Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher SHU432UC/U06 manual
I need an owners manual
dragonsthatk
  • 547 Answers
SOURCE: SHU4302UC/U06 runs for hours. What's the fix?
timer
Posted on Feb 18, 2009
SOURCE: Bosch SHU5302UC/U06 dishwasher starts at
I had the same problem a few years ago and the tech replaced the control panel. No problems until....last night. Now a different problem.
Posted on Mar 27, 2009
DrakeTech
  • 61 Answers
SOURCE: I have a bosch dishwasher shu6805uc/u06 to long to wash.
Well not going into the dry cycle could be a timing issue or a EOC (control panel) issue and will need to be addressed. But most dishwashers these days have a active run time during normal cycle of 110 to 120 mins, and thats not including the heated dry feature. I would let the unit run and see if it will finish on its own, and if I say it pushes two and half hours then something is wrong. A tech would most likely have to look at it, also a power reset could help but thats like a 30% chance.
DrakeTech
Posted on Dec 30, 2009
NoMorTosh4Me
  • 17 Answers
SOURCE: Any known problems with Bosch
Go To The Bosch website and get the info on the recall for the faulty controller which may cause a fire! This model is on the recall list!
Posted on Oct 18, 2010
Macmarkus
  • 2605 Answers
SOURCE: 12 year old - Bosch
Hello, welcome to FixYa.
Based on your description,...the issue is likely with the inlet/water valve. Either ir is clogged, not getting power or it has failed.
**To remedy this you will need to check and possibly replace the valve**
This is what to look for..i.e.
As long as your model number is indeed correct, this info below will be accurate.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple.
**Before attempting to repair the unit please turn off the power (you will need power to check for voltage at the valve though) and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can check for 120vac when valve is energized as well as visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in you should be good to go. Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
Posted on Jun 14, 2011
Bosch Dishwasher Model SHU5315UC/U06 Looking for Cycle Buttons That are no longer avail #176079
There are several places on-line where you can find this parts. Depending on where you are. For example you can look up www.dlpartsco.com
May 08, 2016 | Bosch Dishwashers
SHU4002UC/U06
Sounds like the water inlet valve has failed. just fixed mine with the same prob.
http://www.youtube.com/watch?v=i5nygF7meKQ
Dec 30, 2013 | Bosch Dishwashers
DrakeTech
Dec 30, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Any known problems with Bosch dishwasher model SHU3302UC/U06 front switch package melting? Thanks John
May 07, 2009 | Bosch Dishwashers
Dishwasher stalls
SOUNDS TO ME YOUR CONTROL MODULE IS NOT WORKING CORRECTLY
Apr 07, 2009 | Bosch SHU4006 Dishwasher
We have a +11 year old Bosch SHU3006/UC/U06 that never leaves the wash cycle. We had to stop it during our last test run at 3 hours. Chat advise is suggesting a water temperature problem (I origionall...
Check continuity of the heating element to see if it is broken/open.
The dishwasher prefers that the incoming water (water heater) be 120 degrees (F)
Apr 04, 2009 | Bosch SHU3036UC Dishwasher
Bosch SHU5302UC/U06 dishwasher starts at 2H and eventually starts but continues for a long time at 1 without rinsing the dishes.
Jun 17, 2008 | Bosch Dishwashers
Bosch 24 in. SHU53 Built-in Dishwasher Logo
14 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
