Question about Hotpoint 24 in. HDA3740G Built-in Dishwasher
The main cup for the dish soap will not stay closed
The main cup for the dish soap will not shut and stay closed on the HDA3740G02SA. how can i fix this?
  • Hotpoint Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
dd
Posted on Sep 30, 2010
My FRigidaire GLD2250RDC6 dispenser cup doesnt open after any full cycle. Open the cup manually & the soap cube is still there.
remove door face so you can see the back side of soap door. close soap door and turn timer by hand. watch and see if a part on the trip mechenism is broke.. then replace that part
May 26, 2012 | Frigidaire Dishwashers
Tip
White residue on dishes
This has become a huge problem and a big misunderstanding on what the white dried residue is on your dishes.....IS it hard water probably not . Due you use liquid or powder soap and fill both soap compartments !!!!ow<br /> <br /> well here is a solution first stop using to much soap!!! <br /> most people only need no more than a tablespoon of soap.... powder or liquid..total... dont forget that powder soap can go bad in those card board boxes in a humid enviorment,,,( under the sink) remove and discard any soap that's clumpy and pour rest in a tupperware dish...<br /> <br /> so here is how to remove white residue off dishes...<br /> <br /> Fill your kitchen sink with hot water no soap and 1 cup of vinegar let dishes soak dont let water cool scour dishes in sink no soap rinse them and air dry all dishes .... some dishes may be ruined due to how long white residue had been on them called etching..... now we need to clean the dishwasher start dishwashere like normal no soap and let run for few seconds when dishwasher starts to fill open door and pour in atleast 2 cups of vinegar close door and let dishwasher run cycle repeat necessary till residue is of wash arms racks door and cabinet walls ... these steps need to be repeated in most cases a few times ...
on Jan 27, 2011 | Dishwashers
Soap dish will not stay shut
heatman101
Aug 03, 2011 | KitchenAid Dishwashers
The soap despenser is broken. looks like the spring is inside the holder and it will not close....stays open at all times. model number for our dish washer is 665.13842k601.Kenmore ultra wash. is this an...
heatman101 '';
Aug 01, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
I have a hotpoint built in automatic dishwasher model HDA3740G02SA. When my dishwasher runs all the cups on the top shelf seem to have dishwashing soap powder left in the bottom of the cups. I do not...
make sure the arm on top isnt hitting something, each time you load it each in there and spin it to be sure it moves freely, also make sure your rinse agent container is full of rinse agent.
Oct 29, 2010 | Hotpoint 24 in. HDA3740G Built-in...
Dishwasher cup won't open
Make sure no dishes have block it from opening. If this is a dial model, then with the door open so you can see the soap cup, turn the dial and see if it opens up. If not replace soap cup.
Oct 01, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
My maytag dishwasher is not getting all the food particles off
I recommend check the following areas to address this issue.
Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
If you only fill one part of the soap cup, try adding soap to both parts.
Jun 18, 2009 | Dishwashers
Soap build up on dishwasher. Dries white and stays on dishes.
the spray arms is eather bad or the wash motor ,,,,, it isn't spraying water onto the dishes with any force.
Larry
Nov 25, 2008 | Dishwashers
Whirlpool gold builtin dishwasher
Do not recommend premeasured tablets, usually too much soap. If pre-rinsing dishes use only 1 or two teaspoons of soap in the main wash cup..do not put soap in the prewash cup. Excess soap can cause oversudsing and make the soil sensor think the dishes are real dirty initiating additional wash cycles. Use rinse-aid for better drying performance
Apr 28, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dispenser doesn't open
this is actualy a water flow issue. usually caused by debris in the sump area. shut off the power, remove spray arm, top filter,ect. keep taking things out till there is nothing left to remove...if it has a screw. you will find a screen with a small blade that will be plugged. clean the screen. reasemble and happy dish washing.
Sep 23, 2007 | KitchenAid KUDU02FRSS Stainless Steel...
Hotpoint 24 in. HDA3740G Built-in Dishwasher Logo
327 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
