Supermicro boot from cd
My bios boot setup has no entry for cd boot. how can i fix it? i must boot from cd...
VooDooNOFX
  • 95 Answers
SOURCE: supermicro machines
Your server uses a Super P8SCi Motherboard, and according to the manual for your server on page 4-2, you can enter the bios of the computer by rapidly pressing the DELETE key when you first power on the server. This will take youto the bios setup screen. At the top, you'll see an option called boot. Use the arrows keys to navigate over to it, and change your first boot device to the CD-ROM Drive. Then SAVE AND EXIT, and it will now boot from any cd before looking to boot from the hard drive.
Steven
Posted on Sep 17, 2008
Fixe_You
  • 1800 Answers
SOURCE: i can't boot from external usb dvd/cd drive
please try to remove the connection between motherboard and vd/dvd drive.
then perform the previous steps.
Posted on Jan 27, 2009
drifterK
  • 4924 Answers
SOURCE: kock the bios, I do not windows setup cd-boot, no change fist boot cd rom, please help me bios password
right ..disconnect the power supply ...open and remove for a few seconds the bios battery ...its looks like a a button ......something like a ag battery from an electronic watch ..only larger ...
after that you will have to reset the time and date ...cause all it will be reset to the factory defaults..and it will have the date from the bios fabrication ...it will work for sure ..
if you do not want to open it ...and you need it for booting a OS installation session from disk ..try to press F8 on boot ...just like entering bios...and select from there the boot device..good lusk !
Posted on May 27, 2009
  • 10406 Answers
SOURCE: how to reset the bios password for nec versa
Restart the computer, and read the first message (white text on a black background), hoping that it says something like "press F1 to enter BIOS setup, press F12 to select boot priority".
If it does, press F12, and then select the CD-ROM device as the "bootable" device.
Posted on Jun 15, 2010
  • 73 Answers
SOURCE: need to flash the bios
You cannot remove the password by flashing the bios. However, there are two possibilities that _might_ work, depending on how that particular model works:
1. Unplug the computer and remove the internal clock battery for a few hours at least - maybe overnight
2. Some motherboards have a "CMOS Reset" jumper on them that you can use to reset any password in the BIOS (and any other BIOS settings). It will probably be a two position jumper on the motherboard, usually somewhere near the clock battery. Put the jumper on the opposite position that it is in, power up the computer for about 30 seconds, power off the computer, then replace the jumper back to it's original spot. Then boot up the computer normally and you should be able to go into the BIOS
These two options don't apply to all systems, but probably most of them. IBMs are an exception because they store the BIOS passwords encrypted in a memory chip that doesn't require battery backup, so on them there is no way to reset the password. Hopefully yours is not like that and one of the solutions I gave will work.
Posted on Dec 18, 2010
X7DBI+ bios password
Hello here is the homepage:
http://www.supermicro.com/products/motherboard/xeon1333/5000P/X7DBE.cfm
Remove the cmos battery on the mainboard for like 15 min. and inset the battery again.
This will clear the bios and remove the password.
But you have to setup the bios clock, date, boot settings, when the pass is gone.
The cmos battery look like this:
Please take antistatic precautions when working on the maniboard.
Good luck
Jan 12, 2013 | SuperMicro X7DBi+ Motherboard
Cant install server 2012
Hello download a manual from the homepage:
http://www.supermicro.com/products/motherboard/xeon3000/3210/x7sbe.cfm
Check the settings in the bios.
Try to reset the bios to factory default.
And setup basic boot settings for the drives.
First boot device: cd/dvd
Second: the harddrive.
Try installing with only one harddrive (you can always add more later)
Check also the cd/dvd drive for fault.
The Os server 2012 is supported.
Good luck
Nov 22, 2012 | SuperMicro X7SBE Server Board -...
How i solve supermicro x8dt3-f display problem
Make sure JPG1 is jumpered between pins one and two.
Pin 1 is on the left.
JPG1 is on the very bottom of the motherboard, near the end of the PCI slot.
Next go to Advanced Setup Configuration if you can get any video, and check Boot Graphics Adapter Priority.
Make sure it is set to Onboard VGA.
If no video, reset the BIOS.
Onboard VGA is the default.
Jun 01, 2011 | SUPERMICRO COMPUTER Supermicro X8DT3...
I have installed windows 2000 server and i am getting problem in booting of os. when there is cd of ms2000 present in the cd drive the os boot properly while if i remove cd from the drive and start the...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Apr 15, 2011 | SuperMicro X6DVL-EG2 Motherboard
We just purchased Supermicro 1026T-URF SuperServer: X8DTU-F motherboard. Added Intel X25-E Extreme (Ephraim) SSDSA2SH032G1 2.5" 32GB SATA SSD drive and attached a SAS storage via Areca...
Make sure the DVD is plugged into the left most SATA connector on the motherboard. ( I-SATA0 )
Make sure SATA1 is set to "Compatability" in the BIOS.
Do not use "Enhanced" for SATA1.
Make sure the Primary IDE setting is CD/DVD in the BIOS.
Do not use "Auto"
On the USB problem, Make sure Legacy USB is disabled in the BIOS.
WARNING! The default is, Legacy USB " Enabled".
Apr 01, 2011 | SUPERMICRO COMPUTER Supermicro X8DTU-F...
I can't reinstall windows xp
hope this helps
Mar 29, 2011 | SuperMicro PDSLA (PDSLAB) Motherboard
Menus Locked in BIOS of 5014c-mt super server. Cant navigate to any sub menus... How did this happen????
http://www.supermicro.com/products/system/1u/5014/sys-5014c-mt.cfm
Try to reset the bios, by removing the cmos battery.
And insert it again.
This will clear the bios, to factory settings.
But you have to setup the bios again: date, clock, boot settings etc.
When you get it running again, try upgrading the drivers and bios to the latest version.
Hope this will help you.
Feb 10, 2011 | SuperMicro SuperServer 5014C-MT
How to reset the bios password for nec versa m350.. pls help!!! i want to reinstall my OS but i can't access the bios setup to change the settings to boot from cd rom upon startup. there is a bios...
Jun 15, 2010 | Computers & Internet
Supermicro machines
Steven
Sep 09, 2008 | SuperMicro (SYS-5014C-T) (SYS5014CT)...
How can i get rid of the compaq logo even after i format my hard drive .
The screen that I think you're referring to is the OEM BIOS splash screen.
This particular logo / image has nothing to do with your hard drive... it is embedded on a physical chip (EEPROM or ROMBIOS) on your motherboard.
It is possible to make modifications to this particular splash screen (through a hardware hack), but I don't recommend doing it. The screen shouldn't be a problem; it sounds like you might be experiencing a "Boot Order" issue.
I'm assuming you might be having problems with the Boot Order if you're having issues with loading your OS from CD. When you have the Windows CD in the CD ROM and you reboot the system, you should see the following message flash up on the screen (immediately following your OEM BIOS Splash screen):
"Press any Key to Boot from CD..."
If you don't see this message and your CD ROM Doesn't spin up and begin to load windows...you might have a Bad CD ROM, bad CD "Disc" or...you might not have your BIOS Boot Order set up correctly.
HOW TO FIX IT:
To get into the BIOS Setup on a Compaq Presario system, do the following:
When the OEM Logo Splash screen appears, press F1 to enter the BIOS Setup.
Note: On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
To change the Boot order:
Here's the URL for Compaq's Online FAQ for Changing the Boot Order:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07110&lc=en&cc=us&lang=tr&man_lang=en&product=1843681&dlc=tr#N1310
Try changing the Boot Device Priority in the BIOS Setup: Make sure that the "CD ROM" entry is moved "Before" the entry for the Hard Drive and Network PXE:
Example Boot Order:
  1. CD ROM or Removable Media
  2. USB
  3. Floppy (if you have one)
  4. Hard Drive
  5. PXE (Network Boot)
This should help you load the OS successfully from CD (if you're not being presented with the "Press any Key to Boot from CD..." notification when rebooting with the Windows CD in the CD/ROM drive.
Please repost if this fixed your problem and rate my response!
Good Luck,
LounaTech
Apr 17, 2008 | Compaq Presario SR1800NX Desktop PC
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
