Error e4 fujitec eco 487lw 1
It displays e4 and it is not running al all
3 Suggested Answers
SOURCE: E4 Error code on APE07AHM1
I emptied the water tray. Viola!
Posted on Jul 17, 2008
ineedabin50249
  • 755 Answers
SOURCE: I need service manual for A/C FUJITEC 487LW-I.Thank you.
goto their sight
Posted on Dec 10, 2014
FUJITEC FW1-487LW shows E2
Hi
dear I have problem with my aircon
it show E2 as eror and started to bip bip
what can i do
thanks so much
May 04, 2012 | Heating & Cooling
Error code Df and e4
E4 Outdoor activation of low pressure switch/ less suction pressure.
Check back pressure, which should be 60 PSI when ambient temp 98 degree.If not Short of gas- find leak and arrest. And do gas charging. Even due to indoor coil dust blocked also e4 arise. Clean the coil and reset it.
Nov 25, 2010 | Napoleon NHPS12 Air Conditioner
What men cod e4 on dishwosher kenwood kdw12st3a
Hi
Error e4 on Kenmore usually occurs when there is drain clogging or due to debris stuck in the bottom of the dishwasher. Drain out the excess water from the dishwasher, now remove the mesh and the filter. Now, check and remove any food material or debris stuck. Now pour 1-2 litres of luke warm water and let this water drain. After this replace the parts and run the dishwasher on eco mode without any tablets or soap. Try this 2-3 times and then reset the dishwasher by unplugging it for 5-10 minutes.
Please post back for any further assistance.
Daniel
Jul 21, 2010 | Kenmore 15762 Dishwasher
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
Jul 16, 2008 | GE APH10AA Air Conditioner
Error code 4
check the sub code , it would read E4-? , such as E4-10 is fuser fan, E4-01 is low fuser temp, sometimes hold the print key after in code and sub code may appear. Then you can go to next step of repair.
Jan 30, 2008 | Panasonic FP-7735 Black and White Copier
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
