Lamp not working
My brandnew projection lamp is not working in the projector. Is there a special use for the lamp?
    President:
  • 412 Answers
The model of projector determines the correct lamp required. If a new lamp does not illuminate, there are 3 or 4 possibilities:
1. The Lamp Thermal Fuse is open (non-functional).
2. The Power Switch is non-functional.
3. The Lamp Socket is defective.
4. The new lamp is non-functional (burned out).
I hope this helps!!
Posted on Jan 14, 2014
2 Suggested Answers
  • 412 Answers
SOURCE: I need a new bulb for a super 8 movie projector GE projection lamp 150W incandescent projection lamp
Be sure you have the specific 3-letter code from the burned out lamp, in addition to the model name/number of the projector. Armed with that, go to www.bulbman.com They have lamps for just about anything !! Good Luck!!
jim
Posted on Nov 16, 2011
Temp and lamp lights flashing
can you let the projector work well
if the projector projects the image,
does the projector light?
if the projector work well ,but the indicator lights flashing,that means the projector is ok ,
you only need to reset the timer of lamp and to reset the timer of the filter,
menu-setting-advance-reset-the timer of the lamp
menu-setting-advance-reset-the timer of the filter
Apr 28, 2014 | 3M S15i 165Watt 2000Hrs HSCR Projector...
Lamp wont ignite.lamp light red flashing.
Before changing lamp use a canister of compressed air to remove dust specially inside the projector when lamp is away.
Dec 13, 2013 | BenQ PE7800 Multimedia Projector
Hello! I have a DELL 1209S that the picture is wavering. Is it spring?! Some vertical lines almost invisible in the background are also perceived. What can it be?
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Dell 1209S DLP Projector
Red warning light
  • 2
  • 3
  • 4
  • 5
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
Turn off on screen message
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | Dell 4310WX Projector
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
Blured picture on thomson projector tv
If cocusing teh projector is not working, try cleaning the lens. Sometimes dust is dislodged when replacing a lamp and coats the optics.
Jun 27, 2010 | Optoma UHP 120W Replacement Lamp Projector...
Green projection lamp not working
  1. you will need a manual screwdriver to remove the panel. You need a soft non-abrasive cloth to avoid any contact with your fingers and the lamp assembly.
  2. Turn off the Projector. After the unit has cooled down properly, remove the power cord from the outlet..
  3. Remove Lamp Compartment Door. The lamp compartment on projectors islocated underneath the projector unit. For Rear Projection TVs, the lamp compartment is located in the rear bottom left or right side of the TV.. Remove the screws and the lamp compartment door.
  4. Remove Lamp Assembly. pull out the lamp assembly disconnect any power cords that is still connected to the lamp assembly. Put it aside and don't get it confused with your new lamp!
  5. Clean Lamp Compartment. Dust gets everywhere and while you have the projector open, use a soft cloth to remove any loose dust from the lamp compartment.
  6. Insert New Lamp Assembly. reconnect any power cables to the new lamp if present and slide the new lamp into the compartment in the same orientation that the original lamp came out.
  7. Replace Lamp Compartment Door. Set the lamp compartment door back into place and securely screw in the door without screwing it in too tight
Nov 03, 2009 | RCA P52939 52" Rear Projection Television
Continuity test for a projector lamp?
2. Projector lamps CANNOT be tested with an AMP or OHM meter. Projector lamps function by igniting ultra-high pressurized mercury vapor accross an ARC tube. At the point where the mercury vapor resides there is no conductive electrical material and therefore testing a projector lamp with an AMP or OHM will not work.
Jul 21, 2008 | Samsung - Projection TV replacement lamp...
jasbo
jasbo
