Question about Hannspree 10.1-INCH QUAD CORE TABLET PC T7 SERIES WITH IPS 1280X800 10 POINTS TOUCH BLUETOOTH AND 16GB MEMORY ANDROID JELLY BEAN METALLIC WHITE COLOR
The tablet will not switch on
Could not get tablet to switch from horizontal to vertical so switched it off
Please keep my screen from rotating on my ipad.
Swipe your finger up from the bottom of the screen so it displays the controls. The one at top right with a padlock in a circle with an arrow in the clockwise direction is the orientation lock. Tap it once to lock.
Jun 07, 2015 | GSI Wireless Mini Bluetooth Keyboard For...
My Kindle only shows the books horizontally on the screen. When I turn the Kindle, the words do not move into the vertical position.
There is probably a rotation screen lock in the settings if this is on the screen will not rotate when the tablet is turned to the desired position the option should be in the settings menu need more info to determine where in the settings it is at
Jan 24, 2015 | Tablets & eReaders
How can I get my iPad to work vertically
Check to insure the side switch is on for screen rotation.
Go to settings, General. and untick LOCK Screen Orientation.
Jul 31, 2014 | Apple iPad 2 Wifi 16GB
Galaxy note 10.1
Sounds like your vido processor is faulty or a loose ribbon cable inside your tablet.
Feb 14, 2014 | Samsung Galaxy Tab Tablet PC
Allwinner A20 dual core android tab screen want rotate
Allwinner A20 is a name of a processor, so I'm not sure what tablet are you using.
There is an option to block rotation, for example if you want to read an e-book while laying on your back. Go to settings and try to find an option to unlock rotation.
Also, some tablets have a hardware (physical) switch on the side that locks rotation.
Jan 17, 2014 | Samsung Galaxy Tab Tablet PC
Screen will not rotate
Go into settings and tick auto rotate
Dec 26, 2013 | Mach Speed Trio Stealth G2 Tablet -...
IPad screen will not rotate. NOT locked, restart and reboot completed. Stuck in Vertical and running iOS version 6.1. Any solutions?
If u swipe from the bottom up, to get to the control center (or go to settings), is the orientation locked, or unlocked?
Jul 14, 2017 | Apple iPad (16 GB) WiFi Tablet PC
The phone gyro has stopped working out no longer the screen changes when you change the phone from horizontal to vertical
Check your settings to see if the Orientation Change has been disabled. If so, enable it.
If its already enabled and still refuses to work, its a hardware issue. Take it to a service center. You're probably still on warranty, so everything should be fine.
Cheers.
Mar 19, 2011 | Samsung Galaxy BBSPHP1 Tablet PC
Hannspree 10.1-INCH QUAD CORE TABLET PC T7 SERIES WITH IPS 1280X800 10 POINTS TOUCH BLUETOOTH AND 16GB MEMORY ANDROID JELLY BEAN METALLIC WHITE COLOR Logo
27 people viewed this question
Top Hannspree Tablets & eReaders Experts
David Payne
David Payne
yobo007
yobo007
ka4iup
ka4iup
Are you a Hannspree Tablet and eReader Expert? Answer questions, earn points and help others
