Question about GE 24 in. GSD6660GSS Built-in Dishwasher
GE dsd 6700 top rack glider wheels not turning,
4 month old Dishwasher top rack glider wheels not turning, Very hard to push in or pull out rack.
  • Anonymous Mar 18, 2014
    are the wheels that are on the top rack supposed to come off
  • 10,865 Answers
Remove the tray and look at the wheels to be sure they are completely attached to the tray itself. If they are spray them with PAM or another cooking spray product to lubricate them.
Posted on May 18, 2009
Door will not shut when upper silverware holder is in
Make sure you are installing that silverware holder properly. The little tabs of the silverware holder are supposd to go over and around the mating bars of the upper rack. Barring that, your upper rack may be pulled (bent) out, and you may have to push it (hard) to get it back in shape.
Oct 30, 2014 | General Electric Adora GHDA670N Built-in...
Top rack automatically slides out upon opening door
This is actually a feature to allow the user easy access of sliding out the top rack. A look at the parts diagram disclosed that there is no mechanism activating this and therefore could be assumed to be gravity driven. It would stop a few inches due to the action or rather inaction of the rollers which would require user intervention (pull).
The only modification I could think of is to change how the inner rails are attached by inclining it to prevent the sliding out. The idea would be to lean in the upper rack to prevent gravity from sliding it out. Am not sure if inclining the entire dishwasher would affect the overall performance but it is also a possibility.
I have taken the liberty of including the diagram of the upper track should you wish to reference it.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 28, 2008 | GE PDW8680NSS Built-in Dishwasher
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
I have a GE profile dishwasher. The wheels on the lower rack have all come off and I can't seem to get it back on. On some, the piece that snaps to the rack is either broken or melted off somehow. Do I...
You just need the wheels. I have bought the upper rack wheels before, now I need the lowers. I have found a site selling them at 10.00 each. I am going to keep looking, I think I can do better, considering I need 4. I might just buy a new washer if I have to spend 40.00 plus shipping! I will post back if I find a better deal.
Jan 08, 2011 | GE Dishwasher Lower Rack Roller WD12X10262
Top rack will not pull out all the way
Replace the upper basket wheels - these are available as spares. If the metal runners look angled - it may be the wheels on the side of the dishwasher that need replacing. These are also available as a spare part.
Ebay is actually a good place to shop for spares of this type.
Aug 04, 2009 | Asko 24 in. 1585 Built-in Dishwasher
Just installed new dishwasher top rack will not slide in
I had the same problem with my new GE. They installed 2 brand new upper racks.$$ it worked ok for about a month and then I had to force it in again. on the 7th repair call in as many months my repair guy walked in the door stating that he finally knew how to fix the problem. It is caused by poor design in the wheels. they are porous and the detergent breaks them down and they swell. new wheels from an older model fixed the problem. they have RND on the case.
May 30, 2009 | Frigidaire PLD4375RFC Dishwasher
DISHWASHER TOP SHELF IS SQUEEKING AND STICKING.
One approach would be to apply plumbers grease to the wheel (simple) axles turn on. It would be if you can pull the wheels, apply the grease and reassemble the wheels. The plumbers grease can be bought in a tiny tin at any real hardware stores.
Longer term fix would be to replace the wheel assemblies with new/replacement parts.
May 25, 2009 | GE GSD2000J Dishwasher
How do I remove the top rack on the ge profile built-in dishwashe
FOLLOW THE RODS THAAT HOLD THE BASKET AND AT THE END THEIR WILL BE A PLUG! IT WILL COME OFF AND YOU SLIDE THE RACK OUT THE PLUG USUALLY HAS A LITTLE LIP YOU NEED TO EITHER PUSH UN OR OUT TO REMOVE
Nov 30, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Adora QuietPower II Replacement Rack Wheels?
Model number is on a sticker on the left wall of the dishwasher, just behind the door, about mid tub level. Post your full model number and I'll list your part number(s) for you.
Sep 06, 2008 | GE Adora GHDA656LSS Stainless Steel...
GE dishwasher nautilus - bottom tray caster wheels come off daily.
I finally found a solution after 2 years! Appliancezone.com has wheels and studs to fix problem. WD12x10136 and wd12x10277. About $17.00 and rack is rolling perfectly. GE wanted 200 for an entire rack, no thank you!
Apr 06, 2008 | Danby DDW1805W Designer Series...
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
375 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
