Question about Refrigerators
Scotsman cm250ae-1c making very wet ice
Just replaced the pump in a scotsman cm250ae-1c . Now making very very wet ice, and looks to be having difficulty dropping ice into reservoir once it is made. What could be the problem?
  • 451 Answers
It might be a dirty or damaged ice tray. When in the harvest mode the hot gas will be directed through the tray untill the cubes fall tripping the reset to start the freezing cycle again. If the cubes are sticking because of rust or scale buildup the cubes get "overmelted" causing the "wet cubes".CAREFULLY clean the ice tray . Use vinegar or ice machine cleaner do not use any cleaning pads steel wool or sand paper as this will ruin ice tray. Also make sure icemaker is level both ways. Hope this helps.
Posted on Jan 01, 2014
TheMobilian
  • 8220 Answers
SOURCE: i am looking for schematics or online manual scotsman ice machine
page 13
Posted on Mar 01, 2009
  • 102 Answers
SOURCE: Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Posted on Aug 06, 2009
  • 3074 Answers
SOURCE: Scotsman has become very slow in making ice
I would try cleaning the unit, plus if there is a inline water filter I would replace it
Posted on Jul 23, 2010
Ironfist109
  • 3018 Answers
SOURCE: the model for Scotsman ice maker is AFE400A-1B and
If your ice maker has stopped producing ice completely first unplug the ice maker and then check it in this order.
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:If your ice maker has a small red plastic lever, lower it to lower the wire.If there's no plastic lever, simply lower the wire.In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on Mar 15, 2011
imufo2
  • 3773 Answers
SOURCE: i have a "scotsman cm 500. Tha evaporator freezes
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Oct 01, 2011
Scotsman cm250ae nice cubes are made no harvest. make up water not working.
no harvest? Or on harvest? Nice cubes made? Please elaborate fault you want to find out about
Oct 01, 2014 | Kitchen Appliances - Others
I have a SCOTSMAN ICE MAKER MODEL NUMBER CM250AE-1E and the water coming into the machine never stops. It fills the tray until the water runs out the drain in the back of the machine.
I ran a service call on this model today with the same exact problem. I diagnosed it with a bad fill valve. The valve is not closing all the way and therefore lets water in all the time. With yours, the problem could be a bad timer or a bad microswitch or a bad valve. Hard to tell without looking.
Now to find the replacement valve for this thing...
Oct 02, 2012 | Scotsman Ice Maker With Bin Cube Style...
Do i need to oil the spray pump on my DCe 33 Scotsman ice machine
You can spray lubricant of a silicon base into the rotating part, but you will need to replace the pump.
Apr 27, 2012 | Scotsman DCE33PA1BC 15in Built-in...
Why does my scotsman ice machine, model cm250ae-1e, freeze over on ice cube grid?
check ice thickness thermistor if its not working properly timer will never start advancing
Jan 19, 2011 | Scotsman CSW45 15" Ice Maker with 26 lb....
Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Jun 28, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman CM250AE Ice Machine tech help
Check the bridge size adjustment at the top of the metal grid that the ice forms on. This determines the size of the cubes. Whenever you make a repair on the water system, especially on an older unit. make sure the unit is clean. A little bit of calcium deposits (or that other nasty looking stuff) getting into the passage ways will make it run erratically, and can drive you nuts.
Nov 06, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
