Question about Microwave Ovens
Need manual for chefmate WP700AP20-6 - Microwave Ovens
Chefmate microwave oven manual
Remove the cover by removing the screws on the back of the microwave and slide the cover to the rear. The black and white wires will unplug and the green wire goes under a screw. Use a pair of pliers to compress the strain relief to remove the cord from the microwave case.
Jul 16, 2014 | Magic Chef Microwave Ovens
Chefmate rice cooker instructions 10 cup
if you put a 10 cups of a rice rinse it first before you add a water , the measure of the water is equivalent of the cup of the rice.now,put 10 cups of water. then put it on the rice cooker, then press rice cooking, it is automatically turn to "keep warm" after it's getting boiled. wait for about 45mins of cooking.thanks.
May 07, 2011 | Microwave Ovens
Need manual for Chefmate Breadmaker. Model BH-215
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 06, 2011 | Microwave Ovens
I need the food code manual for my chefmate digital scale
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and Installation Instructions as required.
I hope this helps.
Jan 06, 2011 | Microwave Ovens
Have a Chefmate digital stainless steel scale. It weighs in grams and ounces. It was changed accidently to grams but I want it in ounces. Not sure how to do it and misplaced owner's manual.
Easy! On my Chefmate scale what I have to do is toggle so that "weight" is blinking. Then hit "0" - that is zero. Now you can change back and forth from grams to oz!
Jun 25, 2010 | Microwave Ovens
Chefmate microwave P70D20AL-D4 beeping
After calling many numbers, I was put in contact with the manufacturer, Galanz Microwave, and was told that that beeping is due to a burned out part in the keypad that is not servicable. I, too, have this annoying model!
Jul 19, 2009 | Danby DMW1153 Microwave Oven
Chefmate microwave oven won't start, only flashes numbers.
Well I had the same problem. It made me start unplugging a microwave when it wasn't in use, which is always a plus.
When it does the whole 6666 thing, press 5 and then stop/reset. It usually allows me to input what I want after that.
Good luck people.
Jan 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
A part for a chefmate microwave
customer service 800-856-8977
Mar 01, 2008 | Microwave Ovens
Microwave Ovens Logo
48 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
