Question about Dyson Vacuums
Untangle retractable cord - Dyson Vacuums
Cord retraction
You may have to replace the cord reel. First inspect it thoroughly to see if you can find something restricting it from retracting.
Apr 15, 2018 | Vacuums
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
Bissell Hard Floor 1161 Bagless Canister Vacuum cord won't retract
You have to find a way to turn the drum the cord rolls up onto. Just move it par enough o allow it to retract. Hopefully you will hit that point before the spring lets go.
Dec 21, 2014 | Bissell Vacuums
Kenmore 116.26212602 cord won't retract completely
This is a common Kenmore problem. The cord may have kinked inside the cord reel, You can remove the top by taking the screws out some are hidden under the switch. If the cord gets too close to the edge of the reel it can bind. Do be careful as the spring in the cord reel can jump out and it hurts. I would take it to a dealer.
Jan 31, 2014 | Vacuums
Retractable cord stuck
I wonder if there is a tangle in the cord. It could have also come off the wheel inside. Open the vacuum to see if you can untangle the wire and put it back on the wheel.
Nov 29, 2013 | Hoover Vacuums
Kenmore canister vacuum retractable cord jammed
go and buy it from www. repairclinic.com
God bless you
Jul 06, 2012 | Vacuums
I have a Kenmore Vacuum cleaner 116.24212. The retractable electric cord won't retract. How can I fix it?
The retraction mechanizm is likely jammed. Mostly likely the cord has jumped it's groove in the retraction wheel/hub. If you are good with tools there is a 70% chance you can get it to work again with a basic DCR operation. Most mechanical problems can be solved using this simple rule: Dissassemble Clean and Reassemble.
CAUTION: The retract mech has a powerful spring inside, avoid exposing. Most retract mech units are rivoted closed so consumers won't poke thier eye out.
CAUTION: UNPLUG THE UNIT
Open the unit from the bottom and the top lid of the canister should come off.
The retract mech should be obvious as it is where the cord comes into the unit.
Look for the cord being bound by iteslf either on top or underneath (lie two cordes in one groove)
Remove any binding.
If you see no debris or obsticals for the cord to retract (where it is getting stuck)
Your spring could have sprung!
Do you feel and retract at all?
Can you locate the releae mechagnism?
Does the Release button seem to function? When Pressed it should take pressure off of the cord hub.
The retract mech may need replaced. Overall the cost will be about $60 for parts.
Feb 12, 2011 | Vacuums
Electric cord won't retract
Depends on the machine. If its a Sebo K model then usually pulling on the cord will re-automatically retract the cord anyway. Any other brand and it will need to be replaced by a qualified repair.
May 06, 2009 | Vacuums
Electrolux EL 7001 Oxygen 3 power cord continually retracts
The button has two parts - the inner part (button) and the outer part (surrounds the button). The press the outer part to deactivate (pop out!) the inner part.
It took me a while to figure this thing out, but I was glad the vacuum wasn't broken.
May 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
Retractable cord
I'm assuming that you have bought the new retractable cord assembly. If you have so, I believe the cord should retract going counter-clock wise (pulling it makes it spin clockwise).
Feb 22, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
Vacuums Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
