Question about Samsung Refrigerators
Model RF 4287HARS/XAA temp on door reading OF- how do i turn it back on.
My Samsung dryer (model #DV210AEW/XAA) will turn on but will not work. Its shows a symbol that is shown below Temp. & Time.
that is your child lock. if you hold down the temp and time buttons for about 5 seconds, at the same time, the light should go out and unit should work like normal.
Nov 15, 2015 | Samsung Dryers
What is freezer evaporator thermistor reading at room temp
is it p[ositive coefficient or negative co efficient? usually around 1300 ohms for pce give or take 150 ohms
defrost terminator thermistordefrostterminator-vkiemehpceedlb3juqb40fef-4-2_0.jpg
Oct 15, 2015 | Samsung Refrigerators
Model # RF4287HARS/XAA
No it's a whole assembly the plastic clip is broken. Give me a model number I'll track down the part for you.
Oct 05, 2015 | Samsung French Door Refrigerator Right...
Freezer door code is reading -25 on a samsung refigrater
Error 25 is fridge defrost fault, could be defrost sensor or defrost heater.
Ian.
Aug 19, 2015 | Samsung Refrigerators
Can't find temp control food is getting freezer burn
I clicked on the below links to find your manual.
http://www.samsung.com/us/support/owners/product/RFG297AARS/XAA
http://www.samsung.com/us/support/downloads/RFG297AARS/XAA
There are 2 links for manuals on the 2nd link above
(13.53 mb english and spanish) with file name DA68-01820A_v1.3.pdf)
http://downloadcenter.samsung.com/content/UM/201104/20110428084005272/DA68-01820A_v1.3.pdf
The first one is the quick guide (pretty much useless)
Electronic control from outside of Pantry Cover (Left side)
Adjustable temperature control ((around 41F(5C):Deli /around 38F(3C) : Fresh / around 34F(1C) Chilled) Temperature control from outside of the Pantry : user friendly design helps keep foods fresh for longer.
If adjusting the temp to a wamer temp does not correct the problem you may have an air damper or thermistor problem. You must allow 8 - 12 hours between temp changes to know what the stabilized adjusted temp result is.
Thanks for choosing FixYa,
Kelly
Aug 25, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
The LED indicator is flashing/blinking we replaced the lamp and it will not still turn on. someone suggested the cooling fan? Thank you Shawna2735@Gmail.com
If Fan is running when you turn TV on and keeps running then its OK ,Ballast Board is what turns Lamp on, Is Lamp Lighting at all?
Encompass Parts Distribution has Ballast board for $62.00
Be sure to give the whole model # to TV Ending in WXXaa
WAX/XAA or WX/Xaa HLR6167wxxaa or wax/xaa or wx/xaa
1-800-638-3328 You can also go to their website and type in your model # for List of Parts and Free Service Manual.
Sep 28, 2010 | Samsung HL-R6167W 61" HDTV
Samsung model#hlr6167wx/xaa replaced lamp,lamp and standby/temp still blinking. the bulb is new and turns on. just no picture
Ballast Board needs to be replaced it is what turns Lamp on. 1-800-638-3328 Be sure that Lamp Fan is running or TV will not come on.
Jun 26, 2010 | Televison & Video
I have a Samsung HLS4266WX/XAA that keeps turning itself off with the red stand by/temp light on in the front. I have allowed it to cool down for over an hour with a box fan pointed on the back of the...
Dear dreadtrainer;
It sounds like your Lamp is going bad. The part # B96-01472A. Go to internet (like Google), enter Model # and Lamp toget your best price. To replace the lamp is easy, look at your 'owner's manual".
Good luck, Big Irish.
Nov 13, 2009 | Samsung Televison & Video
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Refrigerators Logo
21 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
