Question about LG DLGY1202W White 7.3 cu.ft. Ultra Large Dryer with Steam Technology DLGY1202
How do we remove front panel on LG DLGY1202 steam dyer when it seems stuck
3 Suggested Answers
MakeupWizard
  • 39 Answers
SOURCE: LG WD-12124RD How do I remove the front panels?
Hiya,
most machines now open from the back you will find 2 or 3 screws/bolts at the top holding on the top section if you un screw those then slide the top back slightly it should unclip allowing you to take off the top this should expose some more screws or bolts that will be holding on the front & sides, if your machine is leaking from the front you could have a leaky door seal too so you may want to check that before starting to take it apart.
Hope this helps
Posted on Apr 23, 2010
  • 6277 Answers
SOURCE: Why does my LG front load steam washer get stuck
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Posted on Apr 11, 2011
How do I open to remove the water on an LG tromm front load washing machine to repair/replace the pump?
LG machines normally have a small diameter rubber pipe folded up in the drain pump basket area on the lower left side of the front panel.
Pull out the pipe and remove the small plastic end stopper to allow the water in the tub to drain.
Sep 20, 2014 | LG Washing Machines
Can't seem to remove back panel from TV to replace the speakers. All screws removed, seems to be stuck on.
Check for screws on the interior of the back panel, not just around the edge. There are screw around the panel where the plugs are connect.
Oct 26, 2013 | LG 32LG40 32 in. LCD HDTV
I need to know how to get the front off of my lg dle0442w dyer.
Disconnect power then using a putty knife, push the blade in the seam between the top panel and the front panel against the retaining clips 2 3/4" (7 cm) from the sides. Lift the top panel while doing this to release the clips and raise the pane.
Open the door and remove the two screws at the bottom of the door opening.
Remove the screws securing the top of the front panel to the cabinet then pull the panel slight away from the cabinet and disconnect the door switch wire harness. Pull the front panel completely out and set it aside.
Reassemble the dryer by following the disassembly steps in reverse order.
Feb 21, 2011 | LG DLE0442 Electric Dryer
How to disassemble LG steam dryer
You can start by removing three screws on the lid of the dryer, slide the dryer lid off. Then if you need to remove the front, you'll need to remove steam-dispenser tray, and remove the screws there, and then on the other side of the control panel. Then once you remove the control panel assembly, the front of the machine has 4-5 more screws to remove. you'll need to disconnect the door switch, before removing the front cover of the machine, sometimes this is very firmly in place, be careful.
Mar 24, 2010 | LG SteamDryer 7.3 Cu. Ft. Extra-Large...
Drum noise
Did you ever figure this out??? Ours just started doing this
Nov 29, 2009 | LG Dryers
When dyer runs it makes a squealling noise like abad bearing>
Could be felt pads and nylon glides on the front drum support are deteriorated.
Could be a sticky build up on the rear drum rollers.
Could be a worn belt tension roller.
Unplug the dryer.
Remove the front panel.
Remove the front drum support.
Remove the belt and drum
Inspect the items listed above.
Replace as needed.
Mar 11, 2009 | Maytag Dryers
Cracked Drum on LG Dryer Model #DLE2512W
If you are still looking for information on this:
No, there has not been any recall.
It is not a real common problem. I only see 1 or 2 a year, which is not many. (LE errors on washers are much more common, for example) The part number of the drum for a DLE2512W dryer is 3045EL1002D and lists for just over $100. You can find a service center to order the part from (in the US) at http://us.lgservice.com/index_b2c.jsp
I would rate the repair at about a 5 or 6 out of 10 on a scale of 1-10 in difficulty. (Basically, remove top, remove front control panel, remove front panel, remove front drum support, remove belt, drum comes out the front, reassemble.)
Dec 22, 2008 | LG DLE2512W Electric Dryer
How to open the dryer and replace the belt
all dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
Dec 21, 2007 | Dryers
LG DLGY1202W White 7.3 cu.ft. Ultra Large Dryer with Steam Technology DLGY1202 Logo
73 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
