Question about Bose Acoustic Wave (32022) 5-Disc CD Changer
It seems the cd is playing the same section over and over. should imuse a cd cleaner to see if it clears up the problem
How do you get a cd to play when it goes from read to open?
if cleaning did not work .blow out with a little air . try other cds run your cleaner again .make sure to get a good cleaning cd .if cleaner cd seems to play after a little air blow let your cleaning cd play for about a half hour....
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
May 15, 2015 | Insignia Ns-es6112 2 Book Shelf Speakers...
How to my fix my CD player
Hi , Have you tried to clean the dust off of the laser lenz ? Some of those CD cleaners will work for you if you are not inclined to take the unit apart and clean it yourself. I think radio shack still sells CD cleaners ?
May 21, 2014 | Sony MHC-G100 Shelf System
No sound when I play my CD on my Micro Hi-Fi System
you have cd output sound before or never you get sound from cd if you never get sound from CD then u call Service Center
May 21, 2012 | Audio Players & Recorders
Place dvd in to drive will not play, come up inset disc and open drive
In most cases when the CD does not play it is possible that the optical head is a suspect.The drive can be jammed or there is some mechanical fault in the loading section. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jun 13, 2011 | Computers & Internet
The unit accepts and ejects a CD but will not play a CD - the radio functions seem to be fine.
DVD/CD players attract as much or more dust as the other electronics in our home. Be sure to dust with a microfiber cloth or electrostatic duster at least weekly, to keep your model running smoothly. The insides of our DVD/CD player can get dirty and dusty too. A great tool is a DVD/CD disc cleaner. This cleaner looks just like a disc with some extra little brushes on its surface. Some DVD/CD cleaner kits even come with supplies to clean and modify scratches on your discs.
Sep 09, 2010 | Sony CDX-4000X CD Player
Jensen flip out head unit volume knob doesn't work . the remote works fine but just that one problem.. and i cant seem to get the DVD to play.! ( bought it used..)
it needs to be serviced by jensen or some other repair facility. there is nothing you will be able to do to get the knob to work. if it plays cd's and not dvd's thats also an issue that you can't fix by yourself. if it doesn't play cd's or dvd's then you can TRY to run an optical cleaner through it. its a cd player cleaner kit you can get at most electronics stores.
Mar 17, 2010 | Jensen's VM9312 Car DVD Player
WHARFEDALE DVD 750 - N0 SOUND ON PLAYBACK
Clean the player with a disc cleaner with a drop of the solvent on each brush on the surface of cleaner CD and play it in the player. If sound quality improves then keep running the cleaner disc till its sound becomes ok. If this does not work then then there is problem on the output amplifier circuit which can be checked out by a professional technician.........sodeep
Jul 30, 2009 | Televison & Video
GAME FROZE UP AND NOW NO GAMES OR MOVIES PLAY HRD DR SEEMS OK
try a cd cleaner....if the hard drive works then the problem is probly a dirty lens...ps2 did the same thing and i used a cd cleaner...a cd with a little brush on it fixed the problem
May 27, 2009 | Sony PlayStation® 3 (60 GB) Console
Cd player not working
first try play Lens Cleaner CD, if you are lucky ,it's done!!
Sep 07, 2007 | Aiwa CSD-ED27 Boombox
Screen displays "Error data" when trying to play a DVD
My understanding is that the DVD player uses a different lens to the CD player. So the DVD lens might need cleaning. A CD lens cleaner would not correct the DVD side.
Oct 04, 2017 | GoVideo DP8240 Portable DVD Player with...
Bose Acoustic Wave  (32022) 5-Disc CD Changer Logo
23 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
