Question about Denon Audio Players & Recorders
Digital Coaxial not working on DVD player
I recently purchased a new DVD player. It only has HDMI and Digital Coaxial hookups. My Projector is on Component only (no HDMI). When I hook the DVD player to the Denon AVR 2007CI Receiver I tried to connect it to the Coax1 and Coax2 slot. Afterwards I assigned the Digital Input Assignment. I set the Component In Assignment to 1-RCA (DVD). I have set the Digital In Assign (3-1) to COAX1 for the DVD player. I still get no picture or sound. Any feedback would be greatly appreciated.
  • Denon Master
  • 5,056 Answers
There might be several problems. As the projector has component only connections and the DVD player none, then if the Receiver has component out, you can hook it up to that. If the receiver has HDMI inputs then you can connect the DVD player via the HDMI socket to it. The Coax sockets on the DVD player will be for sound. Number one should be connected to Digital coax 1 and assigned for it.
It's possible that the sound on the DVD player is switched off on the coax or has the wrong format selected. You will need to see the player's menu for this, so if you can't see the screen using the projector, connect a TV instead.
However if the receiver has no component out and no HDMI sockets you will have real problems connecting the DVD and using the projector with it. Though you should be able to hear the sound via the Denon.
Posted on May 29, 2017
3 Suggested Answers
  • 4234 Answers
SOURCE: Connecting Denon receiver to DVD player
Normally the optical inputs are disabled unless specifically turned on. I dono't know your specific model. I'll research the model and update this with more specifics.
Dan
Posted on Jun 17, 2008
  • 163 Answers
SOURCE: I have a Denon AVR2307
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Posted on Sep 10, 2010
Testimonial: "Yes,extremely helpful,I even managed to change the display from VCR1 to DVD2.Thanks again."
Cannot get new DVD player to work on Denon AVR-2307CI Receiver
TRY TO FIND DVD PLAYER RESOLUTION SAME TO THE RECEIVER....MAY BE IT WORKING..
Dec 28, 2013 | Denon AVR-2307Ci Receiver
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
Can a Sony DVP-NS710H work with a non-HDTV? I have an older TV model (2001) and need a new DVD player. I am looking at this Sony model and would like to purchase.
yes, you must have at your tv one of this plugs: Connector Type Sony DVP-NS710H 1 x Composite video output ( RCA phono ) - Rear , 1 x HDMI output ( 19 pin HDMI Type A ) - Rear , 1 x Component video output ( RCA phono x 3 ) - Rear , 1 x Audio line-out ( RCA phono x 2 ) - Rear , 1 x Digital audio output (coaxial) ( RCA phono ) - Rear on your tv the connector is input.
Feb 14, 2010 | Televison & Video
I recently purchased a new Samsung Blue Ray player. My previous Sony DVD player used the blue,green, red cords plugged into DVD imput, and I used Coaxial for sound. The Blue Ray only uses HDMI, which the...
Optical carries only 5.1 sound, no video. HDMI carries both video and sound. If your receiver doesn't have HDMI, check your TV for optical output. You can go BluRay to TV via HDMI, then TV to receiver via optical.
If you don't have optical out on your tv, you're going to need either a receiver with HDMI or a BluRay player with component output (blue, green, red).
Dec 06, 2009 | Sony STR-DG500 Receiver
No surround sound
Your not goingto achive true dobly sound you need a HDMI solution for this and hence you dvd player is rather old since it does not use HDMI if you want true HDMI sound you need to purchase a DVD with HDMI outputs to the TV
May 24, 2009 | Sansui 19 in. LCD TV
No sound output from coaxial port on philips dvdr 3475
try setting your av signal selector to auto. if that daes not work go to your av set click on digital input setuo an make sure you have got one of your coaxial slots asigned to dvr1. you will get better sound by using a coaxial or optical hookup compared to hdmi. i've tryed both. hope this helps you , if it don't email me back at mirbrts5@bellsouth.net. i also has a ppioneer av reciever, so i've been through the same trile and errors
May 02, 2009 | Philips DVDR3475/37 DVD Recorder
Denon DVD-1740 component video to RGB cable
YOU HAVE THE RIGHT CABLES FOR THIS INSTALL, GREEN, RED, BLUE FOR COMPENENT VIDEO AND RED AND WHITE FOR AUDIO UNLESS USING THE OPTIACL OR COAXIAL, FROM THE DVD PLAYER TO THE AMP OR TV.
ON THE FRONT OF THE DVD PLAYER IS A HDMI BUTTON PRESS THIS BUTTON UNTILL OFF IS DISPLAYED AND YOU SHOULD HAVE PICTURE
Jun 02, 2008 | Denon DVD-1740 DVD Player
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
Problems using HDMI
I've had a problem with the HDMI connector, had it replaced twice while my VPL-HS60 was under warranty. This connector seems very fragile, the first time I was not getting any signal from HDMI, so the repair shop ordered a new connector and replaced it, a couple of days after the it was not working again and found that they had to solder it back on the board. If you're not getting a signal from HDMI anymore that could be your problem.
Nov 29, 2007 | Sony VPL-HS51A / VPL-HS60 Multimedia...
63 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
