Question about Fujitsu LifeBook Computers & Internet
Not charging i got a fujitsu lifebook for christmas. and it keeps saying plugged in but not charging it works if i keep it plugged in but if i take the charger out if shuts down straight away i have tried removing the battery and still nothing. it just says " 0% avaiable (plugged in, not charging) " its a brand new laptop not second hand. and suggestions?
    Top Expert:
  • Fujitsu Master
  • 21,522 Answers
The battery is not working as it should. Either, replace the whole lot under warranty or leave the battery on charge until it will accept a charge.
Posted on Dec 28, 2013
danasaur
  • 77 Answers
SOURCE: fujitsu lifebook t4020 battery connnection/charge problem
So, "all three batteries" suddenly get this zero charge. That is VERY "incriminating". Almost 100% certain you have either a connector problem (most likely) or a power regulator circuit failure (less likely). Get a flashlight and magnifying glass, and look deep into the battery compartment at the connector. Almost certain there is some bent pin or other irregularity there. If so, be careful straightening it out. Disconnect PSU and still, be careful not to cross-connect two connectors. Even though PSU and battery are removed, there is still a small battery inside that keeps that circuit alive for clock and PRAM settings... don't want to short that circuit out. Work only on one pin/strip at a time. Hope this is the problem. Because if it is the regulator circuit -that is a motherboard matter. Major repair, usually not worth the cost. But I really think that scenario is unlikely, unless you caused some serious short recently. Let me know what you see inside.
Posted on Feb 11, 2008
asish_shrm
  • 121 Answers
SOURCE: battery and or charger
Hi you have mentioned
"Sometimes if I jiggle the AC adapter connection to the laptop when the battery icon starts flashing I can get it to continue working."
Looks like you have a lose jack on your notebook or the adapter itself....try to shake the connections when fitted to the notebook and check weather its the adapter or the note book jack....
If you dont have experience opening your notebook and soldering or soldering your adaptor end i suggest you take it to repair center
keep me posted
Cheers!
Posted on Nov 14, 2008
SOURCE: How to remove hard drive from Fujitsu Lifebook N3010 PC laptop
Remove the DVD drive, and then there are 4 outer screws holding the hard drive chassis in place. There are also 4 inner screws that hold the hard drive to the removable hard drive chassis, those do not have to be removed to remove the hard drive from the computer. Carefully remove the screws so they don't fall into the holes on the sides of the screws, and then slide the hard drive out of the pin slots.
Posted on Nov 15, 2008
perpetually
  • 360 Answers
SOURCE: HP Pavilion DV5000 battery charging problem
Sounds like you need to calibrate the battery, it is supposed to be done every 3 months. If it is not done, your battery will display the same symptoms are you describe. Yes, this holds true for adding a new battery also.
Here is HP's instructions on how to do it. You want to scroll down to the section called "Calibrate the notebook PC battery".
http://h20239.www2.hp.com/techcenter/battery/Battery_max.htm
Posted on Feb 27, 2010
Testimonial: "Very helpful but problem remains"
shibuda
  • 1812 Answers
SOURCE: MY fujitsu lifebook ah530 keeps
Your display setting does not match.You need to setting the display right way.Or you uninstall and install the VGA (graphics)driver again,and simply restart the PC.
Hope it will solve your problem .
Posted on Dec 17, 2010
My fujitsu wont work without its charger and when the charger is plugged in it wont actually charge the battery itself.
Probably your battery is dead because if there would have been any problem with your charger port, you cant be able to use it on plugged mode. Buy a new battery ASAP.
Dec 29, 2014 | Fujitsu LifeBook AH532 Notebook
Lifebook s7110
Put the start op disc in the drive restart your laptop and follow he prompts
Sep 30, 2013 | Fujitsu Siemens LifeBook® S7110 PC...
Fujitsu lifebook blinking battery led, bad ac adapter?
i would try purchasing a universal laptop charger on ebay and see if it works. they are under 25 bux. worse case scenario you will have a backup ac adapter. be careful plugging in other ac adapters because the polarity could be wrong or it could have to much amps
Jul 11, 2010 | Fujitsu LifeBook A6025 Notebook
I am now on my 2nd port replicator for lifebook e4010 ... i have 3 fujitsu ac chargers which charge the laptop but not the replicator ??? why ??? pls help ...
No easy answer to this. The standard port replicators that are used by the e4010 lifebooks seem to be incredibly unreliable. I worked with these laptops for a few years and we were forever replacing the port replicators for users.
Aug 26, 2009 | Fujitsu Siemens LifeBook E4010 Notebook
Fujitsu siemens notebook s6120 laptop switching itself off
the processor fan might not be working due to which the laptop gets heated up and switches off. if u dont replace it u might end up burning the processor.
May 17, 2009 | Fujitsu Siemens LIFEBOOK S-6120 PC...
Fujitsu LIFEBOOK C1020 power problem
or a bfoken powr jack.I replaced mine recently for £4.00 and took approx 2 hours.
Jun 16, 2008 | Fujitsu Lifebook C1020 Notebook
Power on my Fujitsu Seimans Lifebook B-2154
Does the laptop get very warm? It may be overheating.
May 06, 2008 | Fujitsu LifeBook B2154 Notebook
Computers & Internet Logo
103 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
