Sandisk mac driver
Not showing up at all on imac. Is the 8 in 1 reader too old to read an SDHC card? Will the SDDR89 show up on a mac?
    Champion:
  • 232 Answers
That reader fully supports SDHC. You should start troubleshooting the issue by either restarting your Mac or using a different USB port. Macs shut down specific USB ports if an error is detected. But since the ports are usually independent you can just try another port. Also, Mac OS X will not mount a card/drive until it has performed nessisary repairs to it so you will sometimes have to wait a bit longer for some drives/cards to mount.
Posted on Jan 06, 2014
  • Rokka
    Rokka Jan 14, 2014
    Hi, Thank you for responding. I tried everything but nothing worked and the 8 in 1 is not damaged. I eventually purchased an el cheapo dedicated micro sd card reader which works fine. Appreciate your response, thanx again.
4 Suggested Answers
SOURCE: sandisk not compatible with mac computers
Disregard my last.  I plugged it into my Mac, nothing happened, as usual.  I waited 15 mins or so and it mounted the drive!  I haven't determined if I'll have to wait that long every time.  Again, this is MSC mode (MainMenu/Settings/USBMode).  But now drag-and-drop works just fine.  Also, see freeware "SyncTunes" at http://www.nesfield.co.uk/synctunes/
Posted on Apr 21, 2008
Schmead10
  • 650 Answers
SOURCE: sansa e260 doesen't detect 4gb micro sdhc card
Make sure your usb mode is msc plugin your sansa and go to my computer click on folder and you should see your removable disk this is your expansion card One of my first solutions Please rate
Posted on Jun 09, 2009
Geekman
  • 32281 Answers
SOURCE: coby mp827 sdhc card
This player uses a micro SD memory card.
You can download the manual from this WEB site.
http://www.manualowl.com/m/Coby/MP827/Manual/247614
Posted on Dec 04, 2012
Does your product work with macs
It's not a FixYa product, but the microSDHC card will work with your Mac. Insert it into a compatible card reader and it will appear to your computer as another hard drive.
May 31, 2013 | Kingston MicroSDHC 4GB (4 Gigabyte) Card...
New 20 inch i Mac just started not reading SD cards from it's slot?
Best thing to do is buy a $9 SDHC compatible card reader goodluck
Oct 24, 2010 | Apple 20" iMac Desktop
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
SanDisk ImageMate 12in1 cannot read SCHC 4GB or higher cards
Correct!!!! This card reader cannot address cards that are higher then 3gig and cannot read sdhc cards. Most older readers will not be able to read the HC type card, and by older I mean if its 6 months old or more. To read these cards you need to purchase a new card reader. I know, My camera uses 4gig cards and I was unable to access the pics until I bought a new reader..
Dec 02, 2009 | Computers & Internet
My Mac doesn't reconize my 8 GB SanDisk microSDHC memory card
Go into Finder-preferences and select under devices: external disks
Nov 25, 2009 | Electronics - Others
I have been given a SanDisk Flashcard for an iMac. How do I put photos from iPhoto on it, pls?
you Need to get a card reader so that you can insert the card into it. this is usually done via a USB port. Once you have this done then the card will show up on the right side of your desktop as a little disk icon. You can then just select the photos and click and drag them onto the disk icon on the desktop. the pictures will be copied as JPG files which can be read by any other computer.
Oct 22, 2009 | Apple iMac 24" Desktop
Transcend not working in comp.
Cards over 2GB are MicroSDHC. Your reader will have to be able to read SDHC in order to read your card. Unfortunately, your reader maybe to old. You probably will need to buy a newer reader capable of reading SDHC cards.
Sep 02, 2009 | SanDisk 4GB Secure Digital High Capacity...
Formatting troubles for a 8gb Sandisk Micro SDHC
Hi Tony,
Have your My Computer window open and re-insert the card into the reader. If it doesn't show immediately, then right click and choose refresh. It should show up then.
Rob
Feb 27, 2009 | SanDisk 8GB microSDHC Memory Card with...
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
18 people viewed this question
 Grubhead
Grubhead
