Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Drainage
By paulbasson on Oct 17, 2007
My hoover hdb244-80 has water sitting in the bottom of the drum and will not drain...
Same Problem
May 28, 2008
-   where is the pump & filter on my Kitchenaid clothes washer - how do I access it? If there is a filter, how do I clean it?
Walter
therapeutx@telus.net-   Guest
Best Solution
posted on Oct 18, 2007
Helpful)
gittos73
Rank: Guru
Rating: 87%, 301 votes
more then likely that your pump or the drain hose has a slight blockedge you can kill 2 birds with 1stone here you can get rid of the water and see if the pipe is blocked by taking the pipe and placing it low to the ground into a bucket if the water comes out slow then you will have a blockedge and your pump will be ok now make sure you pull the plug out pull the asher out now tip it backwards just enough so you can see the pump at the back undue the clip which holds the pipe onto your pump now there will be some water that will leak out once pipe is free you can pure water down it by putting it onto the tap if it comes out fast then the block is in the pump
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
whirlpool ultimate care ii washer LSQ9110PW2
Answer
hello,7.5kg comercial,top load.when it starts the wash cycle it has a bad banging sound thats quit... (More)
Answer
5d shows up where the minutes of my whirlpool duet what does that mean
Answer
the soap dispenser is not dispensing all of the soap (not overloaded)and fabric softener is not... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
