Question about Whirlpool Washing Machines
Spin cycle suddenly stopped. - Whirlpool Washing Machines
    Problem Solver:
  • 20 Answers
I need more info about the machine. Does it make any noise when the start button is pressed, if you can hear the motor turning then more than likely your belt is either after slipping off the drum or breaking. you should be able to access the belt either by the back of the macine or the top to see if the belt is broke or just after slipping. Another problem it could be is that the capacitor in your machine could have blown. To test this you press start, open the door of the machine, spin the drum by hand and close the door before the drum comes to a stop, if the drum continues to rotate after you close the door then you know it is the capacitor that is blown, this needs to be replaced either by an electrician or a specialist as it is possibe to connect the capacitor wrong and the result would be the capacitor exploding damaging your hand. Always plug out the machine before opening the top or back of the machine....
Posted on Jan 03, 2014
My panosonic washing machine suddenly stop spinning
If there is no power to the motor at the SPIN cycle it can be related to fault in the program cycle in the controller board. Reset and use a different program to confirm this, power off unit for a while and check if the fault clears before you can suspect the controller.
Dec 11, 2012 | Washing Machines
Spin cycle does not engage
UPLOADING OR FRONT LOADING WASHER..........CHECK ITS BALANCE LEVELS.
Feb 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 25, 2011 | Washing Machines
Slow spin cycle, clothes still very damp
ahhhh but it is
needs a new belt
it is strectched
Oct 01, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Exessive noise when in spin cycle?
Could be dirty bearings. As long as it is still spinning, it is nothing to worry about. If it suddenly stops one day, it is probably frozen bearings or the brushes in the motor.
Jun 23, 2009 | Maytag Dependable Clean Top Load Washer,...
Spins so harder washer walks across the room. the washer is level. the load is balanced. is it the tub inside the washer that is not level
Engage your lid switch so that washer will spin in spin cycle and watch it spin. At end of cycle when washer shuts down the tub should come to a fairly sudden stop if it doesn't then you need to have the brake worked on. If it does post your model number and i'll advise further.
Mar 11, 2009 | Roper RAS8445KQ Top Load Washer
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Spin cycle quit working
you will need a lid switch, or a motor coupler
Jan 08, 2009 | Washing Machines
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal De
