Question about Spyder 88-98 Chevy C/K 1500/2500/3500 Full-Sz/Silverado/Tahoe/Suburban
I recently put it 4x6 speakers in the extended cab area, now my tail lights are out. I checked all of my connections and could not find a problem there. So is there anything else I could have done? I replaced the fuses they kept blowing. Checked underneath the hood in that fuse panel none of them had blown. The fuse that keeps blowing is labeled park lps
2004 Toyota Highlander, have no tail-lights, all other lights work ?
With the car jacked up and on safety stands, follow the wiring harness from the taillights to the front of the car. The wire is probably pinched, burned or shorted somewhere along the way. Did you have any work done on the bottom chassis area recently? Does sound like a pinched wire.
Sep 12, 2014 | 2004 Toyota Highlander
Smelling fuel fumes inside cab
Possible fuel line leaking or check around the area of the carb for leaks. Check all line connections Check gas tank all over. I doesn't need much of a leak to smell. Some times leaks develope at the tank top where the fuel pump is located as well.Please don't use a match for light to check this out
Mar 03, 2014 | 2000 GMC Sonoma Extended Cab
Colorado: how to remove tail light lens cover? the two screw's (tailgate area), then... Thanks, GD
There are two metal pins in the taillight housing that push into some plastic clips on the outboard side of the truck bed. Gently place a flat blade screwdriver between the bed and the plastic housing and pry rearward to get the clips to release. You may want to put a rag over the end of the screwdriver to help avoid scratching the paint on the bed. To reinstall, line up the pins with the clips and "thump" the housing assembly wih your hand.
Jan 25, 2011 | 2007 Chevrolet Colorado (Extended Cab) New...
2002 GMC SONOMA 4X4- 4.3 Front marker/parking lights dont light up, bulbs are fine. tail lights- when turn signal is on the tail light blinks with tail light and backup light and license plate light all at...
Do you know how to do automotive electrical testing ? Looking at a wiring diagram an check power an grounds for the lights that are not working . Voltage drop testing !
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
Learning how to test properly is the way we fix automotive electrical problems .
How to Use Multimeter to Troubleshoot Common Problems
Do you know what a wiring diagram is ? You need these to find testing points in a electrical circuits . Free wiring diagrams here . http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine size. Under system click on lighting ,then under subsystem click on parking lamps . Then click the search button ,then the blue link.
Electric Testing Techniques You Need to Know .
As far as your door goes take the door panel off an check componets inside , window componets for being tight . with out hearing an looking at the door would be guessing . take to a repair shop .
Jun 25, 2017 | 2002 GMC Sonoma Extended Cab
My 2001 toyota tacoma prerunner is burning the 10a tail light fuse immediately after i put it in
Then you have a short circuit to ground in this tail lamp wiring which you need to find to stop the fuse burning out. Finding a shorted circuit may not be easy but you can try this, check your trailer electrical connection (if you have one) as these do cause this kind of issue. Faulty wiring to this connector, damage or lost screws can all result in this issue. You may need to follow the rear wiring harness from the cab back to locate anywhere that the wiring has been crushed or rubbed through insulation has occoured and the copper conductor is now touching the body or a ground wire. Check the trailer connector, rear wiring behind the lamp assemblies and the harness where it runs in the chassis. If you have recently has any work done under the vehicle, check this area too..
Nov 09, 2009 | 2001 Toyota Tacoma
Need speaker size in a 1998 s10 reg cab
Dash has 4x6 doors are and over size 6 inch but most newer speakers will fit in the factory adapter. I don't know what the rear speakers are. You can check on crutchfield.com, usually very accurate.
Jun 18, 2009 | 1998 Chevrolet S-10 Pickup
I just bought a 07 chevy colorado a few months ago and now none of my brake lights work. what could it be?
after u check all the bulb try to check the fuses if its ok change the brake light switch which is located front of the brake pedal
Apr 07, 2009 | 2007 Chevrolet Colorado (Extended Cab) New...
Left turn signal flashing quickly at night.
This is common, remove the left tail light, find the ground wire, (uasualy white).make sure it is getting a good connection in the tail light plug, and on the frame.
Mar 17, 2009 | 2003 GMC Sonoma Extended Cab
Need to replace my speakers
if this is a ext cab the doors are 4x6, and front are 6 1/2
Jan 07, 2009 | 2002 Chevrolet Silverado
03 sonoms sls extend cab 4x4 speaker sizes
the dash speakers are 4x6 and the 6 1/2 in the doors
Oct 17, 2008 | 2003 GMC Sonoma Extended Cab
Spyder 88-98 Chevy C/K 1500/2500/3500 Full-Sz/Silverado/Tahoe/Suburban Logo
71 people viewed this question
Top Spyder Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Spyder Wine and Spirit Expert? Answer questions, earn points and help others
