Question about Garden
I need a part no. for the bar studs that go in the chain saw oil tank.
    Guru:
  • 145 Answers
Stihl? what manufacturer?
Posted on Apr 13, 2014
3 Suggested Answers
  • 211 Answers
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
  • 110 Answers
SOURCE: i have poulan micro xxv chain not being oil when
wow thats an oldie, That saw uses a diaphragm pump located just above and in front of the clutch drum. Its going tobe hard to find one if its bad, Try cleaning out the oiler hole in the bar first, Then try running the saw without the bar and chain on and see if it pumps.Also check the oil pickup tube in the tank, It has a small screen on the end of it thats prone to sawdust clogging it. If it still does not oil then I suggest you locate the gasket and diaphragm for the pump before you take it apart. Remember to clean everything before reassembling,, Good luck
Posted on Dec 19, 2009
Oiler mechanism to bar of ryobi 40cc 10532 18 inch
I get asked this question a lot , im gonna have to make a video on this subject someday .
but here:
1st ck your oil viscosity/SAE it should be 30 and say bar/chain oil
next dump out entire oil tank and wash out with kerosene (you'd be surprised what I seen come out)
then remove bar and chain , locate oil outlet it's in body of saw near adjustment screw , use a small can of air to blow in this port softly , use a touch more of kero to clean this all out , refill tank with proper oil !!!! and run saw (no need to put bar/chain back on yet ) might take several minutes but oil should start to flow out hole !! stop saw and reinstall bar/chain then run again .. fixed !! if no oil comes out ever your oil pump is gonna need some fixing
for a low cost oil I use filtered used motor oil cut down with a dab of kerosene
Jul 07, 2014 | Ryobi Factory Reconditioned 18" 40cc...
What kind of oil or oil mixture do I need to use my Remington 2.0 HP 14" Electric Chain Saw?
Hi brown9148..
The only oil you need for your electric chain saw is "Bar and Chain" oil...specially formulated oil sold at Loews,HomeDepot,Ace Hardware, Auto parts stores,etc...
You use this oil to lubricate the chain and bar of your chainsaw when you are using it.
It will go into the oil tank and auto feed to the chain and bar...but keep a check on the oil level to make sure it is being used.
Refill tank when needed.
Please take time to rate me
Sep 24, 2011 | Remington Electric Chain Saw
No oil flows to chain
Depending on your knowledge and experience -
1. Find your manual and check on maintenance routines.
2. If no manual avail - clean your saw and your bar.
Bar - oil holes clear, groove clean etc
Saw - locate where the oil pumps out - ensure any guides, holes etc are clean.
3. If saw gas manual oil pump adjustment screw -advance the flow
4 Drain the oil tank checking for dirt etc and if necessary clean tank with a little of your fuel.
5.Refill oil tank AFTER it is clean and dry.
6. Replace bar/chain etc and test if flow is better
If still no good you may need to repair/replace oil pump -not that hard to do but if in doubt take it to a reputable dealer.
May 20, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
On my 16in craftsman saw the oiler quit working
some times this can be something easy sometimes not just follow a few simple steps:
Have you replaced the bar and chain recently?
#1 Remove bar and chain and blow out all sawdust esp around your bar studs dont get to close with the air as you can sometimes pop seals...
Start your saw see if oil comes out around bar studs if so the oil holes in your cutter bar may be blocked...
#2 If that doesnt work remove your oil filler cap and use a piece of wire with a bend on the end to remove your oil filter remove it from oil line and clean in fuel and blow out with compressed air replace on hose and place back into tank and try start chain saw again...
if that doesnt work then take it in to small engine repair shop as the pump may be blocked or unservicable and need replacing
Hope this Helps
Kind regards
Brad
Jan 02, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Where is the oil discharge hole on silver eagle 250-14?
If you take the bolts off the studs that the bar sits over, the ones you loosen to tighten the chain, you can then take off the housing over the chain sprocket. Loosen the chain adjusting screw, Pull the bar and chain off of the saw. The oil discharge hole is behind a plate on the back side of the bar about where the studs for the bar are. There is a small hole in the bar that the oil is injected into. This needs to be kept clean for the chain oiler to work properly.
Dec 02, 2009 | Hardware & Accessories
I have a McColloch 16 in chain saw MS 1635 AV.
remove side cover,bar & chain.above bar mounting studs find a oblong channel that lines up w/ the small holes in the bar.clean everything,sawdust gets packed in the holes.if it leaks oil out the bottom,you need to replace the oil feed line fom the tank.
Sep 21, 2009 | McCulloch Garden
Stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
Apr 14, 2009 | Garden
Chainsaw bar studs
empty out oil tank . you have to tap old stud out through oil tank.replace same way can be tricky but you should be able to get back in
Sep 28, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
