Question about Yahoo Mail
Talk talk Getting on line
Talk talk my account 1008829859
You really need to contact your phone firm, your provider. I thought they must keep your phone line "alive" so you can make emergency calls.
Talk Talk must be the service coming in with the land line and works as ADSL. If the line is down, nothing works.
Jul 26, 2014 | Lands Phones
I am getting horizontal white lines on my Samsung SGH-L700. It started with one line in the morning and by the evening multiple lines have appeared due to which the display in that location is not...
Samsungs cannot not take a whole lot of abuse. Now I do not mean you are abusing your phone. Wear and tear is what I am talking about. Your screen is gone and you need a replacement phone.
May 27, 2011 | Samsung SGH-L700 Cell Phone
Ice maker does not seem to be getting water, I have seen talk of makeing sure line is not frozen, but my supply line is between the liner of the freezer, I can't see if it is frozen. Small balck part where...
By "small balck part" I assume you are talking about the water valve at the bottom of the refrigerator.
If so, you might try a couple of things. Pull the water line off the valve, and (if you can get close enough to it) blow through it and see if there is a blockage. Another alternative would be to run something fairly stiff but also flexible up the line. (Plastic weedeater line is often good for this.)
If the line is open, either the water valve is bad or the icemaker control is not calling for water.
Oct 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
I have the Uniden DSS7955 + 2 - it it on the same line as my broadband computer line and am getting constant static. When I disconnect the broadband line, the static disappears. I had an older model Uniden...
You will need to get a DSL filter to separate the DSL(broadband) from the talk line. These can be purchased at any store that supports computers.
Apr 16, 2009 | Lands Phones
Ricoh fax error #400
Possibly the fax line is open (busy). Try ringing the fax number, see what you get. Try unplugging the fax and plug a normal analogue handset into the line. See if you are getting a dial tone.
If not, then the cabling or line are faulty. Talk to your carrier. If yes then replace the cable on the fax (if possible) or have it looked at.
Mar 03, 2009 | Ricoh Office Equipment & Supplies
I have a 1988 jeep cherokee.... if im not getting suction from the heater control valve...... where could the problem lie?
If you are talking about the vacuum line going the the heater control valve, the problem can be the control panel or a vacuum line that feeds the control panel. The cherokee has a football shaped vacuum canister in the front bumper on the right side. Check the canister out for cracks or disconnected lines.
Feb 26, 2009 | 1998 Jeep Cherokee
I have a,Amsrtad Emailer phone,problem,its displaying,hold down Emailer button restore services.WHY
ive just solved my problem and have restored my e mailer to full use. but have now discovered that my e mailer does not like Talk Talk ,for when i plugged my e mailer into my next door neighbours B T phone line it restored everything. however ive got another problem , my e mailer keeps randomly dialling for e mails and although it doesnt connect, im still getting billed for them on average about 200 a month so ive unplugged it from the phone line any advice?. bob
Jan 12, 2009 | Lands Phones
Hi, i have a belkin adsl2 modem with wireless- g router model f5d7632-4 and it was working fine but now i am getting no connection at all (no adsl light) checked all my wires/filters am stuck! i am on...
Check with your Network provider, and ask them if they can run a line check. No adsl can be problem with either the line or hardware.
But before that do check with your modem as well.
May 06, 2008 | Computers & Internet
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Feb 19, 2008 | Panasonic KX-TG6071M Cordless Phone
Yahoo Mail Logo
13 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
