Question about managemylife.com
Kenmore dryer won't heat
My clothes dryer will not heat up to dry the clothes. Checked my owners manual and found that it could possibly be the thermal limiter. Wanted to try and DIY this problem.
    Habit-Forming:
  • 84 Answers
Check utube how to videos.
Posted on Jan 07, 2014
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
Needs two cycles to dry clothes!
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 19, 2012 | Kenmore Dryers
Wet and cold clothes after cycle
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 31, 2010 | Kenmore 72062 Gas Dryer
Dryer not drying clothing.
heatman101
May 24, 2010 | GE Profile Harmony DPGT750EC Electric...
Kenmore dryer taking long time to dry clothes. Checked and cleaned vent outside the dryer. Any help?
1) Check to see if your dryer has two elements. Sometimes there are more than one element.
2) or if the switch governing the dryer heat works.
3) One other possible problem- the thermostat (actually a switch which operates until reaching a certain temperature) is bad.
Dec 14, 2009 | Dryers
Kenmore 11066912690 dryer stops working
if you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
Sep 16, 2009 | Kenmore 62602 Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
managemylife.com Logo
109 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
