Question about Samsung RF4287HARS French Door Refrigerator
Water filter assembly samsung rf4267hars - Samsung RF4287HARS French Door Refrigerator
After replacing filter, how long before filter light goes off?
Filter indicator : The filter Indicator will be Red when you have used your water filter for 6 months, Reset the indicator (it will be Blue) after replacing the filter by holding the "Alarm/Hold 3 sec for Filter Reset" button for 3 seconds.
The above is how to reset the indicator
Jan 22, 2016 | Samsung RF4267HARS 27 cu.ft. French Door...
Water leak inside behind filter possibley the tank
Another possibility is that your filter is not screwed in tightly enough or that its connecting O-ring has broken. Visit this page for new O-rings, https://www.freshwatersystems.com/c-102-filter-housing-wrenches-o-rings.aspx, and this page for replacement filters, https://www.freshwatersystems.com/s-2-replacement-water-filters.aspx.
Jan 12, 2014 | Samsung RF4267HARS Stainless Steel French...
Samsung french door refrigerator wont disense water after replacing water filter
Put the old one back in and if water works, then the new filter is blocked. Buy another filter.......
Jan 11, 2014 | Samsung RF4267HARS 27 cu.ft. French Door...
How to change the water filer on a rf4267hars 25.5 ft
You must shut the water valve to change the water filter. If you don't havewater valve near the fridge, shut the main water valve for few minutes. If you turn the water filter to change without shutting the water valve, lots of water flooring the fridge and you do lots of work to remove the water inside the fridge. Shut the water valve, and then replace the filter. Then turn the water valve.
Apr 02, 2013 | Samsung RF4267HARS 25.5 Cu. Ft. French...
Ice maker not dropping ice
Need more info. Are there ice cubes in the storage section just behind the freezer door? You may have turned the ice-maker OFF. When your depress the ice flipper, does the motor run behind the door? The motor may be burned out or the ice cubes in the storage section are so melted together in a giant glob that the agitator cannot turn.Or, maybe someone turned OFF the water supply.
Aug 10, 2012 | Samsung RF4267HARS Stainless Steel French...
Samsung RF4287HARS French Door Refrigerator Logo
51 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
