Question about Cuisinart DLC-2007 7 Cups Food Processor
MOTOR DOESN'T SPIN ON CUISINART FOOD PROCESSOR. POWER INDICATOR LIGHTS UP
My unit turns on, power indicator lights up, but the motor doesn't turn.
5 Suggested Answers
  • 5 Answers
SOURCE: cuisinart food processor
I went through the same thing...as it turns out, everything was locked into place but I had the handle in the back rather than the front where the sensor is. Good luck. I hope that helps you.
Posted on Feb 06, 2008
SOURCE: Cuisinart Prep 11 Plus Food Processor - Help!
Not sure if you found the solution by now but we recently had a similar issue. Make sure the bowl is put on such that the handle is facing the front of the processor. There is a little black button that gets depressed when the lid gets put on. We had to get the thing to work one night and spent hours trying to get the processor on and then trying to get a blender to work before finding the problem.
Hope this helps.
Posted on Nov 28, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: CUISINART FOOD PROCESSOR MP14 WON'T TURN ON ..NOT EVEN THE RED LI
You should not have taken it apart - that unit has a fantastic warranty. Call Cuisinart and get it repaired - don't even hint that you took it apart, or your warranty is void.
jo82 - here is how to test your motor to be sure -
Remove the workbowl completely, plug the base into the wall outlet, turn the machine on, take a pen and press in the little black/dark gray button on top of the base. If you hear spinning, then the motor is fine.
If the motor is fine, put the work bowl back in place with handle facing fromt of machine, lid lined up with bowl, and pusher sleeve with metal element lined up with front of machine.
If the motor test failed, call Cuisinart and get the unit repaired.
-Tha Mp3 Doctor
Posted on Feb 27, 2009
  • 4088 Answers
SOURCE: When I turn on my cuisinart food processor, the
Either locked motor or bad brushes in the motor.
Posted on Jul 17, 2009
Lights come on, motor turns briefly, then stops
Check that blade can turn easily with unit unplugged. Fix that first then replace the fuse.
Dec 15, 2012 | Cuisinart BFP-703 SmartPower Duet Food...
-Tha Mp3 Doctor
Feb 17, 2009 | Cuisinart Limited Edition Metal MP14 Food...
Cuisinart Food Processor Custom 14 turned off
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Dec 21, 2008 | Cuisinart DFP-14BC Custom Food Processor
Motor won't turn on
You can test the motor by plugging the food processor in, pressing the on switch and using a pen to press the dark grey or black button on top of the base of the food processor. As long as it spins, the motor is definitely good. Next, unplug the food processor. For the food processor to work, you need to have the work bowl, lid, and pusher sleeve all inserted - if one part of the work bowl is not attached, then the food processor will not spin the blade. Once all three pieces have been inserted, plug it in and turn it on. If the blade is still not spinning, then there is a problem with the element that runs from the back of the pusher sleeve down through the work bowl that triggers the motor button. In that event, you can go to Cuisinart's website and order a new bowl, lid, and/or pusher sleeve - if you see any obvious damage to one part, you can order just that one part. If it is not apparent which part is damaged, order the whole work bowl. Make sure you enter your exact model# at Cuisinart's website, because a DLC-7 is not the same as a DLC-7E or 7P, for instance. The work bowl parts are expensive, so I would just write down the part numbers from Cuisinart's website and find them cheaper elsewhere. There is also a video on the website that shows you how to use the food processors - the first part of the video describes work bowl assembly. Once you get this food processor working, it is going to last forever. Have fun!
-Tha Mp3 Doctor
Nov 27, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
My food processor turn on button won't work.
-Tha Mp3 Doctor
Nov 25, 2008 | Cuisinart DLC-5 Food Processor
My brand new Cuisinart 14 cup food processor won't turn on. All the components are locked in place and it's plugged in. Help
-Tha Mp3 Doctor
Nov 23, 2008 | Cuisinart DLC-5 Food Processor
The cuisinart food processor doesn't work.
-Tha Mp3 Doctor
Aug 26, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart MP14 Will Not Turn On
If it no longer spins, the motor has a problem. (This one has a 20-year motor warranty)
-Tha Mp3 Doctor
Oct 30, 2007 | Cuisinart Limited Edition Metal MP14 Food...
Cuisinart DLC-2007 7 Cups Food Processor Logo
60 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Greg Cann
Greg Cann
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
