Question about Samsung HLR5667W 56" Rear Projection HDTV
Dark shadow about 4'' at top of screen of 56'' dlp samsung hlr5667
I replaced my color wheeel because it was shattered when i put it all back together turned it on i have this black shadow at the top about four inches wide
  • 41 Answers
There is a piece connected to the color wheel assembly called a light tunnel. It is between the color wheel and optic assembly. There is 4 mirrors inside. One of them probably got dislodged when the wheel shattered. Sometimes they can be repaired using high temp glue or you may have to replace the tunnel.
Posted on May 18, 2009
Have a dlp samsung HLT6176S no picture already replaced the bulb still no picture what gives
Remove the lamp and look at the color wheel that faces it.
If wheel is shattered or missing pieces set will know it is not moving or moving too slow and shut set and lamp off.
Not all color wheels when fail make a sound
May 06, 2012 | Samsung DLP HL-P5663W 56" TV
There has been a gray shadom on left side of screen, maybe 3 inches wide, for the entire length of the screen. I can see through the shadow, but it is noticeable.... any thoughts?
This tv have a colors wheel design in it.Flashes or discolors on this shadow?Tv making any humming sound or motor noises.Yes,mean the tv colors wheel is dying and spinning out of it motor axis.The color wheel,is the problems.Colors wheel sit way back of the tv,must take out alot of mechanical parts to get to it to replaced.U have no mechanical skills,don't tries this.Hire a tv tech to replace the colors wheel.
Jan 17, 2011 | Samsung DLP HL-P5663W 56" TV
How do I replace the color wheel in a Samsung?
The following link will give you a step by step on how to do so. I did so and it worked perfect http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/. If once you install the new color wheel the colors on your screen are reversed all that has to be done is pull out the TINY rubber looking thing with 2 pins in it under the yellow/white sticker, not 1 inch or 3/4 inch under the sticker. Right below the sticker where that rectangular opening is.
Mar 21, 2010 | Samsung DLP HL-P5663W 56" TV
My Samsung 56 DLP picture lost is color and is making a buzzing noise which I suspect is the color wheel. The picture is now black
you need to change the color wheel
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
Feb 07, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung HLN617W DLP 61" TV only show green color
BINGO! Light Engine, Maybe listed as- Assy Engine Go to website Encompass Parts Distr their you will find what you need or Call 1-800-638-3328 ,or Try UED 1-800-648-6657
Dec 01, 2009 | Samsung HLN617W 61" Rear Projection HDTV
How do I change the color wheel on my samsung HL-P5663W. I have already removed the lamp and loosened screws for the lamp housing. Doesn't seem to want to come apart. Am I on the right track?
5
6
7
8
Jul 10, 2009 | Samsung DLP HL-P5663W 56" TV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
Picture is going dark to bright and making a clicking noise
Hi, sounds like you`ll need that tech again, your description sounds like a bad color wheel, if you let it continue and it shatters it can & probably will destroy your light tunnell, sorry for the bad news but now you know not to keep running the set, this is a very common problem with dlp`s and it`s exactly why we tell our customers not to purchase dlp`s, gl, video-tek
May 29, 2009 | Televison & Video
Shadow top to bottom of screen on left side about 2" wide...
This can be the sync wheel assy, failure in the drive circuit for the display chip, or an illumination fault. You will have to give the set out for service.
Jerry G.
Nov 26, 2008 | Samsung DLP HL-P5663W 56" TV
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Samsung HLR5667W 56" Rear Projection HDTV Logo
296 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
