Astra 2002 model emission control light is on
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Change 02 sensor
Posted on Dec 28, 2013
I have a Holden Astra 2006 Wagon 1.8ltre. It was running rough so I replaced the coil pack. I have tried disconnecting the battery for half an hour but can't get emission light to go out. Any ideas?
Did the car run good after the coil was replaced?. Emission light will need resetting with a scan tool Providing there is nothing wrong with the emission set up being EGR valve,faulty solenoid or 02 sensor
Nov 03, 2016 | Holden Cars & Trucks
2007 holden astra emission light has come on. Does this mean new fuel pump is needed?
no not pump
something tail pipe emissions related
egr valve or faulty solenoid 02 sensor ?
fault code will lead you to the part needing fixinge1ab937c-e13d-4bb6-91e2-ae2e521a6c8a.jpg
Nov 02, 2016 | Holden Cars & Trucks
What is the location pcv valve on the opel astra 2003
The PCV Valve, or Positive Crankcase Ventilation valve is an emission control device that ...It is located on the inlet manifold
May 07, 2014 | 2003 Opel Astra
How many computer box in opel astra 2006 model 1.6
ecu, light control unit ( bulb blown indicator), abs. immobiliser. central locking . air bag control unit. heater control. sunroof ( if fitted). AC (if fitted). then there are extras. voltage control unit (caravan)
Dec 11, 2013 | 2006 Opel Astra 1.6
2003 holden astra cd ts 4d sedan
You need to get a scanner for the car that plugs into the diagnostic port and use it to tell you what the codes are.
Nov 24, 2013 | Cars & Trucks
2 dash symbols keep coming up and we havent got the book
That indicator means something is wrong with the system that charges the battery in the vehicle, have a test done on the charging system
Jun 27, 2017 | Astra Vehicle Parts & Accessories
I have a Holden Astra 2001 with the emissions engine light on, the manual states that its OK to drive however if if starts flashing I should pull over. Can any suggest a fix for the light prior to handing...
try a simple diy job of replaceing the lambda probe (in between the exhaust manifold and the first box on the exhaust pipe).a quickfit type exhaust centre will do it in mins..
May 13, 2010 | GMC G1500 Cars & Trucks
The engine light comes on and everyhing is fine all fluids are good. someone told me it is the emission control. I'm not sure?
the engine light comes on and everyhing is fine all fluids are good. someone told me it is the emission control. I'm not sure?
Apr 24, 2010 | 2002 Dodge Caravan
2002 Buick Century, when the tank is 1/4 full,
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
The evaporative emission control system checks to make sure there are no leaks in the lines that run from the gas tank to the charcoal canister and up to the engine. It also checks to make sure the gas cap is sealing correctly.
It may just be that the cap was not on tight and the code was tripped.
A dusty environment can also clog the vent line and cause this code.
Have the code cleared and see if it comes back. Some auto parts stores like Auto Zone can read and clear the codes for you.
Hope this helps.
Sep 02, 2009 | 2002 Buick Century
jasbo
jasbo
