Question about Singer Confidence 7469 Mechanical Sewing Machine
I followed the direction, the pressed the peddle. My stitches are straight instead of zigzag.
I tried to make the button hole several times, but the stitches are straight.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Singer Expert
  • 631 Answers
For the buttonhole function, there is generally also a lever you must pull down to engage the function. If you DID pull it down, you may not have pulled it down enough, so that it wasn't engaged.
Posted on Jan 18, 2014
SOURCE: Singer 5050
I was hoping you would have got another answer, I have a mechanical sewing machine ( Singer 5040) with the exact same problem. However, if i use the programed stitches I can sew a zigzag. If i do it manually and set the zigzag width to any width ( even the widest) I get only the same straight stitch, and no mater what length I select it is the same too, very close to gether about 1 1/2 inch stitch.
I took my entire maching apart to expose inside both top side and underneath, nothing apeared loose or broke and i oiled it up. I bought a new bobbin holder and still the same effect. So it has to be something serious is my conclusion...sounds like a trip to Sears to me...LOL
Posted on Oct 17, 2008
SOURCE: Button Hole Beeping on 7462
Yes frustrating issue this one. I discovered that you need to pull down the retractable button hole guide found behind the needle threader (not visible when you are sitting at the machine).
Hope this helps, happy sewing!!!
Posted on Oct 26, 2008
Zenqi
  • 208 Answers
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Posted on Oct 01, 2009
Maggie_B
  • 3 Answers
SOURCE: Setting Machine on Different Stich Patterns
Turn the dial for stitch length so that the black line that separates the stitch length numbers from the buttonhole functions is in the 12 o'clock position. This engages the gears that operate your red stitches.
Posted on Oct 31, 2009
  • 10 Answers
SOURCE: PFAFF 362 Sewing Machine: The shift
Remove the top cover (grasp and lift straight up), spray with "Tri-Flow, liberally inside. Pay attention to the right 1/2 and behind the front dials.
In Front, each dial has a small square opening on the side, use the tube included with the "Tri-flow" to squirt lube inside them. DO NOT use WD-40.
Run the machine daily for 5-10 minutes (set the dial "C" [top front that goes up to 8] to 0 also set the dial on top of the case to 0. Move the Zig-Zag lever (upper right) from 0 to 4 and back again. Respray with Tri-flow. After a couple of days, if it is still stuck place a hair-dryer or light nearby to warm it up to skin temp.
Between the temp and the oil, it should begin working.
Break a Leg!
Posted on Jan 08, 2010
Where is the buttonhole stitch?
when in doubt read your manual .
search for one thru Google make,model,manual
Jul 12, 2016 | Sewing Machines
Will not zigzag or decorative stitches. New to these newer plastic style machines Always used older steel machines. This was given to me my by my sister who used it very little. Could cam be broken?
Hmm, I'm wondering if it has been cleaned and oiled recently. Older mechanicals require frequent TLC. Consult your owner's manual for cleaning and maintenance instructions:
Is your sewing machine mechanical (ie, not computerized)??? CAUTION--if your machine is computerized, do NOT proceed with the following suggestions.
If it is mechanical, have you cleaned and oiled your machine recently? Most mechanical sewing machine failures are because they have not been adequately and routinely oiled, the old oil has solidified and frozen the mechanics. I recommend Bernina oil or liquid Tri-Flow Synthetic Lube (or similar good quality sewing machine oil) for mechanical machines--do NOT use 3-in-1, cooking oil, WD-40, or the sewing machine oil from your grandmother's sewing basket. (I am not associated with any Bernina dealer.)
If it is in fact frozen, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store. Oil one or two drops in every oil hole (see your manual) and also every place where metal rubs on metal. But DO NOT oil any plastic gears, rubber, or belts. If it is still stiff or frozen, direct a hot handheld hair dryer into the top and bottom mechanism of your machine. See if that loosens it up. You may have to repeat.
Once your machine is working again, place a drop or two of good sewing machine oil as directed above. Be sure to use a small brush to clean the lint and dirt out of your machine, especially around the feed dogs and bobbin area. (Caution: Compressed air will sometimes force the dirt and lint into areas that cannot be cleaned.) And continue to use good quality sewing machine oil to keep it running. Recommendation: every time you change a bobbin, after 8 hours of sewing, or every six months if it is not in regular use.
Dec 30, 2015 | Singer 6038 Mechanical Sewing Machine
Bottom thread is still loose even if i try to balance the tension, how do i balance the thread tension?
You bobbin tension CAN be adjusted. First, thread your machine with different colors in the top and bobbin, set your top tension at its default, and run a line of straight, and then a line of zigzag stitches, and compare the results at the top and bottom. You will be adjusting your bobbin to your top tension. If the top tension looks like a straight line instead of stitching and the zigzag looks like "chicken tracks" instead of a zigzag, but the bottom looks like a zigzag, your bobbin tension is too loose.
Remove the bobbin case, and locate the straight-slot screw. There are generally two; one is a Phillips and one is straight--you want the straight one. Leave the other alone.
The rule is "lefty-loosy, righty-tighty." If your stitching displays the above symptoms, it needs to be tightened, so turn 1/4 turn to the right--no more--then test again. You will need patience, but don't turn more than that. It is easy to do, but if you don't do it systematically, you can make things worse, and very slight adjustments can alter the stitching significantly.
Apr 15, 2015 | Singer Sewing Machines
Singer Simple 3116 only sews backward.Looking for answer I saw earlier that involved several steps including buttonholer
You are stuck in buttonhole. The selector knob does not spin round and around. It is moved from Stitch 1 to stitch 14 and back. Try selecting buttonhole and then running the knob in the other direction to straight stitch. If that does not work, (1) drop the lever that senses the button hole attachment, (2) sew a few stitches backward, (3) push the button hole lever rearward, once, hard, (4) rotate the stitch selector to straight stitch.
Jan 09, 2015 | Singer Sewing Machines
Singer sewing machine needle moving to the side after it's in the fabric for a zigzag stitch
If you can grab the hand wheel and move it right and left, then it probably needs a plastic collar that goes next to the left upper shaft bushing.
If not then the cam timing needs to be adjusted.
Mar 13, 2014 | Kenmore 15516 Mechanical Sewing Machine
Machine will not zigzag
The guy is right, dust kills the moving parts. try oiling the shaft that holds the needle up about 1/2 way and then run on straight stitch with no thread to work in oil, do this several times till you feel that it runs smoothly and you have a little movement side to side as this is necessary for your zig-zag. if that does not work it may be a cam or belt in the top part that needs replacing and you will need the repair to tell you that. I asked them to give me a quote before any work was done so I knew what I was up against. I love my machine so it was worth the 200.00 to get the parts replaced. It will sew anything cause it is a older model with metal rather than plastic parts. hope this helps good luck
Jun 17, 2017 | Singer 3116 Simple
Needle position
First, select straight stitch on your pattern selector. Check your zigzag setting to see that it is on zero.If this doesn't help, push the needle bar to the left and see if it will move. It's possible the assembly is seized and won't move the way it is supposed to.
Next, try the widest zigzag stitch. If you only get a straight stitch it is time for a service.
sewman7
Jun 08, 2008 | Husqvarna Lily 540 and 550
Changing stitches on a White 1418 sewing machine...
I have a White 1418. Here's how you do it:
1. Attach the buttonhole presser foot (should have come with your machine) and place the fabric underneath.
2. Set the stitch length knob to 0, the zigzag width knob to 5, and set the needle position to center. Sew 3-5 stitches.
3.Change the stitch length to 0.5, the zigzag width to 2, and the needle position to left. Sew to the entire length of your buttonhole.
4.Set stitch length knob to 0, zigzag width knob to 5, and needle position to center and sew about 3-5 stitches
5. Set the stitch length knob to 0.5, zigzag width to 2, and set needle position to the right. Pressing the R button (reverse button), sew up to the top stitches.
6. Remove the fabric and open the button hole with a button hole cutter.
Sounds complicated, but it's really easy. I love this machine, you just have to know how to use it!
Sep 18, 2007 | White Sewing 1418 Mechanical Sewing...
Singer Confidence 7469 Mechanical Sewing Machine Logo
22 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
