Question about HP Cell Phones
Sim card no signal - HP Cell Phones
    Problem Solver:
  • 5 Answers
I think your HP phone is locked with network so that it will displays an error message saying "Sim card no signal" .
To unlock it,visit TheUnlockArena.com here they are providing the unlock code at reasonable cost with easy step by step unlocking instructions and unlock it.
Posted on Dec 28, 2013
M33 no signal
No signal using indicate a problem with the sims card check your sims card make sure it is not in backward or upside down if that doesn't work replace the sims card
May 22, 2014 | Cell Phones
SIM CARD UPDATE STARTED
contact customer care.
Mar 05, 2014 | Cell Phones
Insert sim card is found in low signal
First:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Second:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jan 12, 2013 | Samsung GT C5130 Mobile
Why I don't have network signal on my nokia 6600?
If you are not getting any network from your phone it my be be due to:* sim card issues* network / outage issues* phone issues
SIM Card issues:1. turn off mobile phone2. remove battery3. remove SIM card and memory card4. clean the SIM card from any dirt or dust5. wait for 2 minutes then plug back battery6. insert memory card and SIM card properly7. turn on mobile phone8. check if you will be provided with a signal from the upper right corner of your phone's screen. if not, try a different SIM card.
Outage:1. call your service provider and confirm if there are outages in the area or outages from the BTS where your SIM card is registered.
Phone Issues:1. if the phone is open line, try to enter a different SIM card2. try to insert the SIM card into a different phone, check if it will be provided with a signal3. if the second phone still dont get any signal and your service provider stated that there is no outage that may affect signal issues from your phone, check it from them if your sim card is still active.4. last resort is asking for a SIM replacement with the same phone number
Dec 11, 2011 | Nokia 6600
How to switch from offline to online
Offline mode only appears if the mobile phone is not getting the signal from its service provider.
*make sure that the sim is properly connected*reseat the sim card from the mobile phone*check account status for signal and connection availability*power cycle mobile phone
1. turn off mobile phone2. remove phone battery3. remove memory card4. remove sim card5. wait for 2 minutes before plugging back anything6. after 2 minutes, plug back battery7. insert memory card properly8. insert sim card properly s well, make sure that the sim is not dirty as well9. turn on mobile phone10. check the signal bar, it should be with signal this time and not offline
*after power cycling, phone should be working properly now unless the sim card is really faulty. you check if its faulty by calling your mobile service provider*
Dec 10, 2011 | Nokia E75 Cell Phone
How can fix my cellphone ? it has no signal ! Samsung E1080 is the model
If you get signal with anothe sim card this means that your sim card needs to replaced , if you dont have signal with any sim card , that means that you need to update your software on the phone or changhing the internal antena
May 08, 2011 | Samsung E1080 Black OPTUS Cell Phone
Ii got a unlocked iphone had signal for the first hur or too now has none even tho it says orange has no bars and cant txt or call or recive
Reset the iPhone:
It has been observed that simply resetting the iPhone can resolve signal strength issues.
Reset network settings:
In some cases resetting the network settings has also helped so tap Settings, tap General, tap Reset, tap Reset Network Settings.
This will restart your iPhone and will also delete any stored Wi-Fi passwords as well as DNS settings and more.
Place your SIM card again:
If your iPhone’s SIM card is not placed properly, it has been observed that it can affect signal strength.
So a good idea would be to remove your iPhone's SIM card by pushing a straightened paper clip into the small hole on the top of the device to open the SIM tray, then check for debris inside the tray or SIM card slot, remove it by blowing into the slot or using compressed air and then placing the SIM card properly and then re-inserting the SIM tray.
The notion is that improper SIM contact can result in a weak signal, so the above procedure could help.
Attaching scotch tape to the SIM card:
This is indeed the most ingenious methods, it appears that attaching a small piece of scotch tape to the outer side of the iPhone’s SIM card (the side of the SIM card that does not have metal contacts) can result in a surprising boost again borrowing from the notion that improper SIM contact can result in a weak signal.
Jun 02, 2010 | Apple iPhone 3G Black Smartphone
Sim card wont register
You SIM card is inactive. You have to make at least 1 paid call every 6 months otherwise your sim is deactivated. If it's new sim has to be activated.
Rate me if helped.Thanks.
Apr 14, 2009 | Nokia N91 Cellular Phone
Cell Phones Logo
Top HP Cell Phones Experts
D. E. Hev
Andrew Taylor
Andrew Taylor
richie46
Are you a HP Cell Phone Expert? Answer questions, earn points and help others
