancel button a buzzing sound will come from behine the handle but the door will not open.
First of all try the reset procedure and see if it helps before proceeding towards troubleshooting:-- Close door
Turn machine on------
Select "Drain/Spin"------
Select "No Spin"------
Press the "Options" button 4 times------
There is a short circuit in the door switch assembly.Its not getting opened due to short in the door switch assembly.You need to get the door switch assembly replaced.But before that open the door by screw driver manually then remove the door lock connections and check the voltage at the door lock switch if its check ok then the door switch is faulty and needs to be replaced.But if the connections checked short then its a short in wires not the switch. Most likely the problem is a bad door lock which has to be replaced. You can find the complete instructions in the Service manual.
- The part number for the lock assembly is AP3837611
You can get required parts from
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher does not run at all,i checked the door
Hello there:
Please try these things i have posted
It doesn't work at all If your dishwasher doesn't work at all, check these: Power from the house Door switch Wiring Timer or selector switch Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker. Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it. Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors. Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be
Jul 14, 2010 | Amana Dishwashers
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
Wont't start dl f on display
HI. this is a Door lock error. Check the following to address this issue. Normally you will need to replace the door lock assembly in this case but, it is not uncommon for it to be just a simple loose wire harness as well.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool dryer stopped working
Check the following to combat this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Jun 18, 2009 | Whirlpool LER4634J Electric Dryer
Dishwasher won't start
Try resetting the unit by shutting off the circuit breaker first for 1 minute then try the reset button. If nothing happens, then i would recommend having someone take a look at it.
Feb 09, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Kenmore 62062 Electric Dryer Logo
71 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
