Question about Refrigerators
We own a Continental Ice Maker Model CE IM65151 and recently the impeller on the pump went out We took it to a local appliance repair shop for repair and were told they did not have the time to locate the part for repair We are looking for the pump assembly Your attention to this request would be greatly appreciated
BIKER T
  • 909 Answers
SOURCE: Clicking noise
THE FRONT PANEL IS DEFECTIVE. HAVE REPLACED TWO IN LAST MONTH. JUST TAKE NOTE OF MODEL WITH DEALER AS CERTAIN MODELS HAVE TO HAVE THE POWER BOARD REPLACED AS WELL.
Posted on Jul 20, 2007
  • 55 Answers
SOURCE: Frigidaire side by side MRS22WNGD0 stopped dispensing ice and water
Even you find the problem you should need special equipment.Better call a technician.This link may help you:
http://www.appliance-parts-warehouse.com/frigidaire-parts/Frigidaire-Refrigerator-Parts/Frigidaire-Parts-MRS22WNGD0.cfm
Posted on Nov 18, 2007
mikedurland
  • 481 Answers
SOURCE: Maytag Refrigerator Ice Maker
  • first make sure the metal arm to the right of it is lowered, this turns the icemaker on.
  • then you can check the water supply to make sure it is turned on, sometimes when houses are vacant they turn the water off as a precaution. the valve may be behind the refrigerator or under the sink in the kitchen.
  • then...
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 04, 2008
  • 10865 Answers
SOURCE: Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 30, 2009
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
Continential ice machine compressor not working
www.continentalelectric.us/appliances/commercial/PS78121-detail
Check charge first. Chec compressor for shorts, opens,grounds.
Match and replace compressor , if necessary . Obtained from any air conditioner /refrigaration parts store.
Jul 05, 2014 | Continental PortableCE-IM65151 Ice Maker...
Always say add water
We have the same problem...if you beat on the sides and the top then turn it off and on, sometimes that works for a while, but I'm looking for a better solution.
Jun 27, 2011 | Continental PortableCE-IM65151 Ice Maker...
I have a new Continental ice maker - bought 2 years ago, but was plugged in for first time yesterday. Motor won't run. Added water to proper level. Plugged in. Set cube size. In one minute red water...
Check the water pump, I had the same problem, the water pump was bad but unable to find replacement parts at this point. The pump is a ZB-1200 made by Zhongboa Motor Factory,
Good Luck
May 09, 2011 | Continental PortableCE-IM65151 Ice Maker...
Electrical hot smell from fan area, not has quit
Hello, electrical hot smell from the fan area means you have a burnt fan which inturn affected other parts of the ice maker. That is the reason why the ice maker fails to start up when you plug it.
You can only fix it by replacing the fan and probably other affected areas by troubleshooting it.
There is nothing like reset.
Take care
Jul 12, 2010 | Continental PortableCE-IM65151 Ice Maker...
Continental electric ice maker CE-IE65151. The
Look at the far ends of the shovel near the attachment hinges. There should be a little plastic tab near the pin on each end and on each hinge. They commonly break off. This is made by e_wave and their model is MCIM30TS. Order parts from Repair Clinic.com
Jul 14, 2009 | Continental PortableCE-IM65151 Ice Maker...
Need rubber seal for drain
It's the same unit as MagicChef MCIM30TS. Get parts at RepairClinic.com or http://www.mcappliance.com/partorder.aspx
Jul 08, 2009 | Continental PortableCE-IM65151 Ice Maker...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
