Question about Linear Corporation Linear DNT00089 Mega Code MCT-3 Three Button Visor Garage Door Remote - LD033 LD050 LS050 Compatible
Linear garage door opener LS050, won't stay closed
2 Suggested Answers
  • 10291 Answers
SOURCE: linear garage door opens and closes when close to unit about 10 '
when the door stops moving when going down, pull the emergency release handle on the door and then push the door closed by hand. Once it's closed push the emergency handle back so it engages the chain. Open the door and close it a few times to make sure it closes all the way with the motor.
Posted on Oct 01, 2014
Linear garage door opens and closes when close to unit about 10 '
Oct 01, 2014 | Linear Corporation Linear Garage Door...
My linear garage door opener will work now and than ? on remotes but works fine with hard wired remotes ?
how old are the batteries in the remotes. Hard wired remotes usually don't have a wire length limit.
How to get my garage door to open all the way?
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Jun 15, 2014 | liftmaster Garage Door 1/2 Hp
The light on the Garage door blinks but doesn't stay on.
(Winston-Salem, NC)
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
Garage door light blinks but doesn't stay on
(Winston-Salem, NC)
My Linear garage door keypad has two codes that will open and I want to change to only one
I don't think you can erase the old code. Get on their website and see. Try calling them and asking the question. I think there is a way you can erase all the codes and then start over.
Dec 17, 2017 | Home Security
The sensor light are different colors
The sensors are seeing something directly in line with the beam between the 2 sensors, or your sensors are not aligned so they point directly at each other.
Jan 12, 2013 | Craftsman Sears Liftmaster Garage Door...
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
Linear Corporation Linear DNT00089 Mega Code MCT-3 Three Button Visor Garage Door Remote - LD033 LD050 LS050 Compatible Logo
163 people viewed this question
Top Linear Corporation Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Linear Corporation Building Material Expert? Answer questions, earn points and help others
