Question about Tomy Freestyle Baby Carrier
Lost parent unit
How to set off pager for lost parent unit on tomy tf500 baby monitor?
4 Suggested Answers
wborg1231
  • 36 Answers
SOURCE: instructons for baby carrier
You can probably find new instructions on Tomy's website.
Posted on Apr 24, 2008
SOURCE: FA error code on screen Tomy Walkabout Platinum monitor
Hi, I've had the same problem with the Tomy WalkAbout Platinum - and, indeed, no help to be found on any website.
Eventually traced the problem to the temperature reset button on the child unit (the blue button to the side). This button was lodged solid in the device; on inspection because of the wire of the temperature sensor.
I've opened up the child unit (remove the four small screws with a watchmakers screwdriver) and removed the entire temp. reset button.
The set up works as normal (but with a bit of gap). With a bit more time, you might be able to fix the temperature sensor wire and get the temperature reset to work again.
Regards,
M
Posted on Apr 22, 2010
SOURCE: Tomy Freestyle Baby Carrier Instruction Manual
Is it one of these
http://www.tomy.co.uk/images/CUK/ENG/DOCS/1752_INS.pdf
http://www.tomy.co.uk/images/CUK/ENG/DOCS/1760_INS.pdf
Posted on Sep 15, 2012
I lost a connection of tomy digital viedo srv400
Hello. I think I've worked this one out. Turn both on as usual. Go to the main menu screen on the parent unit and click on add camera icon. Then click camera one.... but before clicking the add button, go to the camera itself and click the power button as follows - two short clicks, then hold the power button - the green light will start flashing. Keep holding the power button on the camera and click the add button icon on the parent unit. They should pair. The camera may turn off then, but it should be paired - simply turn it on again. Worked on mine, but took a long time to work out how to fix. Please email if you need any help. hbmb8@bigpond.com
Oct 26, 2014 | Baby Gear
I have tomy classic baby monitor from a year now, from few days parent unit is beeping continiously, have checked connection and evrything and even the green light does goes red
The unit may have a back-up battery installed that is low on charge. Replace the back-up battery. The unit is probably still working because you have it plugged-in.
Sep 17, 2014 | Baby Gear
Hello I have a Angelcare baby monitor model ac1100 and have had it 1& half years it hasn't put a foot wrong and all of a sudden the tv monitor side of it is not working properly! It stays a blue screen and...
If you can only see two lines appearing on the screen this may indicate that the parent unit is searching for a signal from its partner and cannot locate one. Check that the nursery unit has fresh batteries and is switched on. If all ok with the nursery unit you may need to "re-pair" the two units together as per instructions. Note that the maximum distance between the Parent Unit and the Nursery Unit is approx. 100 metres indoors. In reality the Signal Strength Indicator on the parent unit should show the strength of signal between the Parent Unit and Nursery Unit. The Out of Range Indicator should alarm when the two units have lost connection and the Out of Range Icon will be visible in the Parent Unit screen. However these units sometimes require a "re-pairing" exercise to get them to communicate with each other again. Ensure both units have fresh batteries.
HOW TO RECONNECT THE PARENT AND NURSERY UNIT
In the unlikely event that the connection between the Nursery Unit and the Parents Unit is completely lost, please follow these steps to restore the connection:
1. Turn both the Parents Unit and the Nursery Unit OFF
2. Turn the Nursery Unit ON
3. Press and release the left wing 4 times. The nightlight will fl ash.
4. Turn the Parent Unit ON. A blue screen will appear with the NO SIGNAL icon in the Parent Unit Settings Bar
5. While pressing the TALK BACK button on the right hand side of the Parent Unit, press and release the POWER button on the left hand side of the Parent Unit
6. If successful, the video capture will appear on the Parent Unit's screen again. The connection was successfully restored
Jan 18, 2014 | Baby Gear
I have a tomy video baby monitor, da baby unit keeps flashing from red to green and nothing is coming up on the parent unit.
Some thing happens to my video...... Have you tried turning the monitor on first? If that does not work repost and I will reply to that.
Oct 19, 2012 | Computers & Internet
Tomy baby monitor srv 400 instruction
Page 1 SRV Series (Model SRV400) Q & A'sQ. My Parent and Baby (Camera) Unit have lost contact, what should I do?A. It may be possible that the encrypted code pairing both units has corrupted, to reset the code please
follow these instructions;
1. Place the Parent Unit next to the Baby Unit.
2. Activate both Parent and Baby Units by pressing their respective ON/OFF buttons for greater than
2 seconds.
3. Press the Mode/Enter Key to enter the Parent Unit's Main Menu screen.
4. Using the four-directional Navigation Keys, select the 'Add/Remove Baby Unit(s)' option and
press the Mode/ Enter Key to confirm your choice.
5. The current status shall now appear, showing all four Camera Units shaded grey;
6. To reconnect the Camera unit to the Parent Unit, using the Parent Units Navigation Keys ensure
the green circle is highlighting 'Camera 1'. Now press the Mode/Enter Key
7. Select the 'Add' icon with the plus symbol and press the Mode/Enter Key.
8. The screen will show the Parent Unit at the bottom transmitting a signal to Baby Unit
Jun 05, 2012 | Baby Care
Camera monitor lost color ability
Hi
The First Years range is by Tomy - we recommend you contact them to discuss http://www.tomy.co.uk/
Jan 15, 2012 | The First Years Baby Care
The radio link between parent and baby unit has been lost and even after going through the registration process detailed in the user's manual link is not being establsihed. I have also removed the bat
Hi there, i have the same problem and its just over a year old now, i got a new battery but it still wont link, and keeps beeping. Did you solve this problem yet?
Nov 15, 2011 | Motorola Mobility Mbp30l Digital Video...
Tomy walkabout platinum monitor
Sounds like the battery - the parent unit has a rechargeable batter pack. You can get a replacement battery at most appliance stores.
Regards.
Apr 18, 2010 | Baby Care
Regards,
M
Feb 21, 2010 | Tomy Freestyle Baby Carrier
Tomy Freestyle Baby Carrier Logo
21 people viewed this question
Top Tomy Baby Gear Experts
Dorel UK
Dorel UK
Are you a Tomy Baby Gear Expert? Answer questions, earn points and help others
