Question about Mitsubishi WS-55859 55" Rear Projection Television
Installed the repair kit slight improvement tv
Installed the repair kit slight improvement tv goes on for two mimutes than shuts off
  • krc2 May 11, 2010
    Where did you get the DM kit?
  • Mitsubishi Master
  • 8,617 Answers
If you installed the DM kit, check to be sure that the gorund is connected on the dM module. Also do you get a error code when you press the device and menu buttons in together for 6 secomds? If so what code are you getting?
Posted on May 18, 2009
Lg 50pk550 wont turn on
Repair kit Now available on Ebay.. BUY NOW
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200884727409
If you have any one of these LG Models TV below, and all of a sudden, the screen lights for only a few seconds, then goes into standby with a clicking noise. [Stuck in standby] When you try to switch it on, it tries but then just clicks and goes back to standby? In this video, I show you the components that goes bad, and the culprit that causes it all. The power supply board has already been bought from Ebay, but I'm still selling the voltage regulator that is dang near impossible to find on ebay, as well as the REPAIR KIT for this power Supply Board. Board model number EAY60968801. With any one of these PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 Please Make sure that you've already gone through the process of troubleshooting and testing your tv's power supply board before making any purchases.. I recommend that you get a tv tech to check it out, because every tv is different. Remember, the component, and the repair kit will only repair power supply model (EAY60968801) with the appropriate PCB numbers. You buy at your own risk
Mar 10, 2012 | LG 50PK550 50 in. TV
I have a 2-2 error code and tv shuts off after a couple seconds any ideas?
Thats almost always caused by a shorted convergence circuit. Installing a convergence repair kit will usually solve that issue. You can get the convergence repair kit for that model which contains the parts and the CD with repair instructions from www.tvrepairworld.com
Feb 17, 2012 | Mitsubishi WT-46809 46" Rear Projection...
Convergence problem please help
You likely did not do all the steps required to fix it. If you bought a complete repair kit from sites such as Tv Repair Ktis go back and ask them for help. If you did not get one of their kits you can still purchase just the convergence repair instructions.
Jan 05, 2012 | Hitachi 53UDX10B 53" Rear Projection...
My tv will come on for 5 seconds then shut off and a red light will blink 3 times over and over whats wrong with it?
Your convergence circuit has shut the set down, thats what the 2 blink error code means. You will need to install a convergence repair kit for your model that has the two ICs and associated resistors. You can get that repair kit with instructions from www.tvrepairworld.com
Aug 06, 2011 | Panasonic PT-47WX49 47" Rear Projection...
Sound problem need a repair. Sound goes off after
Need the sound board, and they are hard to find, I once found one on Ebay, and no one at Dell would help. There is a large IC on this board and I couldn't get it. But later heard to check Digit-Key. I had this same set with the same problem.
Feb 19, 2011 | Dell W3201C 32 in. LCD Television
I have a Philips TV Model # 32pt5441-37. When I turn on the tv a red line a green line and a blue line show up for about 10 seconds and then it turns off. The power button is blinking - 1 long 3 shortis...
This was a common problem for these tv,s. The tv is getting to hot it sounds like and that is why it comes on and then off right away. The tv is made to shut off if it sense something wrong like, over heating, something goes out and the tv knows so it shuts it down as well. That could be alot of problems to find out the wright problem you might need schematics for that tv. The tv is putting out a code as well right? The code that you mentioned might tell it for you. Enter the tv and model number in your seach provider and it will come up with a little searching on the internet your blinking problem.Thanks
Oct 06, 2010 | Philips 32PT5441/37 32" TV
The tv has been shutting off and i'll turn it back on then it will shut off again and now it shut off and won't turn back on?
Ur convergence ics it dead,also cause this prob.Must replaced the ICS,tries these websites for convergence kit,know how to solders?Tries Tv repair world.com,Tv repair kits.
Nov 09, 2009 | RCA HD52W59 HDTV Projection Television
DOUBLE IMAGEN My Screen is showing slightly double of all images plus one image is slightly red and the other slightly green!
Had the same problem with my Zenith2_bing.gif TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com. The kit had all the parts and simple step by step pics of the repair. I cant thank them enough for making this possible . At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly.
Louis
Jun 01, 2009 | Zenith R49W36 49" Rear Projection HDTV
Installed new bulb and now there is a loud whirring noise and multi colored flashing on screen
Sounds like the same problem I had, I bought a new bulb as well, installed it and nothing. I googled that same issue and endedup buying a kit herehttp://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits/osCsid/145ffde26a9336eaf57c21ff6389def7that came with capacitors that had to be replace, the kit comes with aservice manual and a bag with lots of different capacitors to replaceany out on your board, they are really good at troubleshooting and theyoffer help online. If that is whats wrong with you, you will need asoldering tool, I bought my as a kit at radio shack for $20.00 and plusthe $36.00 for the kit, and a lot of patience, my TV is well andrunning now, it was better than the $600.00 estimate I got from a localrepair shop. Good luck!
Sep 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Zenith R49W36 Rear Projection TV Convergence IC problem
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com. The kit had all the parts and simple step by step photos of the repair. I cant thank them enough for making this possible . At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly.
Thanks Guys, I will spread the word.
Louis
Jul 27, 2008 | Zenith R49W36 49" Rear Projection HDTV
Mitsubishi WS-55859 55" Rear Projection Television Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
