Question about Nabi 2
Nabi 2 has grey screen lines - Nabi 2
Can't find manager in settings
[NABI 2] Free up Internal Storage - Basic Ti... ' Fuhu Nabi 2 - XDA ...
forum.xda-developers.com > Fuhu Nabi 2 > Nabi 2 General
Jan 7, 2013 - 9 posts - ‎5 authors
Fuhu's Nabi 2 comes with 8 GB of internal storage, but the actual space available for app install evaporates quickly. Here are ... 2 (quote) Well you can't over root. .... I dont understand how the nabi2 settings sees huge space under ... I was never able to getExt2Int working properly so I abandoned that route. [TOOL][NABI2] NabiLab - Root, Play, Recovery
Jan 17, 2013
Fuhu Nabi2 Backup - Recovery - Root - Gapps ...
Nov 27, 2012
More results from forum.xda-developers.com
[PDF]nabi 2 User Manual - Abt
Dec 28, 2015 | Nabi 2
How long do the screen turn on after I reset it
Cannot get Wopad to turn on sometimes ' Android Tablet Forum
www.androidtablets.net > ... > Rockchip RK2818 Tablets
Dec 28, 2010 - 11 posts - ‎9 authors
It would do this in seconds. the screen would just turn black, like it does when you tap the .... Hi do you know hw to reset the wopad and how to eliminate this *process ...Now I can always turn it on, even after a long standby.
reset nabi 2 tablet if pattern lock forgotten? - Android Forums at ...
forums.androidcentral.com/...tablets/248800-reset-nabi-2-tablet-if-patter...
Jan 31, 2013 - 9 posts - ‎8 authors
How do you factory reset the nabi tablet 2? My child put ... Turn off your Nabi (To turnoff Press and hold the Power button for 3 seconds) then tap OK 2. Press the ... From your screen press the Volume ? (Low/Down) then the Volume + (Up) button. 5. Press the .... These Before & After Couple Photos Just M..
Dec 25, 2015 | Easy Wopad 7 inch Google Android 2.1...
We lost the charger to the nabi were can we get a replaement
Hi Negretta.
Lots of choices out there on Amazon
Amazon com nabi charger 2 , Nabi
nabi 2 Android Tablets for Children Power Adapter Replacement , or eBay
Nabi 2 Charger
You should be back up and running in no time!
D
Dec 09, 2015 | Nabi 2
I have a Nabi that all of the sudden even if the green light is on saying its charged the screen stays black
Sounds like you have a good charger/cable, so try resetting the Nabi that's giving you trouble. Hold the power switch down for 10-20 seconds to reset the unit.
I have a couple of NABI-2 tablets and they both react differently to the charging cables; I often have to shut the NABI off completely to charge them. Also, getting the charging cable to connect can be challenging - I will plug the cable in and out several times waiting 10 seconds or so to see if the green LED will go red.
Dec 31, 2014 | Nabi 2
Why won't The Nabi 2 screen will not unlock even after it is swiped
Best bet is to reset the Nabi...hold the power button in for about 8 seconds. The tablet will shut down and restart. Unless you've dropped the Nabi (hard, my kids drop it often) it should restart and behave.
Dec 11, 2014 | Nabi 2
What is wrong whith nabi 2 that has sreen probloms
sounds like your screen broke. Nabi has 2 'scereens' a piece of glass on top, then the LCD screen below. The LCD screen can be broken by hitting or twisting it. It can also become more prone to breakage if you leave it out in excessive heat.
Nabi will fix the screen for about $60...
Jul 02, 2014 | Nabi 2
Ny grandson nabi jr tablet screen is cracked
I have contacted my warranty company to see if they'll fix mine: the kids have cracked the screen. Fine crack all the way around but the Nabi still works. Will see what they tell me about how they fix it. Have seen ads for the LED and another part that comprise the screen. Not sure which is the right one. One runs about $40 the other $15. (Craigslist is another alternative.)
Apr 04, 2014 | Nabi 2
Nabi 2 freezes when charging
I fit is a new tablet, I would take it (/send it ) back to supplier and complain and/or ask for a replacement.
If it is not new, then... hmmm.
Jan 11, 2014 | Nabi 2
Cracked screen on nabi 2
You have to buy new for sure. The cheapest I have found is LeapTV Educational Active Video Gaming for Kids. Take a look. enjoy
Feb 11, 2013 | Nabi 2
Nabi 2 Logo
Top Nabi Tablets & eReaders Experts
Timllfixit
David Payne
David Payne
jeff5may32
Are you a Nabi Tablet and eReader Expert? Answer questions, earn points and help others
