Question about Samsung N9000 Galaxy Note 3 32GB LTA Unlocked Black
Imei number null/null
How i can restore my imei number
Samsung gt 1900 no ime baseband problem
Hi Ronaldo
Try this..
  • Open up the dialer and enter - *#06# to check your IMEI number, if you see "IMEI Null or 000000 ", you need to reconfigure the settings to fix the no signal or not registered on network problem on your Android phone.
  • In the dialer, type- *#197328640# or *#*#197328640#*#*
  • You will be prompted into the Command mode, provided On the screen, Select on Common, normally option 6
  • Now Select (FTM) Option 1. FTM (Field Test Mode) is for debugging and testing, if the option is on, you will have to turn this OFF.
  • As soon as you turn this off, your NULL or altered IMEI number will be restored
  • (Important) Without leaving the Command screen, press the Menu key, the button that's found left of the Home button.
  • Select Key input and enter option 2 which will turn your FTM OFF
  • Wait for a minute. Remove your battery and SIM card for two minutes, place your battery in your phone back but not the SIM card. Turn on the device then.
  • When the phone is booted, enter the command mode again dial - *#197328640#
  • Select the Debug Screen, normally option 1
  • After that, choice phone control, option eight
  • Click on nas control, option 3
  • Afterwards, click "RRC (HSDPA), option 5
  • To Fix not registered on network or Null IMEI #, click RRC revision, option 2.
  • Choose the released of your phone, here we will choose option 5 (HSDPA only)
  • The final step to fix Null IMEI # is to turn off your phone and insert your Sim card or else reboot your phone and then insert the SIM card to dial *#06# to see if the IMEI number is restored.
Sep 05, 2016 | Samsung Cell Phones
How to unlock a samsung galaxy s2 net work with imei number null
You have managed to corrupt your EFS folder where your IMEI is stored.
Usual reason is that you have installed a non network firmware on a network locked phone.
Reinstall the network firmware to resolve IMEI NULL issue.
Once the issue is resolved, Get the IMEI number by typing *#06# on your mobile phone and get the IMEI number. Then visit
OnlineGSMunlock.Com to get the unlock code for your Samsung Galaxy S2 at affordable cost. with easy unlocking guide. Good luck.
Apr 23, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Imei number restore
can not restore your imei no as its an specifin identity link with hardware only
Jan 23, 2014 | Cell Phones
Im not sure exactly when my IMEI number was somehow erased, if it happened after i installed updates or after i downloaded music, but it now says null and wont connect to a mobile network. I have the
Goto your provider and they should be able to install a factory reset mode , that is if its not available to you. You will loose all your info if you do a factory reset. So back it up.
Dec 20, 2013 | Samsung Cell Phones
ams 210d pls send digarms power borad all pcb , main board,mother board,etc pls send
Oct 27, 2013 | Computers & Internet
Unlock my samsung
Hi if you want to unlock your Samsung mobile from network lock .Then visit Mobileunlocksolutions.com here they ask you the mobile model ,network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Oct 10, 2012 | Null Cell Phones
Nokia 3110c restore security code
The nokia 3110c restore security code can be sorted by going to: http://www.lur.nu/nokia_mastercode/security_code.php type in you IMEI Number, to retrieve your IMEI number type *#06# this will generate a master code use this to restore your security code. - thanks Anand -
Jul 04, 2012 | Cell Phones
Someone changed my IMEI number on the phone nokia 6500 slide, is it possible to restore the old IMEI number, thanks in advance
M so sorry, its impossible to restore your old IMEI number of your phone. Bcoz the software was already been change. thanks
Jan 08, 2011 | Nokia 6500 Slide Cellular Phone
Samsung N9000 Galaxy Note 3 32GB LTA Unlocked Black Logo
210 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
