Question about Xerox DocuColor 12 Color Copier
Docucolor 12 i was cleaning the machine, cleaned the transfer belt and all fuser rolls . It was printing but with haze or ghosty lines. I put it all back together , now the machine wont print anything. I am copying a full color page and when it copies the paper comes out empty without image. Doesnt matter what color of B/W it will not print any image (copy). I use it as a copy machine
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Check scanner unit which hit the opc drum, may be hide by something
Posted on Dec 28, 2013
4 Suggested Answers
SOURCE: Docucolor 12 spills fuser oil
The most common cause, the oil pipe is blocked. black rubber hose. Use a cable tie or some such to clear out any paper dust and congealed oil. Should be no need to repalce fuser parts.
Posted on Mar 21, 2008
SOURCE: xerox docucolor 12 copy/print printing all black
If you moved the printer, make sure the conections from the printer to the Fiery are secure. If loose the prints will be black but when copying will be fine.
Posted on Dec 22, 2008
  • 6 Answers
SOURCE: want to copy images from notebook paper without blue lines apparent
yes, you are loking for border erase function. when you find it then look for what looks like two peices of paper side by side, you will then possible be allowed to adust the sixe of the erased area
Posted on May 13, 2009
The prints have/Lines streaks in the image on all colors what needs to be replaced?
Enter in the service mode and tested in part every colors.Press Utility key - Meter count - Details - Stop 0 0 Stop 0 1 select test pattern gradation test select the colors and press Start key(the test is make A3 paper).If the test is OK verify the transfer belt unit and the transfer roller unit.If the lines appaire on the surface the transfer belt clean the belt cleaning blade and the cleaning brush used a vacuum cleaner.Clean used a special long tools under every image unit LED lines.
Feb 01, 2013 | Minolta C250 Color Copier
My xerox dc12 is getting a black line through when i have printed over 5 copies what do i need to do
check that stell rod beside of fuser unit has any black toner just clean that toner
Jul 09, 2010 | Xerox DocuColor 12 Printer
Blue,black thick line and print is not so glossy
I work on the doc 12 every day. first look at fuser web once out look at the metal roller in side the web slot make sure there is no build up..the large gray fuser rolls should be covered with oil coatting so make sure the oil is pumping.
Jun 30, 2009 | Xerox DocuColor 12 Printer
Black vertical lines on laserjet 4650 print out
99% of the time, this is the imaging drum or fuser.
Pull the imaging unit (same as imaging drum - they are interchangable) and examine the greenish glass tube. Does it have black streaks along the same lines that are on the paper? If so, then it needs cleaning / replacing. Don't touch the glass!! Use Q-tips and rubbing alcohol to gently clean the lines off. Air dry and replace into the machine.
If the imaging unit doesn't have lines, then it's the fuser. This can be replaced as part of a maintenance kit. If you've been using the printer regularly for more than 9-12 months, It's probably time for a Maintenance Kit for the machine anyway, which includes a fuser. I recommend Parts Now (http://www.partsnow.com/) for replacement kits, which have instructions on how to install with them.
Jun 22, 2009 | HP LaserJet 4650 Color Printer
Xerox docucolor 12 system fault 15-362
Fault Code 15-362 - CAUTION: The Fuser Roll remains in a cammed-up position if power to the copier is interrupted while the copier is in use. The Fuser Roll will not be released from its position until the power is restored, the Power Switch is in the On position, and the Start button is pressed again. If the Fuser Roll remains in the cammed-up position for a prolonged period of time, copy quality defects will occur. To prevent damage to the Fuser Roll, switch the Power On as soon as possible after the power is restored, and make a copy of a document. If the machine is a DC 12LP send a print job from a workstation to prevent damage to the Fuser Roll.
Apr 15, 2009 | Xerox DocuColor 12 Printer
Ricoh Aficio CL3500N is now printing all documents with lines/streaks all down the left margin of the page. What do I clean or replace to get rid of these unsightly lines printing on every page?
you can try printing a page in black only, then one page each in the 3 other SINGLE colors: Cyan, Magenta, and Yellow. this will eliminate/ confirm one of these causing problem.
the replacement of Transfer Belt Cleaner or Cleaner Assembly is another to try after the above separate-color thing. see if there's a status page of life remaining on replaceable items, including the Transfer belt assy.
i'll assume you didn't scan the job- - this isn't a multifunction scanner/printer type machine?
ok, next in line is to check the Fuser unit, the part on the upper left side/top of printer. if the same streaks appear on the Main fuser rollers, these fuser units cost about 350 bucks. there is also a Fuser Kit, which costs much less, but its job is to add Fuser Oil to the fuser unit and keep paper and ink from sticking.
a guy could suffer sticker shock from the costs of running one of these, considering you could drop a grand buying all 4 drum units, a fuser unit, and a transfer belt assy. . . .
Feb 16, 2009 | Ricoh Office Equipment & Supplies
Hp 2420 vrtical line in page
This issue can be due to fuser. I am sure you have changed the toner cartridge.
To confirm its a fuser issue, please perform the following:
1. Try printing a configuration page from tray 1, pull the top cover, as soon as the media is 60-70% inside the printer.
This would stop the paper before reaching the fusing assy.
2. Remove the paper and check if the line exist.
If exists, fuser is not faulty.
If it does not, then transfer roller, laser/scanner assy is faulty
- If fuser is faulty, perform the cleaning page as following
1. go to configure device > print quality > create/process cleaning page
perform cleaning page 5-6 times, however, if the line is due to fuser, then fuser needs to be changed.
Let me know the next update.
- Nikhil
Nov 21, 2008 | HP LaserJet 2420 Printer
Xerox Docucolor 12
Error in the Fuser. The description for this fault code is: External Heat Roll Contact Failure. Generally the external heat roll retract motor is defective. The xerox part number of this motor: 127K21350
Aug 20, 2008 | Xerox DocuColor 12 Color Copier
XEROX DOCUCOLOR PRIN 12
Check the blade (knife) , maybe dont clean all residues, sorry form my english, check the fuser roll, this roll have a teflon, mabybe need change!
Dec 26, 2007 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
64 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
