Question about Waring Commercial WSB33 Immersion Blender, Light-Duty
Disassemble Need to know how to remove motor body case
Kitchenaid professional 6000 My mixer has a problem and I know it's in the planetary but cannot figure out how to open it. Any help would be appreciated. John
You need to remove the trim band (one screw at the back) that exposes 4 screw heads where the top cover joins the gear case. There are 4 screws from the top that retain the planetary assembly. I can't remember if you need to remove the motor to expose all of them. The motor is no big deal to remove.
Dec 08, 2016 | KitchenAid Food Mixers
Manuals breville
I do not know why you would which to remove the motor. I do not recommend it. The motor is connected to a transmission in the front of the mixer and was most likely pressed in to place by a machine into a baring in the back of the transmission. As far as I can tell the only user serviceable parts are in the back. Primarily the bushings and the back service cover.
To remove the windings you will need a puller. You might be able to find one at your local auto parts store, or one of the stores that specializes in tools such as Harbor Fright, Northern Tool or something like that. Once you remove the back cover you should see the armature, simply attache the puller to the shaft and extract it. If you are lucky you will be able to reinsert it in the opposite order. However, there is a chance that parts of the transmission will fall out of place making it difficult to reassemble.
I am pretty sure you can disassemble it, but putting it back together will be much more challenging.
If you are having trouble with a switch or the bushings I would call Kitchen Aid first. Help Contact Us KitchenAid
Aug 25, 2014 | KitchenAid Kitchen Aid K45SSWH Classic...
How to disassemble Dormeyer mixer, Model 4300, to get to the motor?
how do you remove the power cord on dormeyer model 4300 mixer
Dec 05, 2011 | Food Mixers
Sunbeam Mixmaster Heritage model Tilt mechanism failed. I got the bowl out and the beaters but can I fix the tilt mechanism?
Theory: Its a screw at the joint that is lose.
Problem: If I held mine upside down it released but wouldn't when right side up.
Partial solution (in progress): It took me an hour to disassemble the monster as I lost the "NUT" inside the motor - the nut is inside the motor case and attaches the lock-lever and a ground wire to the motor case. It makes some sense since it is a part that can strip out if it has to be tightened too many times by a gorilla - a nut is "easy" (relatively) to replace. Prevents you from having to buy a new one at least. Wish they would engineer this better.
Current status: I finally fished it out but have to put it back together now to prove my theory. You cant get into the motor case easily - but I found out that you don't have to get into the motor case if the screw is still semi-attached. I only had to undo the the base to get to the hinge. Then I could tighten the screw. I am an AMATURE - so at your won risk. They make these things so you need to send them in. This most likely seems to be what I have to do now.
Mar 15, 2011 | Sunbeam 2350 Heritage Series Mixer
Mixer head loose
Turn the mixer upside down and you'll see the screws up inside that hold the head to the base. You'll need a long screw driver.
May 15, 2010 | KitchenAid KL26M8XOB Stand Mixer
Dismantling a KSM150 - HELP !!!!! :)
Hi G_MERRY, it sounds like you’re well on your way, great! You’ve got the correct Parts List Manual from KA, 5KSM150PSEWH4.pdf (777.26 KB), and you’ve started to disassemble your mixer using the exploded view on pages 4 and 5 entitled “Case, Gearing And Planetary Unit”.
The first two screws (Illus. No. 25) you removed from the back only secure the trim strap and the trim strap is only for decoration. To get further ‘under the hood’, you will also need to remove the screw at the top of the End Cover (Illus. No. 24) as well as four larger screws (Illus. No. 30) on the bottom of the mixer head before you can separate the Gear Case Motor Housing (Illus. No. 1) from the Lower Gear Case (Illus. No. 18). You will need to remove the planetary ring (Illus. No. 35) to access the planetary ring and agitator shaft, too, if you are completely re-greasing your mixer, as that seems to be your intent.
To continue to disassemble your mixer you will need a regular and Phillips screwdriver, snap-ring pliers, a small drift pin punch and a small hammer. By using the exploded views in the Part List manual, you should be able to disassemble, inspect, identify and replace broken/worn parts, and reassemble your mixer. The Parts list manual doesn’t provide that step by step assembly instructions that would be nice, but just a general idea of how all the parts fit together.
Here are links to three excellent websites that detail the disassembling/reassembly of a KA mixer that will be really helpful in your circumstances.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, and feel comfortable doing it.
I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Feb 24, 2010 | KitchenAid KITCHEN AID 5 Quart Artisan...
My KitchenAide ultra mixer was a gift a year ago.
Hi BOSILKA_PASK, I am sorry to hear about your Kitchenaid mixer. Sadly the warranty for KA mixers is only for one year, so unfortunately you are out of luck as far as the warranty goes. But that is still no reason to panic. Since you did not provide the model number, I can only provide you a ‘generic’ solution, but this should point you in the right direction to fixing your mixer.
The inspection and troubleshooting of your mixer can be done quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person and feel adventurous; particularly now that your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, and select one of the files listed under Parts List and then check to verify that it matches your mixer model.
To disassemble your mixer you will need the following tools: a regular & Phillips screwdrivers, snap-ring pliers, a small drift pin punch and a small hammer. By using the exploded views in the Part List manual, you should be able to disassemble, inspect, identify, replace and reassemble your mixer.
Are you getting any sound when you push the start knob, or is there just dead silence?
If the motor runs but the mixer (agitator shaft) won't turn, then you've had a mechanical failure somewhere in the transmission housing or planetary gear assembly of your mixer, and by your description “and suddenly there was a rumbling/grinding in the motor area...” this evidence would lead me to believe that’s what where the problem lies. Turn to the pages titled: “Gear Case And Planetary Unit”, and remove the top of the mixer. If you have a classic mixer, you’ll see the transmission gears all covered in grease, which you will need to removed. Newer, larger models have a transmission cover over the gears that would have to be removed. As you remove the grease check for debris that could be suspended in it. Once you’ve removed all the grease inspect the gears to see if one (or more) is stripped or has broken teeth. Any damaged or broken gears will need to be removed and replaced.
If you have dead silence, then the mixer has a power issue, which means a couple of things could be conspiring to make your mixer not run. It may be a bad controller assembly (the speed knob) or it could be the motor, but either way it's something you can check yourself
Unfortunately the controller assembly is on a little PC board filled with electronics that was not meant to be 'home fixed' and my electronics expertise ends at being able to recognize a resistor from a capacitor. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not.
The next possibility would be with the motor itself, but electric motors are pretty simple mechanisms and generally don't fail.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
As far as parts go, here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links may be different than your KA model, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good Luck. I hope this helps. Howard, Burke, VA
Jan 05, 2010 | Food Mixers
Can't take apart the body on the mixer
from what i can see you need to remove the mixer head assemble which has a retainer that i havent been able to remove from mine as yet. need a special retainer pliers and you need to remove the rear stand asemble. i have not figured that out yet either. there are no screws under the logo plate. and the screws on the body only loosen the inner assembles, motor and such. this is a tough nut to crack. mine overheats kneading bread and i want to ad a fan.
Jan 04, 2009 | Hamilton Beach 63221 Stand Mixer
How can i disassemble my mixer to pull out a broken motor brush?
The mixer body is mostly a tube. You take the rear off, and the band with the name on it, you should see a 4 screws.
Nov 23, 2008 | KitchenAid K45SS Classic Stand Mixer
Motor runs, but beater doesn't turn
Ok, do you want to know how to disassemble? i just inherited a kitchenaid mixer from my brother and it had the exact symptoms. First, using a hammer and pin punch, drive out the pin that holds the beater mechanism. Pull off the mechanism and remove the chrome ring that is above it. You will see about 6 screws under there, remove them. Next remove the 2 screws at the opposite end of the bottom of the motor housing. Now carefully and evenly separate the motor housing. The motor will come off completely. Lay the motor aside being careful not to pull the wires too much. you might want to support it with a box or something to rest it on. Ok now you will see a bunch of grease on the gears. Put the grease in a paper cup as you will need it again. Wipe off the gear assembly and examine the teeth on the gear. chances are there is a spot where there is no teeth at all. Replace that part, put the grease bak on the gears and reassemble in the reverse order. I did mine in no time, just pay attention to what you are doing. The chrome ring is a little tricky to get it back on but it will stay if you keep trying. You might have to roll it against a hard surface to bend it inwards to make it fit tighter. Good luck and let me know if this helped you out!
May 20, 2006 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Waring Commercial WSB33 Immersion Blender, Light-Duty Logo
46 people viewed this question
Top Waring Food Mixers Experts
eyecam
Are you a Waring Food Mixer Expert? Answer questions, earn points and help others
