Question about LG enV VX9900 Cellular Phone
Dim display on LG enV 9900
I have dropped my phone and now the display on my lg9900 is dim. It works, but is dim and hard to read (both on inside and outside display) is there a way to fix this? Will a phone repair place help? Are they legit?
  • 4 more comments
  • Anonymous Feb 14, 2008
    noyhing works im useing a monder
  • Anonymous Mar 05, 2008
    Same thing happened to me! only mine was water damage, I got my phone out and took the battery out in less than 10 seconds..no lie. then I let it dry and blow dryed it on cold & low for about 10 minutes and everything works fine except its dim and hard to see.
  • KillerKyle Mar 15, 2008
    Yea, i have a similar problem i dropped my phone a couple times and i cracked the screen and now i cant see anything on the screen its just blank.I can call people but i cant like take pictures or even see the screen!
  • shoogiedog Jun 25, 2008
    Both the main and the front backlights are totally dead. I know the phone still works because i can still do everything, except i need to put the phone into DIRECT light, and even then i can BARELY make out very vague forms. I can't read small text at all. It started gradually, first the front backlight would go out every once in a while, then it died completely. Now the inside is totally dead too.
  • Anonymous Apr 11, 2009
    my dad just snapped my phone in half.. i kow the phone still works because the lights still on, its just i cant see anything because the whole top of the phone is off. i dont no how to reconstruct the wires. let me no how i can attach the top part of the phone to the bottom part.
  • nijlkam May 11, 2010
    Solution link . . . http://www.LGenV-VX9900.com
I was trying to set the front backlight and it doesn't have the always on selection on it. Any ideas how to keep it on ? thanks
Posted on Sep 22, 2008
    Master:
  • 474 Answers
Here, this might help, You said you dropped it so its probably due to the shock and not the settings.
Most repair shops dont stock LG Envy parts becasue they ave no way to get it, So they may or may not be able to help.
If you cant get any help, try this, Take apart the cse on the side with the screens. its fours screws hidden under a stickey cover on the side with the big screen. Pry it apart carefully from one of the edges with a little knife or flat head screwdriver. Avoid getting finger prints on the screens, uses an eye glasses cloth to clena it if you do.
There is a ribon that is connected form the other part of the phone that presses in place, its rectangular. Make sure that is snapped securely in place.
The other connector is under the main screen, if you pull apart the main screen from the small screen, there is another connector that is between the two like a sandwich.
This one comes off easily so it may have come loose form the shock of dropping it.
You have to line it up and carefully press it together before you lay it back in the case and put it back together.
Its bassically a metal frame on one side and you line it up and press in the other side, when you lay it back down into the case, it may come apart again because its own weight pulls it apart, so its a bit tricky getting all together and in place but eventually you will figure it out, one you get it all in, mack sure the screens are clean of debre and fingerprints.
You dont want to do it all over again because theres a smudge on the inside or a hair in there, very pesky.
Everything snaps back together easily and then put the screws back in.
If the sticky screw covers survive you prying at them, then put those back on also, it looks nicer.
Give this a try and see, I tried tajing my phone to a supposedly reputable cell phone repair place and the first thing they did was say they dont have the parts and they cant order them. ( this is because LG doesnt distribut them, not even Verizon can work on them, they send them to LG and they usualy replace the phone if its under warranty.)
So dont get suckered in by a phone repair place because they will just check it for water damage and charge you $60.
Let me know if this works, i like hearing good news when it comes to the ENVY phone.
Posted on Feb 25, 2008
Yes! I have the same phone. I just got it a week ago. I like the phone but it keeps on shutting off on me too! This morning when it rang it shut off as soon as i picked it up. What's the deal with that?
Im just wondering if some ppl have been having problems with the Env 9900 (green phone) as much as i am. Everytime the phone is in my pocket it automatically just shuts off. I tried to recreate the problem and it seems that sometimes when you tap the phone that it decides to just shut off (im not hitting the shut off key). Whats the deal with this. Also for some reason my front display cracked and i cant see anything out of it. Does anyone knwo if this is a fixable problem. Thanks for any help
Posted on Feb 05, 2008
  • 106 Answers
Did you try going into the settings
from the front
(Menu -> Settings -> Display Settings -> Backlight -> Display -> Front Backlight -> put Always On)
Same from the inside but main instead of front.
Posted on Nov 02, 2007
  • Doug Kane
    Doug Kane Nov 02, 2007
    how was that not helpful? i had that problem and thats how i fixed it.
How do you fix the charging port on a lg 9900 phone?
You could have a charging port issue, you may need to install a new one into the phone or order a backup battery plus a battery charger, interchange them as needed.
Jul 15, 2014 | LG Pcmicrostore Brand Lg Env Vx 9900...
I need a manual to lg vx-9900
visit this link
http://docs.phonedog.com/lg-env-vx-9900-manual-4316.pdf
if it helps for you please give a 4 thumb rating.
thanks.
May 26, 2011 | LG enV VX9900 Cellular Phone
The people I call can't hear me on my LG Env VX 9900
With the phone OFF and BATTERY OUT.
BACK COVER OFF.
Pass a vacuum cleaner gently over the MIC for two minutes.
A small paper clip can be use to assist removal of dust and dirt.
DO NOT PUSH paper clip or any object inside.
Inspect for dis-mounted item inside the phone.
Re-insert battery and cover.
LG Env VX 9900 is the best music and simple video phone.
Do this clean up around the lower MIC portion will keep the sound quality is check.
Jan 24, 2011 | LG enV VX9900 Cellular Phone
Need a user Manual for my LG vx 9900 Cell Phone
Click on this link Lg vx 9900 User Manual or
to download the user manual for your Lg Mobile. This is a direct link, download will begin once you click the link. The file is in pdf format, so you'll need a pdf reader to read the manual. If you need one (click here to download adobe pdf reader)
Good luck.
Thanks for using FixYa.
Jul 29, 2010 | Cell Phones
LG ENVY BOTH SCREENS BLANK
well it seems like you need the charger port service or resoldered , the flexcable in the phone may need to be replaced.
May 30, 2009 | LG enV VX9900 Cellular Phone
Microphone appears dead
the mic is defected, it is not matter on the moist, theres such thing that will never be permanent,, because the magnet inside on the mic is very delicate and sensitive,, so you need to replace it
Feb 28, 2009 | LG enV VX9900 Cellular Phone
EnV's internal keypad won't light up.
It is a very high possibility. you should only clean your phone with a papertowel that you sprayed with windex very lightly.
Sep 20, 2008 | LG enV VX9900 Cellular Phone
Garmin Nuvi 7700 bluetooth to LG enV-VX9900
You don't. This phone is incapible of that as it's a VZ nav. capible phone. Sorry.
Dec 26, 2007 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
793 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
