Question about DeLonghi Heating & Cooling
Model G93 T EX:1
TURN OFF BY ITSELF
How do I reset my customized home page. It reset itself to the factory settings overnight.
Hi Faye
Your cell phone should not reset itself... you may have a virus on the phone. Can you provide the model and make of the phone please? (ex: Nokia 975)
Apr 05, 2016 | Cell Phones
Opens then closes
I suggest you try a new battery, most camera batteries are good for 1 to 3 years.
Mar 27, 2012 | Casio EXILIM EX-Z1000 Digital Camera
How to reset canon ip2700
WindowsThe printer driver you no longer use can be deleted.When deleting the printer driver, first exit all programs that are running. The procedure to delete the unnecessary printer driver is as follows:
  • When There is an Uninstaller
1. Start the uninstaller - If you are using Windows 7, Windows Vista, select the Start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller.- If you are using Windows XP, select the start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller. - If you are using Windows 2000, select the Start menu -> Programs -> "Your model name" -> Printer Driver Uninstaller.
Restart the Computer and perform the following:Windows
  • If you connect the printer via USB cable before installing the software:
For Windows 7:(1) Remove the USB cable connected to your computer.(2) Proceed to 1.
For Windows Vista/Windows XP/Windows 2000:The above dialog box may appear.(1) Remove the USB cable connected to your computer.If the dialog box closes, proceed to 1.(2) Click Cancel.(3) Proceed to 1.
  • Easy-WebPrint EX:
If you are using Internet Explorer 7 or later, you can use the Web print software Easy-WebPrint EX. An internet connection is required for installation.
1. g0069739.pngPress the ON button (A) to TURN OFF THE PRINTER.Operating noise may continue for up to 25 seconds until the printer turns off.
2. g0069740.pngTurn on the computer, then insert the Setup CD-ROM into the CD-ROM drive.If you are using Windows, the setup program starts automatically.
Mar 31, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Window AC Model No. : LG LWA18G 2DF1AK42 IS THERE INBUILT HEATING FUNCTION? HOW TO USE?
Please try to understand with your model, the tonnage and also whether it's cool only or heat & cool. 12,000 (12)...........means 1 TR. with this help your a/c is 1.5 Tr and if it's heat and cool definately there wil be indication in the model cde it self. Ex.......A18TH DF..... like this. There will be H added in the model code itself. Yours is not heat mode. Is it helpful?
Dec 13, 2010 | Amana PTC094B35AM Air Conditioner
MY TI nspire always rounds numbers to the first decimal place. (EX 23.7 instead of 23.74)
Turn it on, hit MODE then change the FLOAT value from 1 to Float itself. Float allows you to round, and something changed that setting
Dec 02, 2010 | Texas Instruments TI-Nspire Graphic...
I have my 2005 Odyssey brought to Europe.Now I need to do aligment.Even Honda services don't have alignent settings.Is anyone there who could help me???
Alignment: Specifications
Alignment
Wheel Alignment
Tire size:
VAN, LX, EX, EX-L models: P235/65R16 103T
EX-L Touring model: P235-710R460A 104T
Tire pressure:
Front (VAN, LX, EX, EX-L Touring models) ........................................................................................................... 230 kPa (2.3 kgf/cm2, 33 psi)
Front (EX-L model) .................................................................................................................................................. 240 kPa (2.4 kgf/cm2, 35 psi)
Rear ........................................................................................................................................................................... 240 kPa (2.4 kgf/cm2, 35 psi)
Caster angle ................................................................................................................................................................................................... 2° 32' ± 1°
Camber angle:
Front ........................................................................................................................................................................................................ 0° 00' ± 30'
(Maximum difference between the front right and left side: 0° 30')
Rear ............................................................................................................................................................................................................. -0° 30' ± 45'
The camber angle can be adjusted up to ±25' (center of tolerance) by replacing one damper pinch bolt with the adjusting bolt. The camber angle can
be adjusted up to 50' by replacing both damper pinch bolts with the adjusting bolts.
Front toe-in ............................................................................................................................................................................. 0 ± 2 mm (0 ± 1/16 inch)
Rear toe-in ......................................................................................................................................................................... 2 ± 2 mm (1/16 ± 1/16 inch)
Turning angle
Inward wheel 41° 56' ±2°
Outward wheel 34° 32' (Reference)
Toe - 0° +/- 2mm
Sep 22, 2009 | 2005 Honda Odyssey
Camera stabilizer not available
You should update a firmware to new version 1.03 / download from Casio site / . It will allow You to take pictures without camera stabiliser.
This problem with camera stabiliser needs lens alignement in authorized service.
Regards
Gryf
Oct 08, 2008 | Casio Exilim EX-V7 Digital Camera
System error 0e01
Maximale Kapazität von SD-Speicherkarten bei Verwendung mit CASIO Digitalkameras Error 0e01: It has to do with the maximum save capacity of the used SD-Cards (max. 1GB for following models). You can format the card (somehow, maybe with docking station), then it would only have 1GB capacity...
...found on Casio Homepage...
Bitte beachten Sie, dass die folgenden CASIO Digitalkameras die Verwendung von SD-Speicherkarten mit Kapazitäten von mehr als 1 GB nicht unterstützen. Bitte berücksichtigen Sie dies beim Kauf von SD-Speicherkarten für diese Kameramodelle.
CASIO kann nicht für die ordnungsgemäße Funktion von SD-Speicherkarten in den Kameras garantieren, auch wenn die Kapazität der Speicherkarte 1 GB nicht überschreitet.
Für welche Modelle ist dies gültig?
  • QV-R3
  • QV-R4
  • QV-R40
  • QV-R41
  • QV-R51
  • QV-R52
  • QV-R61
  • QV-R62
  • EX-S1
  • EX-S2
  • EX-S3
  • EX-S20
  • EX-S20U
  • EX-S100
  • EX-M1
  • EX-M2
  • EX-M20
  • EX-M20U
  • EX-Z3
  • EX-Z4
  • EX-Z4U
  • EX-Z30
  • EX-Z40
  • EX-Z50
  • EX-Z55
  • EX-P600
  • EX-P700
Welche Probleme können auftreten?
  • Die Fehlermeldung "CARD ERROR" wird auf dem Bildschirm angezeigt. Die Aufnahme von Bildern ist nicht möglich.
  • Wird die Speicherkarte in der Kamera formatiert, reduziert sich die Speicherkapazität auf ca. 1 GB.
Jun 08, 2008 | Casio Exilim EX-Z40 Digital Camera
Prob. with Casio Exilim Zoom EX-Z700 Digital Camera
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fi x it.
Aug 16, 2007 | Casio Exilim Zoom EX-Z700 Digital Camera
Heating & Cooling Logo
22 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
