Question about Dyson DC26 Bagless Canister Cyclonic Vacuum
Dyson DC26 vacuum head turns off constantly
Vacuum doesn't work as it turns off within seconds off touching carpet
  • 3 Answers
SOURCE: Dyson DC 17 Asthma allergy Vacuum
I had a similar issue. I called Dyson. Hey why not, the number is right on the from of the machine. SO IS the beater bar on/off button, right next to the big red on/off switch. It does have a safety off when something jams the bar from rotating so the motor doesn't burn out. I also removed my sock and on restarting the thing, the beater bar would motor was not turning on. I thought the reset would be inside but no, it is right outside in plain view, which I didn't see either. It is a grey button opposite the big red on/off switch. Boy did I feel dumb after that phone call!
Posted on Sep 07, 2008
SOURCE: Suction loss when handle is tipped back to clean carpet
Ours did the same thing. I cleaned the filter and canister thoroughly. It needed to be cleaned, but that didn't fix the problem. I removed the plate under the carpet brush bar (three quarter-turn screws) and removed all hair, lint and threads from the rollers and brush. THEN my husband found the real problem: a piece of flexible hose running from the head into the hose (on the left side when behind the vacuum) was completely clogged. The hose will detach from the head, and you can remove debris. Once that clog was removed, the hose easily re-attaches, and we had great suction once again.
Posted on Feb 14, 2009
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
Posted on Oct 04, 2009
Dysonteam
  • 167 Answers
SOURCE: dyson power head stops
Hi its Darran at Dyson.
As the Turbine head is air driven, you may need to wash the filter and check the rest of the machine for a blockage as a loss of suction will also reduce the performance of the Turbine head.
For the full blockage procedure and filter washing instructions, please visit the Support section of our website at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 20, 2010
SOURCE: turbine head of my Dyson DC08 does not spin
This response is likely too late coming, however for others the problen appears to be the same as the fault with my turbine head which was that the turbine fan had become loose on its spindle. With no pressure on the brushes, friction would allow the fan to turn and drive the brushes via the belt. The faulty part is not available separately however I have repaired mine using araldite glue. Other things to check is for a worn belt. Cheers.
Posted on Apr 28, 2010
Soap all ran out onto the carpet
Hey, sorry to hear you'r having difficulty with your ProHeat.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1060&cid=ccsocial
Jan 06, 2013 | Bissell 1699 ProHeat Clear View Upright...
My Bissell Pet Carpet Cleaner brushes will not turn around and heater doesn't work?
Hey you may want to check out our website for assistance in troubleshooting your machine. Here's a quick link to the FAQ page.
http://www.bissell.com/faqs/?cid=ccsocial
Jan 01, 2013 | Bissell 1770 Quicksteamer II Upright...
If belt is stretched do i have to replace it
If the brush is not turning when on carpet, then yes. The beater brush will turn if the belt is touching it, so looknig at it when the brush is not hitting the carpet is not a way to see if the belt still functions. There should be a window where you can see the brush turning. If the brush does not turn while on carpet, replace the belt.
Nov 24, 2012 | Hoover Tempo Widepath Upright Vacuum -...
Sebo k3 won't vac on carpet...only hard floor
Do you mean the beater bar stops turning and then it doesn't vacuum?
Or it shuts off when you jam it full of carpet? Read the below manual:
http://www.sebo.us/pdfs/website_owners_manualsPDFs/AIRBELT%20K%20Manual.pdf
Aug 27, 2012 | Sebo Air belt K3 Bagged Canister Vacuum
Does not seem to adjust to different carpet sizes
Hi Denise,
DC14 is engineered to adjust automatically to suit the type of flooring you're using it on. You can also use the brush control on the cleaner head to turn the brushbar on for vacuuming carpets, and off for vacuuming hard floors.
However, if you're concerned the cleaner doesn't seem to be working correctly, please follow the steps shown in our online support guide to identify and resolve any issues:
http://www.dyson.com/support/help.asp?article=626&product=DC14-ANIMAL_US
If you've tried this and still feel the cleaner isn't picking up as well as usual, please get in touch with us directly so we can help - you can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Oct 28, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
I can't switch from the brushless option to the rotating brush option.
You should be able to turn the brushbar on using the brush control on the cleaner's head, turning it from the 'Hard floors' to the 'Carpets' setting. For further guidance, you might find it helps to refer to the user guide supplied with the cleaner. In case you don't have this to hand, you can download a copy here:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
However, if the brushbar doesn't seem to be rotating when the brush control is set to 'Carpets', it's probably best if you get in touch with us directly so we can help. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Oct 17, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Just got my dc33... one issue... the dial switch to control btn bare floor / carpet mode doesn't seem holding in it's position when I set to the bare floor mode... it keeps coming back to carpet...
I'm sorry to hear you're having difficulties with your DC33. If you're concerned that the brush control doesn't seem to be staying in position, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to check everything is correct with your machine, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Aug 24, 2011 | Dyson DC33 Bagged Upright Vacuum
Brush inside main head doesn't spin, and stops spinning immediately after prompting it to spin. seems like the motor stop turning brush, however when i open main head and cover suction hole for a...
Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Jul 13, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Carpet/Floor Switch problem on Hoover WindTunnel Vacuum
Well, you have to deal with it, you have to play with this electrical things if you want to fix this problems.
The good news is, the sources of the problems is the switch already broken.The first things before you do anything is, find this switch on the market first to changes the old ones.Then, remove the power cord from the outlet of course.
After have it, then you must open the old switch, and remove it from the unit by cutting the cables using cutter/ pliers or anything.But remember, you must remember the locations of each cable that been cut, you can use Camera Cellphone to make sure of it if you like.
Then put the cables back together with the new switch, after all done, clean all the mess and try operate it.
Hope it works!!!
Dec 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Not real sure what is wrong with my kirby.
i would say to replace the belt for the brush....kirby's have been known to go through belts.....also when i owned one within a year i think i went through 7 belts....try that and let me know what happens. the belts easy to replace.
Sep 30, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Dyson DC26 Bagless Canister Cyclonic Vacuum Logo
61 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
