Question about Yamaha DSP-A1 Receiver
VARIABLE RES. W/MOTO Part #: VZ621400 - Yamaha DSP-A1 Receiver
  • Abdul Khan
    Abdul Khan Dec 29, 2013
    My Right channel cant be controled even if the volume is fully turned down
  • Abdul Khan
    My Right main channel cant be controled even if the volume is fully turned down
My Canon G12 is not capturing at high resolution. I am getting low res- variable size shots. How do I set it up?
When in shooting mode, press the "FUNC/SET" button and scroll down to the setting that says "L" or "M1" or "M2" or "S" and change it to "L"; also if the quarter circle is the jagged one indicating the lower quality compression, you might like to press the DISP button to change it to better quality.
Apr 27, 2011 | Cameras
Dremel Moto-tool model 395 type 1 lock
You can either go to Dremel.com and type in your model number for replacement parts or call their toll free number at 1-800-437-3635 and get that information. Let me know if you need anything further
Feb 20, 2009 | Dremel Variable - Speed Multipro Rotary...
Tv problem
generally buttons are located at front only. but if it is not there then it will be inside in the shape of small variable res. called preset. vertical hold button will be near vert.section &horz hold near h/ section.
Sep 30, 2007 | JVC AV-27850 27" TV
Monitor dark
I had a similar problem with this monitor, mine was dim all the time to the point you cant use it, but the MENU icon was bright as new... also if cable was unplugged the box would float around as normal.... anyway I fixed it by taking it all apart and pushing in the socketed chip.. it clicked like it moved, I also pushed on the variable resistors on the power supply... now it works!!! First time since it quite working long time ago
May 29, 2007 | Samsung SyncMaster 175V 17" LCD Monitor
Yamaha DSP-A1 Receiver Logo
53 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
