Question about AEM 2000 Chevy S10 Pickup - 2.2L 4 cyl. engine - Brute Force Air Intakes
2000 s10 2.2 liter # 4 misfire
Misses on # 4 cylinder
Miss fire
Hi Richard, I'm glad to help! Richard, there's a lot of things that can cause one certain cylinder to misfire. I would first: "Replace the Spark Plug and Spark Plug Wire for number 4 and see if the misfire goes away. If it doesn't then you need to do a "Compression Test" for cylinder # 4 and compare it to another cylinder and if its more then 25 Psi difference then you need to do a "Cylinder Leak Down Test" to see where you are loosing the compression. If the compression is good and you have new plug and wire and it still misfires. Then you'll need to check and make sure you have good spark coming from the coil. If you have good spark coming from the coil. Then you'll need to check and make sure the # 4 Injector is firing. Hope this helps and have an awesome day Richard.
Apr 07, 2014 | 2000 Dodge Grand Caravan
3rd cylinder is misfiring. how to fix?
For engine misfiring problem check the help links mentioned below. Click the link below to go through the troubleshooting procedure :---- Engine misses and truck jumps? Hard to down shift? Issue with high gear only? http://technoanswers.blogspot.in/2012/02/engine-miss-and-truck-jumps-hard-to.html
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Engine Misfire codes for car?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Engine Misfire codes?
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
This will help.
Thanks.
Mar 07, 2012 | 2006 Chrysler Sebring
Car miss's
For engine misfiring problem check the help links mentioned below.Click the link below to go through the troubleshooting procedure :---- Engine misses and truck jumps? Hard to down shift? Issue with high gear only? http://technoanswers.blogspot.in/2012/02/engine-miss-and-truck-jumps-hard-to.html-----------Bad miss at idle? http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
-----------While stop engine idles like cylinder missing? http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
------------Engine Misfire codes for car?
Oil on spark plugs and car misfires? http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
----------This will help.Thanks.
Feb 17, 2012 | 1993 Nissan Maxima
My 1996 tahoe is giving me cylinder 2 misfire And runs ruff idle
Bad miss at idle?
This will help.
Thanks.
Feb 14, 2012 | 1996 Chevrolet Tahoe
Multiple cylinder misfire
Bad miss at idle?
This will help.
Thanks.
Feb 09, 2012 | 2000 Isuzu Rodeo
P0303 cylinder misfire
For engine misfiring problem check the help links mentioned below. Click the link below to go through the troubleshooting procedure :---- OBD-II Trouble Code P0300? http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
---------Car misfires and error code P0306 and P0303 is shown? http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Bad miss at idle?
This will help.
Thanks.
Jan 23, 2012 | 1999 Subaru Legacy
1996 3800 non turbo number one cylinder misfire code P0301
-------- Engine misses and truck jumps? Hard to down shift? Issue with high gear only? http://technoanswers.blogspot.in/2012/02/engine-miss-and-truck-jumps-hard-to.html
Bad miss at idle?
This will help.
Thanks.
Jan 22, 2012 | 1996 Buick Riviera
Where is coil no.5 was told cylinder 5 was misfiring bought coil but not sure which is no. 5
5.4 liter?
Drivers front cylinder
1-2-3-4 on the passenger side, 5-6-7-8 on the drivers side
4.6?
drivers front cylinder
4.2?
driver middle cylinder
1-2-3 on the passenger side 4-5-6 on the drivers side
Nov 07, 2010 | 2000 Ford Econoline
Cylinder 6 misfire for 2000 cadillac deville 4.6 liter engine
check out this tool. Brand new on the market and it quickly can diagnose a misfire from the plug or the coil pack. Here's their website
Sep 03, 2009 | 2000 Cadillac DeVille
1997 Aerostar 4 liter engine has miss on several cylinders. New wires and plugs. Miss is intermintent. Usually worse under load. At times van runs fine.
check for vacume leaks on intake and other vacume hoses. random misfire is also usually a clogged fuel filter or pressure regulator. could also be a cam or knock sensor. are their any trouble codes.
Aug 16, 2009 | 1997 Ford Aerostar Extended
AEM 2000 Chevy S10 Pickup - 2.2L 4 cyl. engine - Brute Force Air Intakes Logo
24 people viewed this question
Top AEM Tools & Hardware - Others Experts
D. E. Hev
Tom
Are you an AEM Tool and Hardware - Other Expert? Answer questions, earn points and help others
