Question about Sony Cyber-shot DSC-W50 Digital Camera
Sony Cybershot camera will no longer take pictures. When turned on the lens keeps opening and closing and the screen says ACCESS. Then it says shut off camera. The battery is fully charged, not sure what the problem is? The camera is 2 1/2 years old, is that the life span of a digital camera?
  • 1 more comment
  • Anonymous May 22, 2009
    I have the same exact problem, lens opens and closes, screen reads access and I am not able to take pictures. Anyone please help!
  • Anonymous May 23, 2009
    Sony Cybershot DSC-W55: able to view and download pics, but when trying to take a pic the screen reads 'Access', the lens opens & closes constantly and then it tells me to turn the power button on and off. I do that and get the same problem.
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    try format the card in pc and try to initialize the camera thru menu options otherwise call sony it might be BAD CCD problem
I had the same problem. I looked at FixYa some months back and found the solution. Give the camera a jolt against something hard. . . has worked for me several times.
Posted on May 24, 2009
  • 3 Answers
Your lens has a grain of grit in it. Try assisting the lens gently side to side and see if that frees the debris.
Posted on May 19, 2009
SeymourRobin's solution is correct, it worked for me as well and now camera works like a charm. Thanks!
Posted on Jun 13, 2009
Sony Cybershot DSCW350 - Camera got dropped with the lens out. While I was able to straighten it out, the lens will no longer completely close (although it clicks like it is trying to) and I continue to...
It seems that some small part inside the lens is broken and prevents moving. Usually not fixable by user :-( I am afraid you will need help of service personnel.
Jun 19, 2011 | Sony Cybershot DSCW350 Digital Camera
I have a sony cybershot and the backlight wont turn on
When i turn on my sony cybershot the lens keeps going in and out and it stops and on the screen it says turn off and on again but it doesn't work
Jan 02, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot stopped working..my camera closes down as soon as i open it.i hv dropped it once..also its lens r projected out so what can be solution to open it?
Please try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
Sony cybershot 4.1 megapixels mpegmovie vx dsc-s90
Your camera has problem in Lens mechanism. If Lens doesn't open properly, camera will not show picture at all. There would be Loading Motor section demaged in Lens mechanism and it needs to be replaced to work camera OK.
Now come to blue screen in playback mode, This model doesn't have internal memory, so you need memory stick/ card to see previously taken pictures.
Jun 21, 2008 | Cameras
Digital camera
Mine is a bit different- Mine turns on to the opening "Cybershot" screen, opens and shuts about 6 times, and then says "Please shut off and then on again" or something. AAH!! Im a photographer! HELP!
Nov 08, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Black Screen
camera ccd is / has failed - also possible , lens iris is stuck closed ( on monitor , can see very faint snow noise against black background - check if iris opens , by shining penlight into lens );
May 03, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony Cybershot DSC-W50
This is what sony cameras do when the lens has become jammed. There are multiple different reasons that the lens can jam but the result is the camera being unable to move it as expected and presenting that error message. Sometimes the lens can be manipulated gently (if extended at all) and freed from the jammed state. Failing this, disassembly is required. Check with your manufacturer for warranty service status and recalls. If they will not cover it you can find a repair provider online. David Millier Advance Camera Repair
Mar 10, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
322 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
