Question about Calphalon Quick Brew 12-Cup Coffee Maker
Calphalon coffee maker stopped brewing, and the heating plate doesn't heat.
Brews good hot coffee but warming plate has stopped heating! Are replacement elements readily available or could it be a fuse...??
The DCC-1200 has only one element, that both heats the water for brewing and keeps the carafe warm. If you're brewing coffee then the element is fine and the suspect part is the Thermistor. Another forum suggested this was a Vishnay NTCLG100E22245B, available from DigiKey (their part # BC2467), connected to the control board with thin yellow wires. The same forum suggested that this thermistor should test at 220K ohms at room temperature, dropping to 20K at about 220F.
Nov 17, 2015 | Cuisinart DCC-1200 Coffee Maker
Can't set the time
User guide:
http://www.calphalon.com/Assets/Files/1800470_1800541_QuickBrewCoffee_UG.pdf
Jun 06, 2014 | Calphalon Quick Brew 12-Cup Coffee Maker
Water not heating
If it's full of water & the red light is on, check if the maker is heating up the warming plate..if not, odds are you may have a bad heating element. Brewing cycle won't start without it.
Apr 06, 2014 | Gevalia CM-500 12 Cup Coffee Maker
Not heating up
Possible that the heater has failed , the thermostat had failed, the switch or the wires to the heater, in all cases you need to trace the continuity of the said items.
Dec 31, 2012 | Calphalon Quick Brew 12-Cup Coffee Maker
Doesn't heat or brew.
Send to Factory for repair.
Oct 19, 2012 | Keurig B30 Mini Coffee Maker
My < year old DeLonghi
If the light comes on and the coffee is not brewing than it is the heat plate temperature fuse. You need tamper torx bits to open the bottom unit and replace the fuse, radio shack sells them. I have had to change several of these on Delonghi products. These are mechanical connections and the leads need to be crimped properly or the unit will fail.
Mar 12, 2011 | DeLonghi Coffee Makers & Espresso Machines
I have an inexpensive chefmate 12 cup coffee maker, and it's still pretty new. But it stops brewing about 1/2 way through, and is painfully slow the rest of the time. Do I have a "you get what you pay...
I had the same problem. Sometimes opening and shutting the top will get the heating element to come on again. I took mine apart and installed a switch to bypass the thermal sensor located on the underside of the hot plate, throwing the switch forces the heating element on until brewing is complete.
Oct 04, 2010 | Coffee Makers & Espresso Machines
Coffee maker did not heat
An electric coffee maker has an electric flow-through brewing water heater with a heating resistor controlled by a temperature dependent regulating switch responsive to the temperature of the heating resistor, and a warming plate heated by the heating resistor for maintaining the prepared coffee at a desired drinking temperature. Apparatus for adjustably prolonging the interruption of heating current 2 to 5 times the normal cooling time of the regulating switch is connected in circuit with the heating resistor and the regulating switch, and a manually actuated small quantity control means connects the heating current interruption prolonging apparatus in circuit with the heating resistor and the regulating switch. The prolonging apparatus may be an adjustable auxiliary electric heater in parallel with the regulating switch and thermally coupled thereto or an adjustable timer in series with the heating resistor and regulation switch and triggered by the opening of the regulating switch
Jan 31, 2010 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
Calphalon Quick Brew 12-Cup Coffee Maker Logo
Top Calphalon Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Calphalon Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
